Results 1 to 8 of 8
    Established Member Two Rings bradisonn's Avatar
    Jun 18 2008
    2001 A4 1.8T Sport Edition
    San Diego, CA
    About to take on DIY speaker adapters...
    How thick does the ABS plastic have to be? And would I be better off going with MDF wood or something?
    Also, if anyone has done this, how did it go? Is it still a good fit (no rattling or anything)?
    Thanks in advance!
    2001.5 TIP Audi A4: Sport Edition, Brilliant Black, Chrome Exhaust Tips, NGK Laser Platinum Spark Plugs, 8000K HID headlight kit. Nothing really, just got my timing belt done at 86K
    Planning to get: RS4 Grill, Kicker Sound system, Clarion Double-Din Head Unit, 5% Rear 35% Front Windows Tint, HID fog lights, up to any suggestions...
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    Re: About to take on DIY speaker adapters...
    I have done this for the fronts. For the rears you can buy meta adapters from crutchfield. I used the speaker grilles that came with my kappa 5 1/4'' speakers. I had to dremel the stock screw rods off and part of the door to make them fit. It is a tight fit and you will be test fitting the door to make sure it works with the window. I did this a few months ago and put my speakers louder then my ears can take with no rattles
    Dont bother with the ebay.uk adapters. will cost you $40 and take a while to deliver. Make your own
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    If you get a sheet of ABS, it should be at least 1/8" thick. MDF is also a decent substitute. I created my own brackets with an extra set of speaker brackets i had lying around. Speakers are solid with no rattles or vibrations.
    Necessity is the mother of all inventions, and there is no "right way" to mount speakers in the front door panels. Be creative, i'm sure you'll find something that will work.
    Also, try searching the forums, i've seen several topics that cover this and should be of some help. Good luck
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Dec 05 2007
    CA LA
    does any one here have a DIY? preferably one that shows what to do to keep the door card looking stock?
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    You're better off using the speaker adapters if you want a complete seal around the baffle of the speaker--it's worth the extra few bucks in the time you'll be spending. You can use a piece of plexiglass, mdf, or others, but the clearances will be off (PITA to reinstall the door card), and you will need to seal the CRAP out of the edges with strip caulking. If you don't seal the speakers, they will sound like hollow, lacking bass, and easily distort because there is no proper baffle. But whichever setup you use, order yourself some of this:
    http://www.partsexpress.com/pe/showd...number=269-300
    This caulk is like clay, but will stick to and make an airtight seal around your speakers.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    mdf is fine and easier to use. then use the caulking posted above or some kind of sound deadener ot seal the rings.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by JaVa View Post
    In my case, I used 5.25's with some pretty massive magnets. Doorcard was a PITA to reinstall. With MDF, I had to keep re-drilling to position the driver where it will clear the door. And if you're using 1/4" thick MDF, we all know what a threaded screw will do... strip. So instead I was drilling holes using nut/bolt to secure the driver. Ended up using plexi instead. On the other B5, I just ordered adapters, and it made my life a lot easier.
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    wheres a good place to get the adapters?
    -06 A4 2.0T
    -97 A4 1.8T
