Results 1 to 19 of 19
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    Exclamation Turbo noise on start up
    My turbo whines and squeals when I start it for 30 seconds to a minute or so when the engine is cold. I thought the bearing in the factory original K03 was going bad since the car does have 90K miles on it. I just had it replaced and it's still making the same noise.
    I have no idea what's wrong with the car at this point Any idea's guys? I'm seriously about to give up and bring it to the dealership to trade it in for anything none VW/AUDI at this point.
    Feb 07 2006
    ouellette
    Re: Turbo noise on start up
    It's so frustrating, other than this the car is running great. Actually the best it's ever run since I bought it at 60K miles. In fact, I'm actually getting about 5mpg more than i used on the highway, and the car pulls as stronger than it ever has.
    I've been worried that it might be an issue with the turbo not getting enough oil due to a sludge issue. But if that were the case, wouldn't the care kinda run poorly?
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    It's the SAI (secondary air injector) pump running to help warm the car up quicker when the engine is cold. Yours is just making more noise than it should, probably on it's way out.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    ^^ agreed with gdawg.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    yeah, its your secondary air injection pump. It freaked me out too. sounds like its coming from the turbo but its not. Ended up being that the output hose wasnt clipped on all the way on the pump. PHEW!! check it out. If you get underneath your car on a creeper, its the black thing on the right that has 2 hoses going to it. its right in the corner. youll see it. Check for cracks or loose fittings
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Feb 07 2006
    ouellette
    Thanks guys, I'll check it out.
    Anyone know where to get one cheaply? I've spent thousands of dollars trying to fix this, and can't afford to keep throwing money at it.
    Feb 07 2006
    ouellette
    The noise does increase/decrease with engine rpm's. would the SAI really do that?
    Feb 07 2006
    ouellette
    could i unplug the electrical connection to the pump to see if it still makes the noise? I'm guessing I'll get a cel with it unplugged?
    Feb 07 2006
    ouellette
    it's hard to get answers here unless it's a coilpack failure or a BT question
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    on a cold start, have a buddy start it while your underneath. youll be able to pin point it. if you listen from the top then its useless. it goes away after you hit second gear right?
    03' 1.8T Tiptronic
    Ziza yellow Fogs
    A6 engine mounts
    Feb 07 2006
    ouellette
    ya it goes away about the time I get to second gear, or if I let it idle until it's reach normal temp.
    Feb 07 2006
    ouellette
    do I need to use a creeper, or can I just pull my fog light out? I'm hoping to disconnect it and try starting the car up.
    The SAI has been pretty loud the past year or so. Wouldn't be a big surprise if it was bad after all.
    May 03 2005
    Boston
    You may fit under the car without jacking it up. Best to remove the belly pan and look up behind the fog light, kind of hard to tell with the small opening of the fog light area.
    People have disconnected their SAI IIRC (or maybe I'm thinking of something else), maybe do a search on that.
    EPL S2 + TCU
    Previous Cars:
    Feb 07 2006
    ouellette
    assuming mine is bad, I'm wondering how necessary of a system it really is. I could probably tie a resistor in to let the ECU think it's still in place.
    removing it would also provide some space to maybe route some more cold air to the intake.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    SAI can be removed all together, the BAT guys do it all the time to clean up/make room. Check A4ringedone's build thread about 13 pages in and it shows how he did it. GL...
    Feb 07 2006
    ouellette
    So I finally got a day off and got around to unplugging the SAI pump to see if I still get the horrible noise when I start the car.......yup.
    I stuck my head under the car while it was making the noise to see if I could figure out exactly where it's coming from and it does sounds like it's coming from the turbo.
    Anyone have any other ideas beside leaving the car parked in a bad neighborhood with the keys in the ignition and a sign on the roof that says "PLEASE GOD SOMEONE STEAL ME!"
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I used to have this problem, but my turbo died before I ever found out what it was. It certainly could be the SAI since I had to mess with it for my AFE intake install and I couldn't hear anything from above and it fit all the symptoms you guys mentioned above. I'll have to see if it still does it after I install the new turbo.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Feb 07 2006
    ouellette
    no it's not the SAI. I unplugged it and still get the same noise. To me it sounds like the turbo doesn't have enough oil on startup. I'm wondering if my oil lines may be a little clogged.
    It started making the noise after I seafoamed the engine in april. Two turbo's and $4k latter.....still have the same noise. The only part I haven't replaced is the oil lines.
    Feb 07 2006
    ouellette
    Killerteve, did you replace the oil lines when you swapped out turbo?
