Results 1 to 27 of 27
    Jul 17 2008
    d
    Engine coolant temperature sensor
    My ECT gauge has been acting up, going from 0 to half and then back randomly at all times. MY CEL came on at one point but went off again. Is this the ECT sensor? Do I need a new part? if so, what part #? thanks
    Feb 27 2005
    North Wales, PA
    Re: Engine coolant temperature sensor
    yes, the question has been answered before. you can find the part on ecs or just go to the dealership. it should onle be $20-$30.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    if you go to a vdub or audi dealership and tell them you need a coolant temp sensor for whatever year your car is, theyll hoook you up.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Dec 04 2007
    New York, NY
    i dont think the the coolant sensor will throw a CEL ?
    Can someone correct me on this .
    Aug 09 2007
    Mount Airy, MD
    it will, i had one, and i thought it was causing my boosting problems. i replaced it. so now it doesnt throw that code anymore... but i still dont boost right...
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    It does throw a CEL. It can sometimes be a tricky bastard and throw a CEL thats not related to it but caused by it. You need to search your code and the cause will most likely be that sensor.
    What year and engine in your car?
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Dec 04 2007
    New York, NY
    i think he has a 01 a4 1.8
    Jan 21 2006
    6MT BT Avant Ti
    RI
    It totally sucks to replace that sensor on the 01. You have to literally hug the motor with both hands. You'll know what I mean when you get to it.
    Jul 25 2008
    US
    That sensor is actually 2 sensors in one (bonus!) That's why there are 4 conductors, half go straight to the gauge, the other half go to the ECU.
    So if the gauge side of the sensor goes bad, then your gauge starts acting flaky but it doesn't throw a CEL. Or if the ECU side of the sensor goes bad, you can get a CEL but your gauge runs fine. Kooky.
    Established Member Two Rings jpo's Avatar
    Jun 22 2008
    Calgary
    I threw a CEL for the ECT sensor..what is more I was having boost issues (i.e. slowest car on earth for about 10 mins after start up) that went away after the sensor was replaced.
    Jan 26 2007
    Bingo, NY
    I got a CEL from my ECT and it was covered under that extended warranty thing from Audi they mailed out. I got my letter back in like April or May of this year. I have a 2001 A4 so you should be covered on yours as well.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    ^ O yea. Just go to the dealer and they will do it free of charge.
    Awaiting Confirmation One Ring
    May 07 2009
    2001 Audi A4 1.8
    San Jose
    Was wondering if your ECT gauge would never "warm up" on drives, or if the gauge was actually broken.
    What's happening with mine is I would go for a long drive and the gauge would never say it's warmed up. I would stop for something to eat, turn the car back on and the gauge would say it's warmed up. Then after driving a while it would cool back down.
    Was wondering if that's the gauge or something more expensive?
    Thanks
    Jul 25 2008
    US
    that could be your thermostat - common failure mode in our cars.
    98.5 A4 B5 1.8T ebay TO4E
    Jun 30 2008
    Erie, Pennsylvania
    Yes, could be thermostat, or could be the sensor. My car was doing the same thing a while back (reading cold while driving, and fluctuating). Changed the thermostat and it was all good. 3 months later it started doing it again! I was like, "another thermostat, really?", then one day the car was really hard to start and threw a code for the ECT sensor. Changed it and the gauge reads normal now.
    If you have vag-com you can compare the ECU's temp reading to your gauge. If they don't agree (gauge says cold, but ECU says ~90c), then the sensor is bad. If they do agree, then the car is *actually* running cold and it's probably your thermostat.
    May 07 2009
    2001 Audi A4 1.8
    San Jose
    Thanks! The computer and the car agreed on temp, so that gave me the answer.
    Nov 20 2010
    Heavily modded 2001.5 Audi A4, 2006 Mercedes Benz SLK 350
    Ontario
    Quote Originally Posted by Nebone View Post
    Just to add some credibility to this statement, I picked up a Bank 1 too lean code earlier this week. I had no idea what was going on until I was driving the next night and the coolant temperature on my cluster fell to 60 (ECT sensor stopped working). I guess it was on its way out and wasn't sending the proper temperature to either my cluster or the ECU.
    I ran VCDS the last couple of days to make sure my coolant was at the right temperature and logged my trim levels. Coolant (group 2) was reading fine at 90-95C and my trim levels (group 32) were 8.3(add)/-3.0(mult). Swapped the sensor today, cluster is working fine again and my additive trim has started to normalize.
    I didn't clear the MIL yet, waiting to see if it will go out on its own as my trim(a) levels get closer to 0.
    There was no DTC specifying the ECT sensor was going bad, just the lean code. On a related note, what a pain that thing is to get to. Be careful not to upset the braided vacuum line on the Kombi-valve if you haven't already swapped that line out.
    Deactivated One Ring
    Apr 24 2012
    Andrews
    Would a failure of the ECT cause the temp gauge to not work AT ALL and a slow depletion of the coolant from the coolant reservoir?
    Veteran Member Three Rings QuattroGinger's Avatar
    Oct 23 2010
    the Dorf MD
    if its the thermostat i would think it would overheat because of it not opening.
    Dec 05 2007
    If the thermostat was stuck closed, the car would overheat. If it were stuck open, it would take longer for the oil temp to warm up (probably would not warm up till driven). The CTS on the rear coolant flange would make your gauge be off. Bad thermo can also do the same thing.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by jahnetik View Post
    Well, the gauge needle is always pointing to *something*, so it is always "working" (ie: pointing to a temperature). Whether that temperature is *accurate* is the question. If the thermostat is stuck open (or removed), it would be expected that the coolant temp gauge would hardly move under average driving in cold weather. The other possibility is a faulty coolant temp sensor, or a faulty gauge. The gauge can be tested directly using vag-com's "output test mode" on the instrument cluster. It can command each of the gauge needles to move throughout their range. If the gauge itself is broken, that test would show it. Vag-com could also look at the incoming coolant temp value to the cluster. You could compare that to the incoming coolant temp value to the ECU (or to the physically measured temperature of the engine coolant using a thermometer).
    As for the leak, that would be a completely separate failure from the electronics, obviously. It could be the coolant temp sensor's o-ring that is leaking, or it could be the plastic coolant flange that it is mounted in. Both are common leaks. Other possibilities are hose connections, leaky radiator end tanks, etc. Generally cooling system leaks are found by the evidence of the leak (crusty pink stuff in the case of OEM Audi coolant) or by doing a pressure test of the cooling system and watching for the leaks in real time.
    Quote Originally Posted by QuattroGinger View Post
    The most common failure mode of a thermostat is for it to stick OPEN, making the car run cold. They are designed to fail in this manner, it is a fail-safe.
    Established Member Two Rings FU5E's Avatar
    Apr 11 2012
    2013 Audi A4, 2008 Porsche Carrera, 1956 Packard Executive
    Troy, MI
    Im having the same problem, my collant flange is leaking and I asked the dealer for the flange and the sensor, I got the flange? I have a 2001 1.8t do I need to call them with a part number or is this it? this thing is burried deep back there I only want to get back there once.
    __________________________________________________ __________________________________________________ ___________________________
    2013 Audi A4 2.0T APR Stage 2
    2008 Porsche Carrera - APR tune, Tubi Exhaust.
    2005 Audi A4 TQM 6 speed. K04 Stage II (sold)
    2001.5 Audi 1.8TQM A4 GT2871 elim. unitronics 440cc, vibrant 500hp intercooler, custom 3" mandrel bent exhaust..... (sold)
    https://tweetlerperformance.com/
    Dec 05 2007
    You need a replacement o-ring also for the flange. The coolant flange are block specific (or cylinder head specific) so it must be for the AWM. Part number is 058121132C. It will be molded onto the flange, so you just need to confirm you have the correct one. And you can pick up the sensor for $15 shipped from MJM (CTS also needs new o-ring).
    http://www.mjmautohaus.com/catalog/p...oducts_id=1207 (comes with o-ring for sensor)
    And to throw in a curve ball, my rear coolant flange was leaking. I inspected it, and found the flange to be just fine. So, I just replaced the o-ring (sourced the leak to here) and everything was fine after that. I would suggest you watch where the leak is actually coming from on that flange. But since you already have a replacement flange, might as well just swap it in. Only issue is it is more work in a really tight space.
    Jun 30 2008
    Erie, Pennsylvania
    For a 2001, you want to have the following on hand if you are going back there:
    Flange:http://www.ecstuning.com/Audi-B5_A4-...ges/ES2187573/
    Sensor:http://www.ecstuning.com/ES2535414/
    O-ring for sensor:http://www.ecstuning.com/Search/N90316802/ES2467/
    Clip for sensor:http://www.ecstuning.com/Search/032121142/ES1906430/
    O-ring for hard pipe:http://www.ecstuning.com/Search/058121687/ES250825/
    Quote Originally Posted by FU5E View Post
    Sounds like your dealer sucks...just sayin'
    Apr 11 2012
    Troy, MI
    Yup they dropped the ball on me
    Did get the leaking flange fixed though would have been nice if send me all of it, included all of it. So now I just have too wait for a sensor
    Thanks for the info though it helped me out
    Jan 24 2010
    melbourne australia
    I have a leaking flange snd found there was a bit of degredation of the plastic where the o ring sits.
    96 A4 1.8TQ
    FRANKEN TURBO K03-073, 1 BAR CHIP, SUPERTECH VALVES, PORT N POLISH, JE PISTONS, SCAT RODS, 034 MANIFOLD & FMIC, FIDANZA FW & SOUTHBEND STG 3, BILSTEIN & H&R, 3IN EXHAUST, CUSTOM AIR BOX, APR DV, DBA SLOTTED, RED STUFF.
    Oct 23 2010
    the Dorf MD
    fuck those flanges. my timing belt kit was easier for me to do than that thing. lol
