Results 1 to 26 of 26
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    OH NO!!!! Blown head gasket
    I was just told that I have a blown head gasket, I knew this would happen.
    114000 miles what do I do now? Is it worth fixing?
    How much is it going to cost me?
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: OH NO!!!! Blown head gasket
    diy = $300-400
    shop = $1500?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    DIY is not that bad for someone who hasnt done any major work before. There is a DIY on here you can search by "Rosati" he did head removal thread. all you gotta buy is new head bolts ~$60, and new head gasket ~$40. do the math.
    plus you have us if you have any questions. i would do it for you but i am all the way on the east coast.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    May 18 2008
    SOOOOOO Cal
    OK I'll fly you over here.
    Not I'm just joking
    But hey guys thanks for the response, looks like my warranty might cover it,
    not really sure yet.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    You need a helper or 2 to lift the head as its heavy and en engine hoist helps too.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    May 18 2008
    SOOOOOO Cal
    Well if any body wants to come over and give me a hand with this you are welcome to come by, free beer.
    I'll let you guys know if my warranty covers me or not.
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by nebone22 View Post
    *looks at head sitting behind chair*
    It is not THAT heavy, lets not be ridiculous.
    Its not that hard to remove, you just need a timing belt kit. The entire front needs to come off, and then its like a dozen head studs you need to undo with a special audi tool. I suggest you do this with someone who knows what their doing, last thing you'd need is to fuck up your timing.
    -18 718 GTS
    Jan 21 2006
    6MT BT Avant Ti
    RI
    If you pull it with the turbo, DP, IM, etc its fairly heavy plus u don't want to chip or scrach anything when maneuvering it yourself.
    Sep 14 2006
    Lansing, MI
    the head is not heavy. you can disconnect the turbo to exhaust mani and then the intake mani. lift and walla is out. well not really, timing belt needs to come off.
    yeah, i guess is better if you ahve someone local help you out.
    SOLD
    May 18 2008
    SOOOOOO Cal
    Well looks like the place I took it to is going to work with my warranty to get it fixed.
    They are charging $1,300.
    Not sure if thats reasonable.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Its a solid day's worth of work plus parts (see below).
    8hrs * 100-120/hr = $800-960
    head bolts ($40)
    head gasket
    valve cover gasket
    intake mani gasket
    exhaust mani gasket (ie: complete gasket set $99)
    You're getting close to $1300. Sounds somewhat reasonable.
    EDIT: You're at 114k. Might want to start thinking about a Timing Belt kit. It'll be easier to throw that in there while you're replacing the head gasket. Should only be the additional cost for parts. (I, personally, book-keep a TB interval of 60k)
    -Doug
    May 18 2008
    SOOOOOO Cal
    I'm going to ask them to do that and a new snub mount while they are in there.
    Timing belt is a good idea, I don't need any more problems.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I'm scrawny and I did it myself with the manifold attached. It's maybe 60-80 pounds so it isn't light but it isn't impossible. Disconnect everything, lay a few rags or old towels on the workbench, and in one smooth motion pull it off and lay it back down. Lay it upside down, on it's side, or up on a couple books so you don't trash any valves.
    You'll need:
    - full timing belt kit
    - oil change stuff
    - gallon jug of coolant
    - head bolt tool
    - replacement head bolts
    - valve cover gasket, head gasket
    You might also need to have the head machined for flatness. To check this you'll need to clean up the head surface and lay a real straight edge on it. Then take a .001 or .002" feeler gauge and see if it slides under it anywhere. You could also shine a light from the backside to check for gaps.
    Jim
    I Do Werk.
    May 18 2008
    SOOOOOO Cal
    Well I'm not saying I can't do it but I have very little experience to do it my self.
    I'm not saying I don't DIY but with something like this I really don't know, not to mention I have classes starting soon so I would like to get it done as soon as possible.
    Plus this place seems to do good work, I just really hope I am covered for this other wise I'm paying out of pocket.
    If not well looks like I'll do it my self and use the jeep or something the bus I dont know.
    Like I said if any body is near by and wants to spend a weekend fixing some other duded car hey your welcome to help me out.
    Mar 09 2004
    nw michigan.
    I would do it but you're not exactly on my way home.
    Jim
    I Do Werk.
    May 18 2008
    SOOOOOO Cal
    Well, you could stop buy it would just be a little out of your way.
    Haha
    May 18 2008
    SOOOOOO Cal
    ok well insurance wont cover me, that sucks. So I guess I'm paying out of pocket $1200+
    Not sure if thats a good price but it needs to get done. I have school coming up and I still have to pay for classes. This really sucks, not to mention I have surgery soon and my insurance wont cover me unless I'm a full time student, but I still have to work so that means night classes for me. Wow what a predicament this really sucks and this better fix my over heating problem.
    This really sucks!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by kampfer View Post
    Add a new thermostat to your TB kit for good measure and to rule out the T-stat possibly being your over-heating problem.
    -Doug
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Hey bud, cheer up, it's not that bad.
    Of course it's worth fixing, at 114,000 miles.
    My B5's done 213,000 miles, and I'd fix her, even with twice her current mileage, and the engine exploded!
    Jan 21 2006
    6MT BT Avant Ti
    RI
    So they definitely confirmed that the head gasket is bad? Maybe you can save it with a new thermostat?
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Quote Originally Posted by Siena View Post
    i totally agree on this one
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    May 18 2008
    SOOOOOO Cal
    No, I did the Tstat and the coolant sensor flushed the radiator water pump seemed to be working. Then I took it to the mechanic and he told me I had some torn up pipes and the head gasket was busted. So now I'm paying total including all I have done to stop her from over heating about $1700.
    Then I still need to pay for college which is starting soon.
    But I guess it could be worse...
    I could be dead.
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Seems kind of odd to have a blown head gasket on a stock motor and no other signs of a blown head gasket other than the engine overheats. Usually, there is coolant and/or oil leaking into other parts of the engine when a head gasket blows and causes overheating... How did the mechanic determine the head gasket was toast? Did he physically remove the head and see the carnage or did he do a compression test?
    Did you replace the water pump? The impellar might have broken off. It's a very common problem which causes overheating.
    I have also seem people have overheating problems because the coolant flange on the back of the head starts to leak...
    "You know you have a bad idea when Ford guys are making fun of you."
    May 18 2008
    SOOOOOO Cal
    well as far as I understand he did some chemical test in the coolant tank. by dropping some sort of chemical into the tank he was able to determine that there was oil in it.
    As for leaking there was oil all over my garage from at least two places. one is the oil pan, I cracked that the other I don't know but there are two pools of oil.
    Apr 18 2007
    Orange Park, FL
    Oil in the coolant could also be the result of a bad oil cooler... Not to mention that if the head gasket were bad enough to allow oil into the coolant, I'm pretty sure you would be burning oil as well. I've also read that it's a bad idea to mix other chemicals with the G12 coolant... Such as water wetter looking like oil when it mixes with G12,
    May 18 2008
    SOOOOOO Cal
    well my bro told me that as i was going to the mechanics( he followed me) I was spewing WHITE smoke for a while then it stopped, he tried to convince me that it was probably because of cold start but I know better I mean come on cold start. anyways they are taking my engine apart and cleaning it out and all that good stuff so if it keeps over heating well i guess i'll do my best to get the mechanics to pay for the further repairs on the count that they would have charged me for something that probably wasn't even broken. I get it back tuesday so we will see.
    I'll keep you guys posted
