Results 1 to 34 of 34
    Jan 08 2007
    NEW YORK
    "Bosch F5DPOR Side Fire" HELP
    I was told by several auto parts stores that the popular Bosch F5DPOR Side Fires only fit the Audi models below. Why doesn't the 2000 B5 S4 show up on any parts sites as compatible? How many of you use this plug on your B5 S4?
    #F5DPOR fits the following vehicles:
    AUDI 200 QUATTRO 20-VALVE 1991
    AUDI S4 QUATTRO 1992
    AUDI S4 QUATTRO 2.2 (1993 - 1994)
    AUDI S6 1996
    AUDI S6 AVANT 1996
    AUDI S6 QUATTRO 2.2 1995
    Apr 05 2007
    Re: "Bosch F5DPOR Side Fire" HELP
    they're just not listed as an 'oem equivalent' replacement... many people run them and they work great. if you are stock though, just run stock plugs (at least stock heat range).
    Feb 17 2004
    Sterling, VA
    The heat range is 2 ranges colder and thus it doesn't match the heat range that a stock S4 would use. Since a Stage 3 car isn't stock, stock heat range isn't a requirement.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Are they ok to run on STG 2?
    Feb 17 2004
    Sterling, VA
    I suppose you could but, the added heat and cylinder pressures won't be there to make them as necessary as a Stage 3 car.
    Brett - Moderator
    Issue?: email me.
    Apr 13 2007
    Frisco, Texas
    I just got some was going to install over the weekend.. should i just go with OEM instead? I was told that these are that much better even for STG 2
    Apr 13 2008
    Tennessee
    Quote Originally Posted by Daft View Post
    probably more like just one heat range colder
    Jan 08 2007
    NEW YORK
    My S4 is Giac Chipped. Does that make my car a stage 2? Is it still worth using the side fires?
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    Quote Originally Posted by Venator1 View Post
    Yes, it is Stage 2, and no, the side fire Bosch's are not a benefit to you. Even at Stage 3 +, $2.xx per plug Autolites from NAPA work fine for me. I use the F5DPOR's only in warm weather, and only because I paid $90 for the set...
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by quickaudi View Post
    The NGK and Bosch heat ranges are not lined up in numerical value.
    The stock NGK plug in the 2.7T "PFR6Q" is a 6 heat range in NGK's numbering system.
    If you were to look up a stock equivalent plug in Bosch's part numbers, it would be a "7" since Bosch uses a different scale.
    The Bosch F5DP0R is a "5" heat range and thus it is 2 heat ranges lower than stock.
    You would also be running 2 heat ranges lower by using the NGK BKR8E-IX iridium plugs.
    Brett - Moderator
    Issue?: email me.
    Jun 14 2007
    2000 S4
    Connecticut
    Stage 2 = Tuning + Catback exhaust...
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    You're stage 1, and no, the F5DPORs will not be a benefit for you.
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    Quote Originally Posted by SLC_S4 View Post
    Well, I learned something just now--I thought that Stage 1 was getting a B5 S4 to start and run in a semi-reliable fashion...
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by joules View Post
    No, that's "Step 1". "Step 2" is realizing the you have a problem...
    I'm running the side-fires now to see if they help my misfires, but I think I have bigger issues Hopefully if I get those resolved I can see if they help any.
    But I think that running this car hard (which I have been known to do) in this SFL summer heat, I would probably see some sort of benefit over say someone up north... IDK, that's just how I justified the price to myself anyways (haven't gotten past "Step 2" yet )
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jan 08 2007
    NEW YORK
    I can get the F5DPOR for $13 each. Still cheaper then the NGK OEM. You think it is worth it now or is it basically the same shit for a Stage 1+ and I will feel no difference?
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    Im also in need to buy plugs and i was told by a friend that i should get the side fires..will there be a problem??
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    F5DP0R can be put into many applications but sometimes not recommended for use due to its colder heat range.
    it works on Audi's 3.0 engines(AVK) as well
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    May 03 2007
    german
    heaven/hell
    Veteran Member Four Rings YZracer's Avatar
    Sep 20 2005
    Scottsdale, AZ
    I run the Bosch platinum sidefires from JHM. They run great.
    CURRENT TOY
    2013 TT-RS Ibis White - Stock for now......
    Sold:
    2010 B8 S4 Phantom Black: Stasis Touring Suspension Kit, APR Pulley, APR 93 Octane Pulley Tune, APR Full Carbonio Intake
    Parted and Torn down:
    2000 Black 6spd S4
    SSP Tuned PJK04 Stage 3
    Burned:
    2000 S4 Tiptronic (B5)
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    Bosch side fires may have no "benefit" to a non Stg 3 car, but would they have a consequence to a Stg 1 or Stg 2 car?
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    i dont use bosch plugs.. but easy reference for ngk:
    stock- bk6reix
    chipped-bk6reix or bk7reix
    stage 3-bk7reix or bk8reix
    these are all iridium plugs. copper or plat can be used too but the heat ranges should stay 6 for stock, 6 or 7 for chipped, and 7 or 8 for stage 3
    i use the 8 heat range plugs on my car but i had to close the gap from .28 to .25 or it would misfire too much. but up top these plugs really perform in hot temp climate
    Account Terminated Four Rings
    Feb 05 2007
    In your fridge
    Stage >3 = stock plugs
    Stage <3 = side fires
    Why spend over $80 on plugs if you're not going to benefit from them?
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Is there anyone who runs these in a Stage2+ car? I need plugs in a couple thousand miles and am not sure what to get.
    Aug 03 2008
    Silver S4
    what other plugs can be considered to be good on stock and stage 2 S4's?
    please mention name and part or model number
    Jun 24 2008
    Quote Originally Posted by Bart View Post
    If you read that normally from left to right it says: "Stage [greater than 3] equals stock plugs, Stage [less than 3] equals side fires."
    I don't think that's what you meant.
    /end being a jackass.
    Veteran Member Two Rings
    Oct 08 2004
    San Diego CA
    Quote Originally Posted by GunSupplier View Post
    Gun Supplier is exactly right about the above info.
    On another note, you will be perfectly fine using those plugs, they will work like a charm, stock or not.
    Feb 02 2009
    Cars other people killed
    capital city wastes
    with the side fires you will have overall better combustion efficiency. with obd2 the computer will adjust the timing and feuling because of this. also its harder to blow out the flame with a side fire plug than a regular style and indexing the plug is less-nessesary. the full benifits wont be realized until you create a really turbulent combustion chamber, hence why theyre used with bigger turbo cars with huge injectors. there will be overall benifits but you wont notice them unless you did back to back comparisons on two cars for many miles and then looked at the overall condition of the combustion chamber and other factors and somehow factored out all of the numerous problems these cars will go through during that time.
    aside from bigger turbos you can also get colder plugs if you upgrade the ignition system with a higher output, or with water injection. the ign system increases the heat on the plug so going colder will prolong their life and water injection is similar to advancing the timing alot which in turn induces more wear on the plug.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    LOL WHAT^?
    stop speculating.. please.
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    ding ding what he said
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Quote Originally Posted by Boosted-S4 View Post
    No Probems. I have been running them for the past 6k miles on my stage 1 Giac chipped s4.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Three Rings OneSickSedan's Avatar
    Feb 23 2005
    2001.5 Audi S4 6-Speed WMS Stage 3-
    Southern California
    I have GIAC and piggies and am running F5DPOR's with no problems.
    2001.5 6-Speed Santorin Blue S4 (WMS Stage 3-,mod list in my profile)
    "Who, after all, speaks today of the annihilation of the Armenians?" - Adolph Htiler
    Let's end the cycle of genocide by recognizing the Armenian Genocide and end the Darfur Genocide.
    "If you're not first, you're last." -Ricky Bobby from Taladega Nights
    "LIVESTRONG" - Lance Armstrong
    Aug 30 2007
    nyc
    I ran them felt fine when i was stage 2 ....... do it so u wont have to later bosch sidefires............ftw
    c5 A6 tip
    this n that
    Apr 13 2008
    Tennessee
    quoted to prove mods can be wrong
    seriously? search this http://www.clubplug.net/bosch_ngk.html
    or this http://www.spark-plugs.co.uk/pages/t...chd6b-w4e2.htm
    find F5DPOR or F5DP0R
    note that it crosses to NGK's PFR7B, which is only 1 range colder than stock (stock is PFR6Q)
    FYI, there is no Bosch stock equivalent for a 2.7t plug - they don't make one, and I can back that up with several phone calls to several Bosch reps. NGK makes the only stock plug for our cars.
    At any rate, both start at "6", but NGK goes up and Bosch goes down for heat ranges.
    therefore, the f5DP0r plugs are only 1 range colder than stock plugs.
    Senior Member Three Rings drewski's Avatar
    Mar 03 2004
    Audi S4 Avant
    SF Bay Area
    *golf clap*
    now: Widebody 01.5 S4 Avant - Pearl/Onyx - one or two mods . . .
    then: 98.5 A4 2.8 QMS - Pearl/Ecru
    For Sale - email me if interested:
    Startup Racing Penske Competition (single adjustable) Suspension. No springs
    S4 intercoolers
    B5 A4/S4 rear doors, currently Pearl White
    S4 K03 turbos. 62k miles. not blown
    S4 3-spoke steering wheel w/ airbag
