Results 1 to 23 of 23
    Registered Member Two Rings HellasA4's Avatar
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    emergency trunk release!?!?!
    ok so i know theres the gas cover emergency release, but after my central locking pump went, my trunk has been stuck in the lock position. i have tried to use the key and follow the owners manual but the trunk still wont unlock. any ideas on how to get it open!? is there an actual and separate trunk release from inside the trunk?
    1999 A4 2.8L 30v Quattro Manual in the werks.....custom centrifugal supercharger kit, RS4/UberHaus styling, custom true dual exhaust...
    one of a kind Audi.
    WTB: OEM facelift shift surround, fog light relay modules for facelift dash conversion... hopefully you guys have this stuff laying around and you want to get rid of it! thanks... PM me...my dash conversion is almost complete!
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: emergency trunk release!?!?!
    Does the key turn fully 90 degrees both ways from center?
    To the left or anti-clockwise unlocks and it should stay unlocked.
    Apr 22 2007
    Riverbank, Ca
    Or turn the key left and push it in will open the trunk and undo the alarm for the trunk, when you close it it will reset the alarm.
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    ahh damn.. i wish it would turn... the key doesnt even turn!!!! u think i should go to the dealer for that? was the key not cut right or not programmed right?
    one of a kind Audi.
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    The lock mechanisms get really corroded up with salt/sand/whatever. Absolutely flood the cylinder with WD40 and work the key around (push it in and out, turn it side to side). It can take quite a while to get everything working smoothly again, you have to be quite forceful with the key to get it moving even.
    Sam
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    ok. thank you sam. i will try that today
    one of a kind Audi.
    May 22 2008
    is full of crap
    sandville
    valet key will go in but not turn. This is the same key that worked before, correct?
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Can you release the trunk from within the car?
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    Quote Originally Posted by MattzWarsteiner View Post
    yes this key worked before
    one of a kind Audi.
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    Quote Originally Posted by Siena View Post
    how do you do this?
    one of a kind Audi.
    Established Member Two Rings isramirez21's Avatar
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    I have the same exact problem! I cant turn the key either.:-(
    Anyone knows what can we do to get the trunk open?
    Thanks
    May 22 2008
    is full of crap
    sandville
    Might have a frozen lock mechanism.
    get inside through the back seats. Take off the fuzzy trim on the underside of the lid at the back and look for the vacuum lock actuator on the passenger side of the latch. Disconnect the rod from the vacuum motor end and pull or push it to unlock. If it wont move the lock mech needs replacing or some serious de-corrosion & grease.
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    ok so using wd-40 in the keyhole didnt work. i am sure this key is not the valet key because it opens the glove box therefore it should open the trunk. the key wont budge. I will attempt to open the trunk from the inside though i have no idea how to remove the trunk liner. any easy way or write up to do this?
    one of a kind Audi.
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Quote Originally Posted by HellasA4 View Post
    I am in the same boat as you man! I cant see any release cable or something like that to open the trunk.:-(
    Anyone plz take a picture where the release cable is!
    Thank you
    Aug 02 2008
    audi a4 2.8 1996
    IL USA
    Any life saver PLEASE!!!
    Dec 12 2006
    99 A4 2.8L QM
    Chicago
    bump anyone do it already and have or know of a write up for it?!?!?!
    one of a kind Audi.
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Try some PB blaster. WD40 is just about worthless.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    May 22 2008
    is full of crap
    sandville
    To remove the liner take off the triangle and holder first. Two bolts and two clips underneath. The rest of the liner should just pull loose at the hold-down clips. The lock mechanism is right below the button/keyhole.
    I'll try to get a picture of mine up tomorrow.
    EDIT:
    There are NO hold-down clips. Philips screws at the edge nearest rear window and bottom of lid hold liner on.
    Jul 24 2008
    Los Angeles, CA
    I too faced this problem of standing in front of my trunk trying to get it opened. I put the key in turned in all sorts of ways and pulled it out numerous times. I got so frustrated I also looked for a release cable from inside the cabin but to no avail. I even folded down the back seats and crawled through the back to see if I can open the trunk from the inside like some cars have if you put someone back there.
    It turned out that simply I didn't know how to work the trunk lock. I still don't know how it works but after I got it open, I knew it was right and from then on, I only unlocked the trunk using the remote and will never put a key in the trunk keyhole again.
    May 22 2008
    is full of crap
    sandville
    OK you guys, I looked close at my liner. If you can get this off, you can see the mechanism to unlock it.
    After you take off the triangle and holder, there are also some hard to see philips-head screws around the back and bottom edge to remove.
    There are no clips on my car < sorry about the misinformation on that part.
    Please dont tell me somebody muscled the thing off on my bad.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    nice 8 year thread bump. would of been better to make a new thread.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Nov 07 2010
    South of Heaven
    Quote Originally Posted by realmexy View Post
    Does all 1998 - 2004 audis have use remote trunk release button?
    In North America the B5 series A4 (1996 - 2001) never had a remote trunk release (key fob or switch inside the car) and would only open by using the external lock/button. I would image other countries are like this as well.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Established Member Two Rings jsbs1991's Avatar
    May 19 2014
    cbr 600f3
    Snellville GA
    I did this like four months ago. You will need to pull the liner off but what like mattz said there are also screws that have felt on them to make them blend in with the liner that need to be taken off also. When.I did mine I put a hole through the liner and made an emergency release. But I also but a pump off eBay that works great.
