Results 1 to 16 of 16
    Registered Member Two Rings CHRIS-NZ's Avatar
    Jan 19 2008
    New Zealand
    Passat Coilovers
    Hey all...
    A simple question will passat coilovers from a b5/b5.5 fit my a4 b5?
    They look really similar to my current shocks...
    ive tried searching this forum and googling everything i can think of...
    Any help would be great...
    Chris
    --- Audi A4 ---
    19" ASA JH9's, Supersport Shocks Eibach Springs, Tints, Remus Exhaust.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Passat Coilovers
    I might think if your car is FWD it will work.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    make sure you have the same engines. passats are lighter than audis so the spring rate may not be stiff enough. it should bolt on fine though
    Jan 19 2008
    New Zealand
    Yes i am fwd. A lesser spring rate means what will happen?
    --- Audi A4 ---
    Dec 14 2006
    Halifax, NS, Canada
    are they any cheaper?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jan 19 2008
    New Zealand
    Not sure, they are not new - coming from a guy not to far away from me so thought i would make the upgrade to get rid of that ugly gap between my front fender and tire
    --- Audi A4 ---
    Jul 06 2008
    2001 Audi A4 1.8T
    Quote Originally Posted by CHRIS-NZ View Post
    that means the spring will be softer.
    Jun 04 2007
    Austin/DFW, TX
    The spring rate should be about the same.
    My 5-Speed Swap DIY
    - B6 USP
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    they're coilovers..so it doesn't really matter if the spring rates are a lil off, you can just adjust the height
    TEAM|AXION
    Jan 19 2008
    New Zealand
    So go for them we all reckon?
    --- Audi A4 ---
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Quote Originally Posted by hiwords1 View Post
    You've got things the wrong way round.
    The Passat B5 / B5.5 is a lot heavier than an A4, it's almost as heavier as an A6.
    The springs will raise an A4, unless they're adjustable, I haven't read that far.
    Jan 09 2008
    United Kingdom
    Quote Originally Posted by biketsai View Post
    Spring rates are higher.
    Yes, they may be adjustable, but they'll be very stiff on the lighter A4, will make the car very skittish over uneven surfaces.
    Jan 19 2008
    New Zealand
    Quote Originally Posted by Siena View Post
    Therefore giving me poorer handling than my lowering springs and shortened shocks?
    --- Audi A4 ---
    Jan 09 2008
    United Kingdom
    Exactly, Chris.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Just a curiosity question, will passat 4 motion coilovers fit a quattro and visa versa?
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Quote Originally Posted by big_greasy_taco View Post
    Yes. But most 4 motion Passats had 2.8's with Auto's. 1.8T 5speed 4 Motion Passats are very rare. One year only I think.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
