Results 1 to 25 of 25
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    225 vs 235 on an 8" wheel?
    I bought the set of wheels used with 235s on them, i like the look of the size but when the car gets lowered will i rub? The exact sizes im looking at are 235/40/18 and 225/40/19. Anyone have pics of a 225 on 8" wide wheels?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    Re: 225 vs 235 on an 8" wheel?
    Im rubbing right now in the fronts with 235/40/r18 my wheels are 18x8 32mm offset. Its actually not rubbing its cutting the shiet outta it. But im gonna get my fenders rolled this saturday.
    Feb 12 2008
    01' S4/ 98' Boxster
    Lake Oswego/Corvallis
    search. you will most likely have to roll the fenders with a 235 if you are lowered. 225 usually is the right size.
    Aug 18 2007
    Ohio
    Still looking for pics
    2002 TT Silver 225
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    225/40/18 on an 8" (rear wheels)
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    i have 235/40/18 no rubbing lower..
    Before my shocks settled .
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    225/35-19 is the correct size. We have more rubbing problems with height than with width. I've run 235 and 245mm widths at various heights without rubbing.
    Jim
    I Do Werk.
    Established Member Two Rings lud's Avatar
    Mar 21 2006
    2.8 Q 5 speed// flash red 01 S
    laval
    it really depends on how low you are.
    If it aint Euro its Shit
    Mar 11 2008
    san diego ca
    I usually like atleast half an inch in my wheel well. Thats why im getting my fenders rolled.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Quote Originally Posted by JDM EJ1 95 View Post
    There is no way that is an 8" wheel the back. And look how stretched that tire looks.
    Stage 3+ RS6's
    Feb 28 2007
    chicagoland
    its a 225... of course its stretched....
    Nogaro 01 s4
    620whp 93octane
    Dec 11 2006
    Boston
    225 on 8 is not stretched.
    Stage 3+ RS6's
    Feb 28 2007
    chicagoland
    ooops my bad lol i thought the tread was wanting pics of 9 inch wheels :P
    Nogaro 01 s4
    620whp 93octane
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    I ran 235/40/18 on my 18in Rs6s for about a year before buying 225s because they were a lot cheaper than 235s. I'm lowered on Neuspeed sport with bilstein grooved shocks. No rubbing what so ever.
    TEAM|AXION
    Dec 11 2006
    Boston
    hahaha no harm done.
    Stage 3+ RS6's
    Aug 18 2007
    Ohio
    Im thinking of going with the 225's because of the 100 dollar savings over the 235's plus the peace of mind knowing i wont have to get new tires or rolled fenders when it gets dropped.
    2002 TT Silver 225
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    i rubbed but im low and i have a 26 offset. i had to get 215's to not rub
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    I'm not that low, but I'm on H&R coil overs and on 245s all the way. No rubbing.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    235's here. I would rub when going over bumps but it was only the plastic liner. I cut those out and got the fenders rolled just in case and no problems.
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Mar 11 2008
    san diego ca
    Damn yo 215 thats small what size are your rim? Thats a nice car though.
    Mar 09 2004
    nw michigan.
    It is the offset that forces the smaller tires, not the rim width.
    Half of the equation is the tire size but the other half is where you place that tire. You could run a 155mm wide tire and put it into the control arm or fender with the wrong offset. You can also run a 245 or 255mm tire with the proper offset and fenders rolled and never rub on anything but the ground. I've done the measurements and could get a 265mm tire in there if one was available that was short enough to avoid the rear upright.
    Jim
    I Do Werk.
    Senior Member Two Rings DEB5S4's Avatar
    Jun 21 2008
    Stamford, CT
    I'm running 235/40/18's on a set of Enkei SC05's with a 35 offset on the H&R and Bilstein setup. The tires are definitely a plus size but i wanted to run as much tread as possible. Before I rolled my fenders, the side of the tire was absolutely getting shreaded but once I rolled and pulled my fenders I've had no problems since.
    Mar 09 2004
    nw michigan.
    Quote Originally Posted by DEB5S4 View Post
    Your new tires are a half inch taller than stock which is where the problem lies. Go to a 235/35-18 (shorter) or 245/35-18 (stock height) and there will be less chance of rubbing.
    This is how it works folks. The fender lip angles up over the tire. The inner control arm does the same thing in the rear. This is why taller is bad. If you go tall then the offset becomes more critical than ever.
    Jim
    I Do Werk.
    Jun 21 2008
    Stamford, CT
    Quote Originally Posted by onemoremile View Post
    I purposely went with a 40 sidewall because of the condition of the roads in the location I live. I wanted more sidewall for a slightly more comfortable ride, and to absorb shock to my wheels in the case of potholes and less then desirable road conidtions. It was a thought out decision not just a mistake. For 5 minutes of work on the fender the problem was resolved.
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Ya, but you also have an 8.5" wheel with a 38 offset.. I have this setup too but the right offset here is key. I also noticed that Michelin tires are more squared off then the BF goodrich I am driving on right now... something else to think about.
    Quote Originally Posted by Bigair View Post
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
