Results 1 to 15 of 15
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Can you Vag-Com a BMW?
    Just to pull the OBDII codes?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Can you Vag-Com a BMW?
    With different software, yes.
    With VAG-Com. I'm fairly sure the answer is NO.
    -Doug
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    You can use the cable but need different software to read the ECU. There are OBD2 programs for sale but mostly just read fault codes. VAG - Volkswagen Audi Group
    I can give it a try as I usually have a 330i come over on a daily basis.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    It said on the site it might be able to pull codes from different makes.Is there any good BMW software like vag com? I see the carsoft or something like that but you need an expensive cable.
    Veteran Member Four Rings jefferson88's Avatar
    Feb 12 2004
    08 A3 2.0T S-Line
    G-town, Ontario
    Quote Originally Posted by nebone22 View Post
    VAG = Volkswagen Aktiengesellschaft, or "Volkswagen AG"
    Past: 99.5 A4 1.8TQ, 07 A3 2.0T
    Present: 09 A4 Avant 2.0T & 08 A3 2.0T S-Line
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Quote Originally Posted by jefferson88 View Post
    Hah out smarty-pantsed
    you should be able to pull generic obd2 codes using the "obdII scanner" button or whatever it is called on the normal vagcom window. there are certain manufacture specific codes that it may not pull or give you the definition for. but short answer, yes, you should be able to use it to pull obd2 codes. that is the whole point of obd2. so you dont have to have a specific cable/software for each different make.
    edit: http://ross-tech.com/vcds/tour/obd-2.html
    contact via email please.
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Quote Originally Posted by k0mpresd View Post
    Generica OBD-2 features are only available for people with the latest version of VAG-Com (which requires having a genuine Ross-Tech cable); so if you have an eBay cable, you won't be able to scan any other make/model cars since you are stuck on version 409.
    "You know you have a bad idea when Ford guys are making fun of you."
    Veteran Member Three Rings oface's Avatar
    Apr 23 2004
    '99 A4 1.8TQM, '99 RMK 700
    Fairbanks, Alaska
    Maybe, I've pulled a code off of a Ford Escape. then tried it on a jeep and it wouldn't work. I think it might work just to pull the code.
    BetaAlphaTau Member # 51
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    Using the VAG-COM on non VAG vehicles is hit-and-miss.
    I was actually able to get it to work quite well in the "generic" mode for my Volvo in Europe; a pleasant suprise. Could read most info, run logs, etc. Much more than I had expected, and Ross-Tech was suprised since the model year was not required to be fully OBDII.
    In anycase, just plug it in and see what happens.
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    Quote Originally Posted by chris164935 View Post
    my version of 409 has a generic obd2 button. ;)
    Apr 18 2007
    Orange Park, FL
    Really? Because they don't even list that as feature on Ross-Tech's site until like version 50x.
    really. and there is a cracked version of 50x floating around as well. so ebay cables arent limited to 409 either.
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    VAG = Vagina.
    Not a big deal
    Bad Ass I Beam rods are finally here. Join the Brute Revolution
    My Car is for sale, click here:http://www.audizine.com/classifieds/...?product=39888
    ^ my mind stays in the gutter too. i just do a good job of hiding it. haha.
