NOTE: The ignition switch going bad can affect a number of things in your car. In my particular instance, my car was having difficulty starting. It would rev up to about 2000 rpm for about a second before it would die off. It would then take sometimes as many as a half dozen attempts to finally start the vehicle.
Tools Needed:
T8 Torx (I was able to make a T10 work)
8mm socket
4mm allen
Small flathead screwdriver
12 point (triple squared) bit or even an equivalent Torx
Patience
Process:
**disconnect the battery**
Remove the side fuse panel to access one of the 8mm screws for the knee bolster.
Remove all three 8mm screws and remove the knee bolster. You will have to remove the left side fuse panel to get to one of them. (I didn’t actually remove the knee bolster, hence no pics, during my replacement and it was somewhat a nightmare, so I would definitely recommend it.)
Unscrew the two T8 screws on the lower steering column shroud. (I only had a T10 but it somehow worked)
You will also need to remove a 4mm allen from just above the steering wheel adjust lever. You will have to pull the lever down to reveal the screw.
Remove the lower shroud (this will take some maneuvering to clear the steering wheel adjust lever).
Flip the upper portion of the shroud into the instrument panel to get it out of the way.
Remove the two T30 Torx bolts from the back side of the steering wheel and the airbag should fall out.
Unplug the connector from the steering wheel to the airbag
Unplug the connectors from the steering column to the steering wheel.
Next, remove the steering wheel by removing the center portion with a 12point (triplesquared) bit. I didn’t have one and it’s almost impossible to find these bits at hardware stores or car part stores. So you could order one off the internet but I was able to use the equivalent Torx bit size and I’ve been told that an alan wrench might work too.
Before removing the wheel, mark the interior and exterior splines with a sharpie or something so that you can line it back up upon reinstall and then pull the wheel off. If you have trouble getting your splines lined back up, remember that if you put the key in, you can rotate the steering wheel again.
Next, you will look on the bottom of the steering column assembly directly in front of the ignition assembly for a silver 4mm allen screw. Remove it.
Now on the top left of the steering column you must unplug this connector (the latch to push in is on the opposite side from you).
Also, remove the black plug on the left end of the ignition (it will have a purple piece on its left side.
Next there will be a small flathead screw on the bottom portion of the ignition tumbler. The head of this screw is covered with red wax or plastic so you have to scrape that off first. Then back out the screw but DO NOT remove it.
Now, to get to the next screw (the reason you removed the steering wheel) you have to pull back on the front portion of the steering column but do not remove it. Pulling it back should reveal the second plastic covered screw, so repeat what you did with the first one.
Now the ignition switch should pop out because its spring loaded. Once you have it out, look at the yellow pieces on your old and new switches and make sure they are lined up the same to each other with respect to how they are installed into the tumbler. If they are not, use a flathead screwdriver to rotate the new one to the correct position.
Finally just reinstall everything in the reverse way as explained above. You might throw errors for a day or two. My ESP light stayed on for a day or two, the auto-windows didn't work for a day, and my key remote didn't work for a day.
