Results 1 to 11 of 11
    Dec 08 2006
    Newark, Delaware
    OEM tire pressure ?
    i just got a 06 S4 aniv. ed'n. I looked inside the door to see the rec'd tire pressure and was shocked to see it said 44 psi on the door sticker.
    I've never run tires this high.
    It still has the original tires.
    Do you suggest i run them at 44 psi?
    thanks for your opinions
    Bob
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: OEM tire pressure ?
    Recommended pressure should be on the tires. 35-40 sounds right.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    Yup, my tech told me to run 44 psi.
    B7 RS4 mugello
    B7 S4 moro
    Q5 meteor
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    on my B6 it says 35 REAR, 39 FRONT
    I run the same on my OZ SL's as well
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    For gas mileage 44 may be best ... I ran my 18's around 38 lbs.
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Three Rings Meradin's Avatar
    Jul 14 2005
    White Plains, NY
    B7 S4 is 44f/32r which if you look at the weight distribution of the car is a close match. I personally run my fronts at 38 with my 19's as I feel I get better turn in response. The factory specs are a guideline and the psi can be adjusted to affect handling and fuel economy.
    2012 S4 Prestige S-Tronic
    Phantom Black /w Titanium Package
    Modded...
    Oct 11 2007
    Suburbia
    I tend to run about 41 up front and 38-39 in the rear. If you look at the door panel, it will give you a guideline.
    Feb 13 2008
    2006 S4
    San Jose, CA
    From what I've been told at Audi club events, the suggested tire pressures ensure the car will understeer. I run my fronts at 38 and my rears at 41.
    Jul 22 2008
    Washington D.C.
    I just got a 2008 S4 and the service guy told me to go by the manual not the inside of the door.. so not sure what that means to you guys as I am yet to read the manual or check tire pressures.. I'm still getting over the fact I just bought one of my dream cars :)
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Quote Originally Posted by biffturkle View Post
    That only makes your car understeer more than with the factory recommended 44F/44R. If you want to dial out understeer, you should go higher in the front...try 41F/38R.
    Registered Member Two Rings limeylee's Avatar
    May 29 2008
    I assume these are cold numbers.
    Does ambient temp play into it, i.e. CA Vs Canada.
    How does wheel size/tire type effect numbers?
    I am running 39F/36R on 18's
