Results 1 to 7 of 7
    Registered Member Two Rings kingdon's Avatar
    Jul 07 2007
    new york
    Do I need a camber Kit when you lower the car
    I lowered my car with H&R COILOVERS and I was told by the wheel alignment place that I needed a camber kit for my car I drop my car a finger and a half in front and two finger in back betweeen wheel and fender. My front tires are eating up on the inside. Drop me a link thanks.My B-5 used the next on the right hand side to move to the next pic.
    http://s308.photobucket.com/albums/k...afilter=images
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    Re: Do I need a camber Kit when you lower the car
    you don't need one but i think there's a way to tweak the camber a bit on our cars. or maybe it was a diff suspension setting. there's a diy on doing an alignment on here though.
    here's a thought though http://www.k-mac.com/
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    You can't adjust camber on the B5 but you can even it out so its equal on both sides (meaning it won't be too negative on one side compared to the other side). That is done by shifting the subframe.
    Alignment Information
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Something about dropping the subframe I think but I don't think it really works. I think maybe because both sides are linked it doesn't do anything.. only changes it relative to the other? You don't 'have' to get a camber kit, but there isn't a way of changing the camber stock. Get some adjustable upper control arms if you are worried about your tires
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Purems is going to be coming out with some adjustable control arms which allow you to dial in your camber.
    Pictured are some older prototype pieces.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    You dont NEED it, but if oyu want perfect camber, then I suggest getting a camber kit. With our cars, there is no exact camber adjustment spot, so in order to do that, you must adjust the subframe which can only even it out.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Don't bother with a camber kit. If your car is low enough to need one then it is too low.
    The inner tire wear is from an incorrect toe setting not from camber alone. If the toe is corrected the tires will stop fighting each other which just scrubs off the rubber.
    Jim
    I Do Werk.
