Results 1 to 40 of 52
    Sep 17 2006
    07 cbr600
    Car won't start when HOT.
    Ok so normally it seems that peoples cars won't start when its cold but my car does not like to start when it gets HOT.
    If i go for a long drive and the car gets up to temp (middle of the gauge) and then i stop to go in a store and come back within 5 minutes it will not start back up. Ill have to crank it for a while.
    If its too hot I have to open the hood then crank it for a little and it will fire up.
    Now if i let it sit for a little and cool down it will start right up no problems.
    Is there anything simple i should be looking for? There isn't a CEL.
    Apr 22 2007
    Riverbank, Ca
    Re: Car won't start when HOT.
    Starter turns over just fine?
    Feb 27 2005
    North Wales, PA
    coolant temp sensor
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by Poopie View Post
    coolant temp sensor
    I replaced that less then 10k miles ago, think it would be that? Car started fine before the BT.
    Yeah it turns perfect.
    Feb 27 2005
    North Wales, PA
    well you may not have a CEL but you could have some stored codes that may point you in the right direction. I'm still leaning towards the coolant temp sensor.
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    How does it act when you turn the key? Go out and check if there is any spark if it does than next step would be to look if it's getting fuel. How old is the fuel pressure regulator? Like poopie said temp sensor would do that, check the wires that go to it maybe it looses ground when it get's hot.
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by GetAwayFromMe View Post
    Does it turn over, clicks? How does it act when you turn the key? Go out and check if there is any spark if it does than next step would be to look if it's getting fuel.
    It starts up everytime everyday. When its cold its normal turn key start up. When its hot its hold key and crrank for 30-40 seconds.
    Ill try and check it out today, the FPR is the stock origonal one.
    Poopie ill try and get a VAG to check for some codes.
    I actually did get a CEL yesterday after boosting real hard but i didn't think that had anything to do with this problem being that ive drove for 3.5k miles now with it starting like this.
    Apr 21 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    start off by checking your plugs, make sure they are the right ones for your setup and ensure that the fuel is being delivered.
    Sep 17 2006
    07 cbr600
    The plugs are what autospeed used so they should be ok i forget what ones they are ill have to look.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Hmm. I learned my lesson to diagnose an issue right as it starts happening and not 3.5k miles in. 30-40seconds on the starter heats it up
    I'm also thinking it's the coolant temp sensor. It is probably faulty and tells the ECU that the temp is higher than normal. The vag can tell you the temperature of the sensor but there is also a way to check what the sensor reads by using the climate control hidden function but I forgot how to access that exactly.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    i have the same problem with my car as well...changed the plugs, coil packs, and CTS and it still sucks starting it when its hot. I have to crank it for 45sec and give it gas. if its cold it starts right up
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by nebone22 View Post
    Well it runs fine once started so im not to worried about it. Just an inconvenience. Im gonna try and get a vag com tonight and see if i can find anything out.
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by AudiRacerS4 View Post
    Oh yeah i remember PMing you a little while back, i guess you still havn't figured it out either and you replaced all that stuff hmmm
    I also have to give it gas when cranking it.
    Feb 15 2007
    marimont
    110% the crank sensor located behind the oil filter. Replace that and bam you guys are back in service.
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by solowb5 View Post
    Thanks man you sound pretty confident and I do need an oil change so probably would be a good time to give it a try. Does anyone know the P/N or somewhere i could get one the dealer wants 130 for it.
    edit found the DIY i think the crank sensor and engine speed sensor are the same thing just two different names?: Im not sure if the p/n is the same for a B5
    http://www.audizine.com/forum/showthread.php?t=104097
    Feb 15 2007
    marimont
    I believe there are vendors on ebay that have them for around 50ish.
    Sep 17 2006
    07 cbr600
    Ive noticed people with this sensor problem also get an EPC light and the car stalls often, my car never stalls and i havn't got the EPC light either, think it would still be the be the problem?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I did a generic search on google for various engines for this issue and its either coolant temp sensor or crank position sensor.
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    I had the same exact symptoms/problem and it was the coolant temp sensor. I couldn't even stop for gas without having to wait 20 minutes to start the car again! Very inconvenient.
    I picked one up at a VW dealership for 30 bucks. They had it in stock. Tada Problem Fixed.
    Feb 15 2007
    marimont
    I had mine go out and didn't get a epc. I am an 01 by the way.
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by Matt@JHM View Post
    damn i really cant imagine it being the coolant sensor after i just replaced it but for 30 bucks its worth trying both to see if it gets fixed.
    thanks everyone for the help
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I seen a bad Coolant Temp sensor right out of the box. Gauge would never go above cold.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Are you running a new tune?
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    this is a yes
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Jul 07 2004
    socal
    Quote Originally Posted by firstarsbrnwhit View Post
    this is a yes
    If so then it could just be his "hot start" fueling, the tuner can fix that.
    Sep 17 2006
    07 cbr600
    yeah this is most likley it because it did not happen until they started to tune my car and after it was tuned.
    To bad i just bought the engine speed sensor for 95$ and it will be installed tommorrow
    Apr 14 2008
    a4 avant
    marlboro
    either what hood said or coolant temp....my ko4 setup had that happen first it was crank for a like 30secs when it was hot then it just wouldnt start....
    -vrt-
    Sep 22 2008
    A6 1,9TDI Avant 04´´
    DENMARK
    Hi guys.
    Did you fix your problem and what part did you change???
    I have an A6 1,9tdi with engine code AVF and it´s the same problem i have when the engine is hot,have changed the coolant temp sensor with out succes. what to do now ??????
    Flying ...
    97 A4 2.0TQM
    Rochester, NY
    I'd check your manifold air temperature sensor too.
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by pac1085 View Post
    That wouldn't cause the car not to start when the car it hot. Would just make for thrown off fueling. I was driving around with one disconnected for an hour before I realized I forgot to reconnect it after working on the car.
    -18 718 GTS
    Sep 22 2008
    DENMARK
    I forgot to tell the begin of the story: I filled the tank with diesel and the car stopped suddenly after 1 km.Cheched it out with the vagcom no faults.
    Changed the diesel filter thought it might be full of shit didn´t help.tryed to start the engine no succes.Tow the car to a freinds workshop emptyed the tank and the diesel was dirty and with some water in it.New filter and filled diesel and the engin started.
    It worked fine for a couple of days,spoke with an audi mechanic and he suggested that i should put some carburater alcohole in the tank to get all
    water out of it.I than hade the vagcom on againe and it said something with "engine speed sensor" deleted and went for a drive no fault.
    The next day it worked fine in the morning, but in the evning was for a drive
    and stopped by a gasstation stopped the car and came out after 15 min and it wouldn´t start it only cranked and cranked.But if I spary some diesel start help in the air intake it starts fine.
    So I don´t now what´s wrong
    Jan 25 2006
    A4 2.0T
    MD
    Diesel huh? Not sure we can help.
    Oct 29 2005
    10speed
    San Francisco, CA
    Hey Russel, Dougyfresh was havign the same problem, I dont think Mark@ASP has figured it out yet
    - Clint
    Sep 17 2006
    07 cbr600
    I never actually installed my sensor, at 95$ i wasn't going to chance that it "might" help. I'm leaning towards mine being tuning and i should be getting it fixed in Oct. Ill let you know if it was just my tune if not ill replace some sensors. I might also try to find a cheap sensor (didn't feel like looking before and just got it at the VW dealer) and try it out anyway.
    Sep 17 2006
    07 cbr600
    Yeah, i was talking to Dougyfresh in some PMs and he said he had the same problem. I know he has his car down there now so hopefully Mark can figure it out and fix mine also!
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Quote Originally Posted by Russell2686 View Post
    So did you install the new coolant temp sensor yet?
    Sep 17 2006
    07 cbr600
    nah i didnt install any sensors or anything. i think its my tune because someone with the same tune as me is having the same problem and also it never happened until after i got my kit installed
    Senior Member Three Rings ForceFed's Avatar
    Dec 30 2008
    minnesota
    hey just wondering if you fixed it yet. iam having the same exact problem. i cant seem to find out whats causing it. iam getting fuel i know that. i have unitronics tune for the gtrs eilm turbo. my problem also started the day after i installed the turbo/tune/injectors. so iam hoping that its not the tune but might be.....any help or info would be great if you figured anything out yet
    01 Silver s4. BASIC BITCH
    04 Ultra Sport black on black 1.8t 6spd Avant
    00 s4 6spd dp's, magnaflow twin 2.25in,k04, j-fonz ,pss9's,hotchkiss sways,19vmrSOLD
    sold98 a4 1.8t quattro 5spd, some mods...GT2860elim,unitronics tune, 415cc injectors(green top), 3in vr6 maf, carbonio intake,2.5in exhaust, bilstien pss9's, 18in OZs, EVOMS intercooler 2.5in piping ect..
    sold91 ford sho white on black, modded
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by ForceFed View Post
    Yeah I had it fixed. It was the tune. It was giving to much fuel when hot. They tweaked the file and it was all good.
    Dec 30 2008
    minnesota
    what tune do/did you have?
