Page 1 of 6 123 ... LastLast
Results 1 to 40 of 226
    Oct 15 2006
    From a few to one...
    Arlington, VA
    In - Line Check Valves
    had one of mine go bad, and have been confused to what they are and where they are located. so i decided to take a few pics and try to help some of you guys out in the future.
    Part Number: #058 905 291 (thx to old guy, as usual)
    Places to Purchase:
    ECSTuning - http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
    PureMS - http://www.purems.com/products/product.php/II=1566
    When I called dealers, they quoted me around $40 each.
    Locations:
    Close-Ups:
    this one is broken and will soon be replaced.
    i assumed there were only 5 because that's all i could find. but i have been hearing that there are 6. if you know where the 6th one is, feel free to let me know and i'll update the thread. also, please let me know if any of this info is wrong. i'd hate to mislead people because i didn't know something.
    Edit: thx to AudiA4Turbo22, i found the 6th one. i took a pic and updated. let me know if there is anything else.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Aug 05 2008
    02 A4 1.8T MT
    Lexington, KY
    Re: In - Line Check Valves
    Good post. My front left one looked identical to yours. Got a new one for around 20 bucks from my mechanic.
    Buncha motorcycles
    Memphis, TN
    there is just five..... there is some cheaper ones you can get, i forget what they are called but one is different and must be dealer ordered....
    APR Stage 2/AWE Intake
    Dec 06 2007
    u missed one, look below ur intake manifold it runs along it, please take a pic and show us.
    -Kirk
    BetaAlphaTau Member #58
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    So are those the check valves that you can just get rid off?
    -Sami-
    Feb 17 2005
    Sarasota, FL
    Simple, take all that shit out then you dont need any
    Buncha motorcycles
    Memphis, TN
    how?
    Feb 17 2005
    Sarasota, FL
    Grab and pull .. pull HARD!
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Quote Originally Posted by A4ringedONE8T View Post
    ahahah... just dont hit yourself in the face when pulling!
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by AudiA4Turbo22 View Post
    updated. thx for that info. hope the pics are good enough. if need be, i can try and clear things out and take some more pics, but i think you guys get the general idea.
    Quote Originally Posted by Papachristou View Post
    do you know which one is different?
    is there no negative consequence of removing these? i assume you have to get replacement hoses to all the locations?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by NyteEscape View Post
    Taking alot of the stuff out removes the need to run hoses to those "places"
    Dec 06 2007
    i've been looking for a pic of that one under the intake manifold forever thanx man!
    -Kirk
    Oct 29 2005
    10speed
    San Francisco, CA
    lol what Shawn is trying to say is you can replace all of those with a single check valve
    - Clint
    Dec 06 2007
    ^^please explain.
    -Kirk
    Buncha motorcycles
    Memphis, TN
    indeed, i was about to order some of those UPS plastic check valves and some silicone line
    Feb 17 2005
    Sarasota, FL
    Not that you need to see my engine bay again but count how many check valves I have ...
    If you didnt figure it out, I have NONE!
    Dec 06 2007
    ^^so how to bypass? any way to bypass the PCV?
    what can i remove without getting codes??
    -Kirk
    Feb 17 2005
    Sarasota, FL
    Nothing in the PCV system is connected to the ECU. Remove all the crank vent shit under the intake manifold as well as its connection to the intake manifold. Run a 1" hose from the crank breather (on top of the oil filter housing) up to the valve cover breather, T it to another 1" line which you can either dump under the car (which I do) or connect it to a catch can, then a line from the catch can to the TIP, your choice. I prefer to have absolutely zero oil crap going into my motor so I just have the 1" stainless hose you see in my pic running down below to tranny to vent any excess pressure or oil residue
    Feb 17 2005
    Sarasota, FL
    Without triggering a CEL, you can remove pretty everything I have except SAI. EVAP will not trigger a CEL as long as the solenoid is plugged in (the one thats on the back of the intake box from the factory). You can remove the N249 and N112 vac lines as long as you keep the solenoids plugged in (or put resistors in there place)
    Dec 06 2007
    thanx
    -Kirk
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    I had to replace (#1 in pic at top) one last week. I was about to take off on a road trip so no time to wait for shipping. It ended up costing me $43 at the dealer after tax. ugh.
    I don't know about throwing codes with removal, but I didn't have any cel's with my busted one. they are simply "one-way" valves. They do something, but likely just a passive safety system. If I had known at the time that they were just one way valves, I would have just glued up the one I had. Some high temp silicon would do the job just fine.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Buncha motorcycles
    Memphis, TN
    hmm i might take all mine out instead of replacing them
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Did you have some sort of drawing you went off of to determine which ones could be removed and how to hook up just regular lines? Why wouldn't you need at least just 1 check valve? Don't they serve a purpose or are they all useless?
    Can you come up with more detailed pics of areas that have stoppers and where particular lines go? This could be a great how to for most of us to learn from for first timers like myself with turbo'd cars.
    Buncha motorcycles
    Memphis, TN
    shawn, so you are saying i can take out all my check valves and just use some 1" silicone lines? what do you do with the one by the airbox? block it off?
    Feb 17 2005
    Sarasota, FL
    The hard plastic line connection to the airbox is the feed for the SAI pump. If you remove that or the SAi system, you will get a CEL.
    The only thing that needs the 1" hose is the crank and valve cover breather, T those two together, then dump them under the car or into a catch can your choice. The suction pump can be removed, that gets rid of 3 check valves. You will then need to connect the brake booster directly to the intake manifold. The other 3 check valves that are small (black/grey) are for EVAP, one on top of the air box and two over under the intake manifold. That can removed if you wish, no CEL. You will need to keep the solenoid connected on the pass side of the car to the line coming from the fuel tank. The solenoid still needs to be able to purge vapor pressure build up from the tank. Everything after that solenoid on the passenger side can be removed, its connections to the TIP and to the intake manifold. The two check valves on the driver side are the feed lines for the charcoal canister in the drivers side wheel well. There are two quick disconnects for those lines right under the power steering fluid resevoir. Just disconnect them there unless you want to pull the canister and everything from the fenderwell. The only things remaining after that are the vac line feeds for the N112 and N249. N112 is for SAI, it needs to remain if your keeping SAI. N249 is how the ECU electronically controls the DV. It can be removed, just connect the DV directly to the intake manifold which yields quicker DV response from boost/vac pressure, NOT the ECU!
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    Hey would you wanna do a write up with pictures for all us guys that are still running non BT on how to remove all that crap and how to route the new hoses. That would be very appreciated.
    Since you have a shop to run and all to make it worth your time a little more i can throw in $5 bux for this and Im sure a bunch of other people would have no problem donating $5 bux as well for your time on this.
    $5 dollars on your makeing the writeup for how to reroute all this stuff is still cheaper then buying one of those stupid checkvalves let alone 5
    Just let me know of your paypal and if you wanna do this and ill send 5 bux over.
    Thanks
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Alex@GMS View Post
    Thanks
    Ive offered to do it before, I just need a car to do it on. The stuff in my car is long gone so all I can do with it is take "after" pics
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    My check valve above the airbox was damaged just the same as the one in the picture. Anyone know what this damage comes from? I was able to buy it from the audi dealer in town for about $20. No big deal.
    oh yeah, and there are also two different check valves for the '03 1.8t that look almost identical and don't expect the parts guy at the dealership to know which one your car should have (or if it even matters).
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    +1 For the GI Bling Dawgg Shawn.
    Writeup on this matter will be greatly appreciated.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jan 24 2008
    NorCal BayArea
    No one around you has a stock one? lol WTF. i would have you do it to my car. Wanna fly out to Cali?
    Feb 17 2005
    Sarasota, FL
    Fly me out there and Ill do it for free
    Dec 06 2007
    hell i'll chip in if u wanna do my car too.
    -Kirk
    Feb 17 2005
    Sarasota, FL
    haha I don't want any money guys, I just need a car (and someone to take pics would be helpful) inorder to document. End result one clean engine bay!
    Dec 06 2007
    ^^got the car and the camera man
    -Kirk
    Jan 24 2008
    NorCal BayArea
    Damn it i hate this.
    Can someone in Florida with a Audi B6 1.8T and a DSLR camera please go to 1551 and do this!
    PLEASE!
    Feb 17 2005
    Sarasota, FL
    PLEASE!
    lol its 1552, and I have the SLR
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    I'd fly you here, you'd have to fly back on your own haha
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Feb 19 2007
    Charleston, SC
    Guys I plan on doing this....and I will take pics.
    If I dont mess anything up, I will post a DIY,
    Only one question: Why does the factory have these check valves from the getgo?
    -Sami-
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    My guess would be that more stuff can break = get raped at the dealership for repairs.
    Looking foward to your DIY good luck
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Jan 24 2008
    NorCal BayArea
    sorry im on my iphone and i dont know what happened. lol 1552 is what i thought i typed.
