Results 1 to 12 of 12
    Registered Member Two Rings
    Jul 02 2008
    nj
    where to get licence plate light screws??
    i stripped mine and audi said u have to but the plastice cover with it..any1 know where to get just the screws?
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Re: where to get licence plate light screws??
    man that sux. I know a few member's here have had drilled them out. Not sure if they used the a bigger screw to replace it.
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Three Rings 04TurboB6's Avatar
    Feb 17 2008
    Leesburg, Va
    that happened to me when i first bought the car back in Feb...i had to drill out the stripped screw.
    fortunately i had some small screws laying around the house to replace them
    good luck
    Aug 05 2008
    Philly
    i would also like to know. my dealer put longer screws on and the damn thing rattles like crazy...
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    when this happened to me, i just had to buy a new unit (plastic piece + screw)... Ive actually had to buy a couple of them now. They are like $17.00, so not a big deal, but I guess it is when all you need is a $0.02 screw.
    Veteran Member Three Rings dfresh000's Avatar
    NNJ
    Lowes has the screws (just replaced mine last month).. its like size A-3 in the metric section.. thats my best guess, but once you see the screw you'll know. bring the old one to match up as well
    '13 Monsoon Gray S4 P+ | DSG | Carbon Atlas | B&O | Sports Diff | More Fun to Come
    '14 Monsoon Gray Q5 3.0T P+ | B&O
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    Quote Originally Posted by Hotel Guy View Post
    Same here. These license plate assemblies are such a horrible design. Those tiny little screws strip like crazy. I simply drilled my stripped screws out and drilled in new holes with better screws.
    Registered Member Two Rings zeven13's Avatar
    Aug 10 2007
    '07 Audi A8, '03 Audi A4
    St. Paul, MN / Sioux Falls, SD
    Yup... Lowe's
    Optimized Operations Engineering Manager, PE, MBA, CSCP
    MN Plates: UR 2SLO
    Xbox Live: Z The Voice Z
    Jun 11 2008
    Williamsport, Pa
    when i bought my car the plate rattled they put the wrong size metric screws in (way too long) anyhow i took one to a hardware store spent 1.50 on 4 new screws about 1/4 in in length. granted they arnt screw heads they are bolt but i dont mind that
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Buy the whole lens with screw. Even if the lens and terminals are okay they will most likely shit the bed as soon as its all back together. They are delicate.
    Put some vasoline on the screw and around the o-ring on the lens. This will prevent road salt build-up and corrosion on the terminals for the bulb (a big problem here in the northeast).
    -Doug
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Go to loews and they'll thread match it and hook you up
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    20 Nissan Rogue ~ 08 Highlander Sport
    SE PA
    i got nice stainless steel replacements at Sears Hardware. just take your old one with you to compare.
