Results 1 to 12 of 12
    Senior Member Two Rings collegedude10's Avatar
    Jan 06 2008
    A5 3.2 6MT, B6 A4 3.0
    Oil level sensor going out on me?
    the low oil light came on twice the past three days. all i did was check the oil level and then the light would go away. What can it be? I noticed its happen when i have pushed the car, put it in Sport mode, or drive manual and engine break to about 4k rpms. could the dipstick be coming lose a little bit and setting of the low engine light.
    this happened before about a month ago. changed the oil, was not clumpy or anything abnormal, and went away.
    should i change the oil level sensor? if so where would i get one and how hard is it to change? get a new dipstick?
    is the sensor by the dipstick?
    2009 Audi A5 3.2 6MT
    hopefully this list grows...
    Jan 06 2008
    Re: Oil level sensor going out on me?
    anyone?....
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    first you need to determine what warning you are getting. There is a "Low oil" warning that indicates you need to add oil. Then there is the red "low oil pressure" warning that indicates a lack of pressure. This one is serious and could be an indication of sludge, bad oil pump, etc. Then there is a third warning for the "oil level sensor" which indicates a problem with the sender unit. The sender unit is located on the bottom of the oil pan. It is the rectangular part with the wires connected to it. I believe it cost around $90. Which light are you getting?
    Here is what the sender unit looks like. Part number 1J0 907 660 B. If you replace it be sure to get a new "O" ring with the unit (part # 038 103 196). Just drain the oil, unplug sensor, remove three bolts, replace unit, done! Also be aware that the sensor changed between the '02 3.0 (Ch#8E-2-400000) and '03 3.0 (Ch#8E-3-000001) The '03 uses sender # 1J0 907 660 C which is the same as the one for the 1.8T. Check your chassis number before ordering.
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Not much I can add to old guys's post besides my personal experience... When I first got mine, I had the exact same symptom; I brought it in and it was determined to be the oil sensor which I had replaced under warranty.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    i replaced my sensor. forgot how much it was. 35 dollars? changed it at oil service.
    Jan 06 2008
    thanks for the input guys. the sensor was $85 ... is there a picture where i can see where this sucker goes?
    Dec 28 2006
    Western Maryland
    It goes in the bottom of the oil pan where you see the recessed opening:
    Mar 29 2005
    Acura MDX
    New England
    Quote Originally Posted by collegedude10 View Post
    you bought it from the wrong place, GenuineAudiParts.com has it for $60,
    Riverside audi for $63, vs local dealer was $104. I have had a "oil level sensor" warning and am replacing this sucker tomorrow. G'luck with yours.
    also, mine came with an o-ring already installed so I have a spare one now, LOL.
    '12 Golf .:R /
    Apr 12 2007
    Milwaukee
    my oil level sensor failed because the terminal on the sender > red wire clip broke off and the tab is in the clip.
    Jun 21 2005
    Milton, Ontario
    I'm bringing this back from the dead....
    Could this sensor fail due to road debris smacking it? Or a lowered car scraping on speed bumps?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jan 06 2008
    my situation is a little weird. my catlytic converter went out on me, thankfully covered on warranty. eversince the dealership changed the converter the low oil light went away. since i already bought the sensor im just going to change anyway as a preventive measure.
    Jun 21 2005
    Milton, Ontario
    I see. My oil pressure sensor went bad, and I have to replace it. But I am unsure of what caused it to go bad, just trying to figure it out.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
