Results 1 to 14 of 14
    May 12 2007
    San Diego
    Rotors (dimpled, slotted) Causing Noise?
    Hi guys I've got a question, have any of you ever heard of dimpled and slotted rotors causing noise when you drive and/or brake?
    I recently purchased a set of dimpled and slotted rotors and pads and had them installed (along with new suspension) and now when I drive I can hear this constant clicking sound (almost like a cricket) coming from all four wheels. I can only hear it when I have the windows down and am driving near something so the sound reflects back. The clicking sound increases when I increase speed and really increases when I brake.
    I've taken the car back to the shop where I got everything installed and they've disassembled and reassembled the brakes, suspension and even the USP bumper I just had put on but nothing fixed it. They think it might be sound coming from the dimples on the rotors.
    Has anyone ever come across something like this? The rotors were made to OEM spec for a B6 A4 and unfortunately I can't remember the brand of pads. They weren't high performance, just something with low brake dust.
    Any help would be much appreciated, I'd really rather not have to buy a whole new set of rotors and get them reinstalled. Especially not when I don't even know if that's the real problem.
    Thanks!!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Rotors (dimpled, slotted) Causing Noise?
    Those are Adam's rotors right? If so it is mentioned in his thread as normal and I believe it will dissipate as the rotors wear... I installed my slotted/dimpled on my rears but don't hear this noise... all though I think I may have installed them opposite of the normal way.. which has no bearing since the rears are flat and the fronts aren't directionally vented..I hope that helps
    May 12 2007
    San Diego
    Yea, they are Adam's rotors. Thanks for the heads up. I just went back to the thread and he does indeed mention his rotors making a soft clicking/popping sounds, which is exactly what mine are making. Although I couldn't find where he said they will dissipate as the rotors wear. I sure hope they do. Adam refers to the sound as almost pleasant but it's honestly pretty annoying to me. I don't want people hearing my car clicking every time I drive by.
    Anyway, thanks for pointing me in the right direction. I wonder if anyone else has had this happen and if so, how long the sound will keep happening.
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Quote Originally Posted by pondside36 View Post
    What he said!
    PS - it's brake NOT break!
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    I get the same thing with my car, i dont know what rotots im running because they came with the car. its sure annyoing, maybe ill do my brakes soon.
    May 12 2007
    San Diego
    Quote Originally Posted by Gondi Stylez View Post
    What he said!
    Heh, whoops
    Dec 19 2007
    York, PA
    thats a normal characteristic of slotted/dimpled/drilled rotors...they make a clicking sound while braking. Its the pad sliding over the open areas
    Established Member Two Rings nezach's Avatar
    Nov 03 2007
    02 A4 3.0 Quattro 6spd
    Chicago, IL
    I have the same sound on my car. Put Adam's rotors (dimpled/slotted) on my car last week
    May 20 2008
    Salem, Oregon
    I have them too and I hate the sound. I wonder if it is the dimples or the slots making the noise. Sucks paying $525 (B6 S4 fronts) and considering going back to stock...
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    what pads are you guys running.. I went with Hawk Ceramics.. and I don't appear to be getting the noise.
    Dec 19 2007
    York, PA
    its not really that annoying...turn the music up for god sakes
    May 12 2007
    San Diego
    Oh I can't hear them inside the car, music or not. I can only hear them when I have the windows down and am passing something which the sound can reflect off of. And with climate control there's almost never a reason to have the windows down.
    I guess I just didn't realize that dimpled rotors did that. I don't particularly like the fact that my car is now constantly making clicking sounds is all. Whether I can hear it or not, I know it's there. But I certainly don't think it's worth it to buy a whole new set of rotors or go back to stock. The rotors work perfectly fine. It's probably just a preference thing and I probably should have done a little more research before getting the dimpled ones.
    It's not all that big of a deal though, I was just worried when I first heard it that it might an issue with the suspension install or something like that.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    turn up the music! that sound is normal!
    at least you know your brakes are functionning with the sound. don't worry
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    I get the sound too and it's annoying as hell. I personally like to have my windows down but luckily I listen to my music pretty loud so it helps, but when I'm in the mood for quiet that annoys me. I doubt the sound will ever go away and it does suck. I have factory blanks (B6 S4) that were machined with slots and dimples and they make noise.
