Results 1 to 9 of 9
    Sep 19 2007
    seattle
    Anyone had their ECM replaced?
    The dealer told me today the Check Engine Light comes on for 2nd time was because ECM was bad and they needed to replace it. Has anyone had their ECM replaced/repaired before? Is this a big job? Should I be worried this car is a lemon with only 1k miles?
    Thanks.
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: Anyone had their ECM replaced?
    Should be under warranty right?! Don't think it's too hard to plug in a whole new ECM, it's located under the plenum cover next to the brake fluid reservoir. If they are just replacing part of it then they have to remove the box, heat the bolts (to losen the thread lock compound) and put the new module in. They then use their VAS system to recode the ECU unlock the cruise control and immobilizer system.
    I paraphrased from the Bentley manual, but I would think that a day of work is involved if they have the tools.
    Edit: As far a lemon is concerned? I don't think that a single occurrence would be cause for alarm. If the car kept frying ECUs then I would be worried. From a cost perspective, I'd be more worried about mechanical failures over electrical ones.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Don't worry about it. When I bought my 92 Jetta it was warm and summer ,drove down to SoCal for 3weeks in Sept and it ran great . When I got home to Vancouver it was cold , got up next morning and it took 3 tries to start it! Dealership changed the ECU because they said cold start programing was wrong.Bad ECU'S happen thats what warranty is for.
    Sep 19 2007
    seattle
    ok, thanks gentlemen! good luck to me this time!
    Senior Member Three Rings lrae's Avatar
    Jul 22 2007
    b7%20s4%2C%20b8.5%20sq5%2C%20488gtb
    Southern NH
    Mine went bad, but for other reasons. Its not too difficult, they take off the large cover on top of the firewall, unbolt the winshield wipers, take the windshield cowl off, use a torx screwdriver to unbolt the ecu box, then there are a couple screws on the ecu you gotta grind off otherwise you cant get it out for security reasons. Then they pop a new ecu in and theyll have to recode all the keys. This is from what I remember after what had happened to me at Waterfest.
    2007 S4 Phantom Black Pearl / Ebony Nappa | RNS-E | CF | Corsa Catback | 034 Suspension Goodies| Bilstein B14 | RS4 Grille | VMR V706 19x8.5
    2016 SQ5 Daytona Gray Pearl / Ebony Fine Nappa | Carbon Atlas | Black Optics | APR Stage II w/XLR8 196.5mm Single Pulley | Roc-Euro | H&R Sport Springs
    2018 Ferrari 488 GTB | Rosso Scuderia
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Quote Originally Posted by lrae View Post
    Care to tell what happened
    Jul 22 2007
    Southern NH
    Chip flashing gone wrong.....
    Aug 18 2008
    SoVA
    no worries. i've had 2 of them replaced in the last four years. one in my '04 r32 and the other in my '05 GTO.
    Registered Member Three Rings
    Jul 22 2008
    2006 S4 25th Anniv. Ed.
    Fed Way, WA
    LOL... Dude, they've figured out the one fault, and the car will be trouble free for the rest of it's life.
    http://i234.photobucket.com/albums/e...ProfileDay.jpg
    "I think I'm going to get metal legs."
