Results 1 to 10 of 10
    May 02 2008
    Painting car one panel at a time?
    I have been thinking of painting my car DIY for a while now. The thing is I do not have the time or the place to prep and paint the entire car at once. Just preparing the car for paint will take me a few weeks on and off.
    The question is, how would it work out to paint one panel at a time? Hood, fender, roof etc. Completing one panel per weekend. Assuming all the paint is mixed up ahead of time and the final sand and polish is done at the end.
    Anyone have any experience or comments?
    Thanks
    Joe
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Painting car one panel at a time?
    It would be fine. I dont see how it would be bad in any way.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 27 2005
    North Wales, PA
    humidity, temps, etc will all play a small part in the color matching
    Apr 22 2007
    Riverbank, Ca
    More likely than not, all the pannels will be a slightly different color..
    Your better off doing all the prep work through your various weekends per pannel, priming the pannel with a sealer when your done, and the final weekend after all the pannels are done you do your final sand, throw the next primer down one day, and shoot the whole car the final day.
    This will make your job a whole hell of a lot easier..
    GL
    Oct 06 2004
    Minnesota
    Taping off and cleaning your paint gun would be a PITA 9 times
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Forget it if your car has metallic paint. . .
    Solid colors would give you the best results....even then I would take the paint to its source and have them shake it for you each time.
    And yeah, like A4Rob & Andy sayz, prep and un-prep + cleanup would be a giant pain.
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    If a metallic, pearl or mica-based paint, forget about painting at those different times.
    You won't match the paint, even if all pre-mixed.
    The ambient temperature, and angle of spraying will affect the final shade you'll end up with.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yeah i would recommend doin all the prep first since thats what takes the most time. You may be driving around with a car that looks flat and dull for a while but its definitely worth it in the end. Then leave the paintwork so you can do it all at once. Taping and covering is what makes it such a huge pain in the arse.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    May 02 2008
    Thanks for the replies. Sounds like a better plan to do all the prep work little by little then paint all at once maybe on a long weekend. Had not considered cleanup 9X, definitely a real pain. Will just have to drive with a patch primed car for a while.
    Joe
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    At least paint it in sections. You could do the entire front clip - fenders, hood, bumper - over a weekend. Then do the doors and roof the next weekend. Then finally the rear quarters, trunk, and bumper. Staging like this will also mean that the aftercare will also be staged so you won't have to do everything at once until you claybar and wax it a couple months later.
    I had my entire front clip done and it wasn't bad at all. Before removing each panel drill some 1/8" holes near the mounting bolts. These make reinstalling and lining up much quicker and helps prevent panel damage. You can prep and primer a set of panels over a weekend, reinstall, and use the block and longboard on the panels during the week. Friday after work you pull the panels back off, make sure they are perfect and clean, and then lay down the base.
    Jim
    I Do Werk.
