Page 1 of 7 123 ... LastLast
Results 1 to 40 of 255
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    B7 center console swap ** the entire parts list, in all colors
    I've posted this before but I couldn't edit the original list/post. Anyways, here's the entire parts list, in black:
    Center console : 8E0-863-241-E-6PS
    Hand brake assembly: 8E0-711-303-L
    Hand brake trim: 8E0-863-276-C-6PS (this trim covers the area on the console beneath the hand brake)
    Power outlet assembly: 8E0-863-284-C-6PS
    Hand brake Boot: 8E0-711-463-D-6PS
    Hand brake bracket for boot: 8E0-711-543-D-4PK (this is the sleeve that goes on the e-brake assembly first, then the actual boot fits over this)
    Hand brake button: 8E0-711-333-B-3Q7 (yes, you guessed it, the e-brake button is sold separately)
    3rd mounting bolt for hand brake assembly: N 101 277 07 (thanks to skeeball for providing this info)
    NEW INFO: If need to order these items in other colors, you would simply need to replace the part numbers ending the black color code, "6PS" with the following color codes that apply to you:
    EC3 - light platinum (grey)
    4D9 - indigo
    8C1 - torrone (beige)
    This is everything you'll need. Now there is one other part, which is the metal "U' shaped bracket that fits in the console, beneath the hand brake for support but it is ABSOLUTELY not needed. I promise you. I wasted money purchasing this piece.
    This is start to finished product, sort of:
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Re: B7 center console swap -- the entire parts list, in black
    You did that for a cup holder?
    789whp
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    best mod i've ever seen! :) hail smoothie king!
    Sep 20 2006
    MD
    Quote Originally Posted by Howard Hughes View Post
    Yep, I sure did AND for the fact that my old console was peeling.
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    YES!!! Want to post a DIY. I'm ordering this!
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    same for manuals, correct?
    not 1 cup holder, TWO!
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Buncha motorcycles
    Memphis, TN
    man that looks nice! mine is peeling like hell as well... what did it set you back?
    APR Stage 2/AWE Intake
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by WiZZLa View Post
    two USABLE cup holders...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Deactivated Three Rings
    Apr 11 2008
    thought about doing this.. cost? time?
    Sep 20 2006
    MD
    Took me about half the day. I got things at cost pretty much so it was under $400 for everything. Yes, the autos and manuals have the same part numbers, except for the shift boot, etc.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Does it have the same coating as the original one?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    Thanks so much for posting this! I bought all the parts off a fellow AZer about six months ago, but I was too lazy to write down the part numbers. I've had a number of people ask me for help on this, so this should answer all their questions.
    Now Gondi Stylz do a DIY write-up and everyone should be good. The tricky part is the e-brake. It is tricky to release the cable yoke tension and a little tricky to hook the e-brake cables back up and re-tension. Otherwise the install is fairly straightforward.
    The new console is the new finish which does not look like it will peel like the old ones. If you have a black interior (Soul) it will match perfectly. I've heard the beige is different. Don't know about other colors. Plus, the 2 usable cup holders are at a lower center of gravity than the dash mounted cup launcher. You will never spill a drop with these! Only downside is you lose the cool James Bond cigarette lighter.
    Mar 21 2006
    Lakeland, FL.
    Good to know, thanks!
    I'm back bitches!
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Quote Originally Posted by derleicaman View Post
    Look's like I'm going to have too
    Any tips?
    Sep 20 2006
    MD
    ^^ The only tricky thing is releasing and re-tensioning the brake cables. Everything else is straight forward. Here are some tips though:
    1. you have to remove the radio and climate control. The climate control is not screwed in but rather fitted in with spring clips to hold it in place.
    2. there are plenty of screws, most of them are hidden under the tranny shifter plate.
    3. IN the rear of the console, make sure you remove the bolts that hold the arm rest on.
    4. Remove the door locking/rear seat heating assembly location at the rear of the center console.
    5. The factory wire harness for the original cig lighter will not mate to the new cig lighter, you'll have to cut the wires and attach female blade terminals on the ends and just plug 'em up to their appropriate contacts.
    Can't think of anything else right now.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    thank you ray you where much help, do you want me to take any pictures when i do my swap
    Sep 20 2006
    MD
    If you need any help, pics will aid in resolving whatever issue you may encounter.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Clean. I like it. Got the p/ns for platinum?
    No need for a DIY. Just start unscrewing screws and your existing center console is out. Start screwing in screws and the new one is installed. Its fairly simple.
    -Doug
    Sep 14 2007
    2004 A4 1.8T, 93 Ford Festiva
    Nazareth, PA
    my biggest complaint about the b7 is the cupholder, personally i hate it there....good idea though
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    In my friends 06 b7, the rubberized surfaces are peeling WAY more than my 02. His arm rest looks like it has a terrible sunburn.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Sep 07 2007
    Atlanta GA
    that sucks maybe his was juust a bad console.
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    Quote Originally Posted by RLB6 View Post
    Gangster!
    The B6 center console is plain retarded.
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    wow ... exactly what i want to do ... how long how muchh post a diy dude
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Do we need any new screws and/or bolts? Just reuse what we have?
    Where should I buy this? Stealer? Online?
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    I searched the B7 forum for "peeling" posts and it returned basically nothing... so what is the verdict? The B7 console does not peel? This update is very, very tempting!
    Thanks for the writeup!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Sep 07 2007
    Atlanta GA
    I just finished mine... let me tell you i feel like iamm driving a brand new car....
    Jun 30 2007
    A4, S4
    Orange County, CA
    damn this seems tempting to do
    Apr 20 2007
    Lander, Wyoming
    I just priced it out for all the parts on GAP, the total came to $345.69 (retail is $501.01) plus $25.39 shipping = $371.62.
    hmmmmm...
    Jon
    go > show
    Ich liebe mein Audi
    Registered Member Three Rings Colt556's Avatar
    Dec 16 2007
    03 A4 Avant, 03 Getta 24v GLI,
    Indianapolis
    I did a similiar swap on my 03 Getta and love it! I was wondering if this was possible. Thanks for the info, I'll be ordering the parts this week!
    I just reread the post. On my Jetta I was able to "Adjust" the e brake handle with my foot so it bent into place and I saved almost half the cost. did it a year ago and no problems whatsoever...
    It's an Avant Thing...
    03 A4 Avant 1.8TQ Tip, APR 1+, APR exhaust, Carbonio, Eibach Pro Street, Hotchkis swaybars, OEM E code HIDs, Aero Wipers, 20% Tint, B5 S4 Calipers with Cryo Power Slot Rotors, 18x8.5 BBS CHs, More to come....
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by lookaught View Post
    hmmmmm...
    Their shipping calculator is wrong, the console alone is over $100 to ship.
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by 400HPA4 View Post
    Their shipping calculator may be wrong but I've always paid the price they listed. I ordered my console from them last year and it was under $20 for shipping.
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    anyone ever try to spray their existing console with plasti or anything. I need to the new look at the bare minimum.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by edwardabodnar View Post
    Click here.
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    question.. with the new console. Can I use my old Push button for the E-brake? I would rather save myself the $5 (ya i know its ridiculous, but its 2 gal of gas.. aka 44miles!)
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Veteran Member Four Rings oildrpr's Avatar
    Apr 07 2007
    Huntington Beach, Cali
    does this console use the same rear ashtray as the b6 console? i want to make sure my old brushed alum. lid will work..
    Jan 25 2006
    A4 2.0T
    MD
    It so wierd to see an automatic shifter there....
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Quote Originally Posted by oildrpr View Post
    yes
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    I think i'll do this next summer
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    The color code for platinum appears to have not changed between the B6 and B7 so I would assume the colors match. No guarantee. So for platinum interior you would change the '6PS' in all the above part numbers to 'EC3'.
    I know this thread got resurrected, but I figured I would throw out the info for future searchers.
    Established Member Two Rings VAGguy's Avatar
    Apr 08 2008
    04 Passat Variant 1.8T Manual Swap
    Abingdon, MD
    Exactly what I was searching for. Thanks for bringing it into recent postings!
