Results 1 to 10 of 10
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    APR Tuned - 2.0 TSI & 2.0T FSI - DYNO GRAPHS - Comparisons Inside!
    Discuss:
    Stock FSI vs Stock TSI
    Stock FSI vs APR Tuned FSI vs Stock TSI vs APR Tuned TSI
    All figures measured at the crank.
    All runs using 93 octane.
    All hardware is stock.
    Registered Member Two Rings
    May 14 2008
    Latif
    Re: APR Tuned - 2.0 TSI & 2.0T FSI - DYNO GRAPHS - Comparisons Inside!
    Interesting thread. So whats the release date for TSI 93 octane software?
    Euro Technik Autosport
    Jan 10 2007
    VA
    Looks like the new motor (2.0 TFSI) makes near identical power/torque as the old motor (FSI 2.0T), both stock and with APR software. All this really concludes is that the old motor was basically underated from the factory, and that the new motor has better power down low, but less up high (rpm wise).
    Aug 23 2008
    Auburn, AL
    One note on stock numbers most don't consider. 91 octane is recommended for the vehicle. We are using 93 octane in the graphs above.
    Established Member Two Rings AJN334's Avatar
    Sep 21 2004
    Chicago
    Why does the TSI lose so much steam compared to the FSI at high engine speed near redline? I didnt know the motors were that different...I had read that the new motor would deliver more power early and less power late but figured it had to do with the tuning from the factory...guess not
    Can someone fill me in, was causes this with the new motor?
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Quote Originally Posted by b6onboost View Post
    That's the trend I've been seeing with Audi/VW and the 2.0 engine. The newest version is more diesel like than the previous one, and I for one think it's NOT a good idea.
    Low RPM torque is gook, mainly for city driving.
    But, I like high rpm torque for performance driving, and those graphs don't speak well for the new engine.
    It SERIOUSLY lack on the top end. That's how they are getting some of the improved MPG: less revs, less friction, less power up top, better MPG.
    The software bumps and smooths things a bit, however, compared to the FSI the TSI only improves the low rpm curve a bit. It's less power, but it's more linear down low, until it gets higher revs and then it's seriously drops.
    The Audi version with variable valve lift should really help a lot. Too bad VW cut costs and thus cut performance on the new TSI. Looking at those graphs the TSI really does need better breathing at high revs, and better valve control would help that.
    It's also possible that the intake is quite restricted on the new engine, and simply can't breathe as easily when revs climb.
    It would be cool to see a better intake flow and it's numbers and graphs.
    Good info on the dyno's.
    Sep 29 2008
    Henderson Nevada
    Per the first graph (stock/stock) the T FSI engine tends to have a slightly more linear power curve which is great for a turbo car (or any car for that matter but hard to get in an exhaust driven/forced induction app). The power drop does not occur till late in the graph (over 5k). Not too many folks are driving in that range often anyways.
    From the thousands of motorcycle dyno runs my company has done we have always found that the bike with a linear power curve and a peak of 110hp (rainbow graph) will always beat the bike with 135hp peak and a spiked power curve (mtn peak graph). Of course this being on the same motorcycle. By the time the "spike graph" bike has reached its maxium hp out put the "rainbow graph" bike is long gone due to the power made all the way through the rpm range.
    I am assuming this is what Audi/Vw engineers are looking for; linear power? Who wouldn't be?
    Veteran Member Four Rings fusionx's Avatar
    May 16 2008
    07 A3 2.0T
    Socal / Boston
    what company is company is gonna come out with the TFSI chip first?!
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Registered Member Two Rings kwanja_a3's Avatar
    Mar 28 2007
    2007 Audi A3 2.0T S-Line
    Toronto, Canada
    Quote Originally Posted by fusionx View Post
    http://www.revotechnik.com/aboutRevo...20_Sept08.aspx
    2007 Audi A3 2.0T S-Line 6MT
    http://mydubspace.com/kwanja3
    Deactivated Three Rings
    Jun 15 2007
    2007 GTI 2.0T
    Charlotte, NC
    APR TSI Software is already released, Just chipped my wifes new TSI Jetta a week ago and its awesome. Also I think the software for the new DSG cars in a million times better. Shifts lightning fast and smooth you barely feel it upshift or down shift.
