So anyways, I was driving home from work tonight and once I got out on the highway I noticed a huge wobble in the car. The car was swaying from side to side with the slightest movement of the steering wheel. I was only going 60 to 65 MPH. I knew I had a slight leak in my left rear tire so I figured it must have turned into a BIG leak while parked at work. So I just happened to be coming up to an exit where I usually go to air up my tires. I pulled up to the pump, got out, and checked the left rear tire that usually goes low on me. Nope not that tire this time. So I walked around to the other side and the right rear tire was almost completely empty. Why? I don't know. I only live 5 minutes away so I decided to air it up and go home and figure out what to do next.
Well, I started to air it up and it seemed like it was filling up. However, I couldn't notice any change in the sidewall as I was airing it up. Granted, it was kinda dark behind the gas station. I heard what sounded to me like rocks, gravel etc. adjusting underneath the tire so I assumed it was taking in air. I stopped and thought for a second to make sure that the sound was what I thought it was. I started to air it up again and before I knew it BOOOOOOMMMMM! The tire exploded! Smoke, dust, etc. went spraying everywhere and knocked me back a bit.
I couldn't have been airing it up for more than 10 total seconds. I can't believe that I could have overinflated the tire from "flat" to "explode" in that amount of time. Something went wrong. I just can't figure out what.
Luckily for me, since I had an autocross yesterday (no I don't autocross on my street tires) I had all my equipment still in the car. So I jacked up the car and pulled the blown tire off and put on the 17" OEM spare and drove home.
Here's a couple pics. Anyone have any idea why this happened? I inspected the tire and saw 3 or 4 nails/sharp metal objects in the tire so I guess that explains the flat. I just don't see why it would blow up from any other reason but overinflation. And right before it happened it still looked flat.
That's part of the wheel well carpet sitting inside the wheel.
I need a drink!
Van
