Results 1 to 19 of 19
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Changed Plugs to E3 Spark Plugs
    Had them for over two weeks, just had the chance to install them yesterday morning. Some people really make this process of changing plugs seem much harder than it is. It is for the most part, just like changing plugs on any car, actually, I found it much easier.
    Torqued each one to 22lbs/square inch. I took my time. It took 30 minutes to replace all 4.
    Took the car out to test it out and there is a little difference in power which you can feel, very slight though, nothing like the boost in power that a chip brings to the table.
    I've been using octane boosters on my car and it seems evident that MMT may not be that great for the car. All four of my spark plugs had orange coatings on them. After doing some research on the internet, I found that this was caused by the MMT that leaves a residue. So I will discontinue the use of octane boosters containing the MMT.
    Overall, seeing as I got the spark plugs for Free-ninety-nine, it was ok, they would have otherwised cost $6.99 each, which is the same as the Platinum or Iridium NGK's. The E3 has a Copper core, but I think the electrode may be either iridium or platinum, since they have a 100,000 mile or 5 year change interval. I don't know if there is a mileage advantage, it is too soon to tell. I will update as that gets better.
    They have a Video on Horsepower TV that shows these plugs produced 5.5 more bhp (at the Flywheel or crank) with less fuel consumption vs the stock NGK Super Platinum on a V8.
    You can learn more about them here: CLICK, if you would like.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Re: Changed Plugs to E3 Spark Plugs
    keep us posted
    Some fast things and some slow things
    ~Josh~
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I saw that episode. Keep is posted, did mileage go up?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by dirtybrd View Post
    I sure will, drove to work today, 100 miles round trip, so I may have a better idea, tonight. From the look of just the drive to work, no, nothing has dramatically improved or even slightly. Number 2, mileage counter was at 25.9 as of Friday, is down to 25.7 today, albeit, I did a lot of stop and go and city driving this weekend. The drive from home to work, is not really a good judge of Highway miles, since anyone who has driven I-80 in the bay area during rush hour will attest, it very inconsistent.
    USP Member 110
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    I put these plug into my car a while ago. I was a little skeptical about them because they cross reference the plug with the NGK BKR7E (one step colder) the BKR6E (stock heat range) and the Bosch F5DPOR (two heat ranges lower)
    i noticed when installed that I would pull an average of 1-2 degrees more timing under boost. Now I know the conditions were not controlled for before and after. I also called up the company and asked about the heat range and they didn't really know. All I can say is I took them out.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by gotaudi View Post
    You are whole lot more modded than I am...but I thought that for chipped or "better" cars we should use a colder plug, which in this case as you said: BKR7E. But since I am very mildly modded from stock, this may not be an issue for me? Or should it?
    USP Member 110
    Dec 25 2004
    Earth
    I run these-
    Best plug you can get for the modded B6 1.8T!
    Jun 15 2008
    Fairfield, CA
    UPDATE:
    Trip home yesterday, the trip mileage average (number 1) indicated 30.6 mpg, 10 miles city, 40 miles highway. Compared to normally, for the same trip, not accounting controlled, similar road conditions, temperature, shift points, etc. it usually was 25.9. So unscientifically, I gained 4.7 mpg based on this trip. My overall, counter number 2, has also increased 25.7 to 25.8.
    Too early for a real conclusion, but it seems to be giving what they claim, a little more umph, using less gas.
    USP Member 110
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Quote Originally Posted by MikTip View Post
    I run these-
    just got these too. what is the correct gap spec on these? or the factory spec ok since these are side fire?
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    What performance mods do you have on your car and where did you pick these up? I just recently switched to NGK Coppers BKR6E on my Stage 1 (not 1+) and am not 100% happy with them.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Dec 31 2006
    boston, ma
    Quote Originally Posted by Exanimas View Post
    what problems are you having?..i went between the 6's and 7's and my car is much more responsive with the 6's..also who's software are you running?
    Apr 23 2007
    Just got them in and did some test driving. Loving the plug so far. No pinging whatsoever yet and almost no vibration at idle. So far i tried NGK 6e's, 7e's and Bosch f5pdc's. Have not been happy with any from the very first minute i had them in. I think this is the one finaly and no more 5K replacements either! Will see how they hold out.
    btw, bought mine on ebay from this guy. good and professional seller. ran me $40 a set.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by eclimax13 View Post
    I'm running APR. There is a huge variable though... The night that I changed them was one of the first cold nights we had and since then it's been about 50 or below every time I start my car. Gas mileage seems worse and idle is still pretty rough. Also (could be due to the cold), my boost gauge is showing that my vacuum is a bit lower then I'm stopped, not sure if this is a good or a bad thing.
    -Nick
    Dec 31 2006
    boston, ma
    my idle is a little rough too unless the outside temp goes up but once that happens the idle is smooth...no problems with gas mileage...i have mine gapped at .30...ill prob go some iridiums next time...with the 7's i lost low end power from 2k-3k..i would have no power til i hit 3k which i didnt like...then i put the 6's in and the low end was back to normal..i dont understand why it idles so rough when its cold out but once it hits about 60 degrees ...the idle is nice and smooth
    Mar 09 2008
    is full of crap.
    Boston, MA
    Oh yea, forgot to mention, mine are gapped to .29, since I heard that's what APR's tune is made for.
    -Nick
    Dec 31 2006
    boston, ma
    ya..thats what they told me..and use a stock heat range...have you tried the 7s?
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    I run these-
    Compare with IK22 which one is better?
    Mar 09 2008
    is full of crap.
    Boston, MA
    No, but I figured I shouldn't have to since I'm only stage 1 and you know how cold it's been lately.
    -Nick
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    I run these-
    those look expensive.
    i'd stay away from those E3 plugs myself. all that junk on the plug is going to hamper intake flow.
