Results 1 to 18 of 18
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    How do you program b6 Keyfob and immo?
    So I completely trashed one of the switchblade keys of my a4 trying to do the b7 housing switch.. badd idea .... So I bought another b6 key from eBay, and I took my key blade and stuck it into it. So now all I need for this b6 key to work is to program the LOCK/UN/TRUNK/PANIC btns, and program the immo so it doesn't say "SAFE".. My questions to you AZ'ers
    1.) How do you program the Remote part of the key (LOCK/UN/TRUNK/PANIC)?
    2.) How do you from the the Immo chip... It is a new IMMO chip that the eBay company put in, so it has never been programmed to any other car.
    Thanks!!
    Link to the key I bought:
    http://cgi.ebay.com/ebaymotors/ws/eB...m=370064506041
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Feb 27 2008
    Re: How do you program b6 Keyfob and immo?
    BUMP....anyone know??
    Registered Member Two Rings TripnA4's Avatar
    May 12 2008
    Dallas, TX
    I dont think you can do this on your own or with a VGA COM.
    I had to take it to the dealer. They charged me 70 bucks...this included cutting the key, programming immobilizer to start your car and programming the remote to Lock/Unlock.
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Yeah, I think the dealer needs to get involved. Cha-ching!
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Programming can be done with VAG-COM, but the immobilizer must be done at an Audi dealer (VW dealers told me they couldn't do it anymore on the B6 and newer models)
    http://www.ross-tech.com/vag-com/car...-matching.html
    http://www.ross-tech.com/vag-com/cars/immobilizer.html
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I am on the same boat, my dealer has can't do attitude, so I'm stuck with nothing.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    To program the remote functions on a new key, get in your car with the car off and the driver side window rolled down.
    insert the new key into the ignition
    insert your vallet key in the driver side door lock (outside the car)
    turn the vallet key towards lock and hold it there
    while it is held towards lock, press the unlock button on your new remote for
    2 seconds.
    let go
    press it again for 2 seconds
    let go and you should hear an alarm honk or something like that.
    This is from memory so it may not be right.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Quote Originally Posted by 400HPA4 View Post
    2 seconds.
    This will roll the window up if the ignition is not turned to the "ON" position.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    not to thread jack but I just purchased a b7 key fob to do the conversion, I thought you can do the whole thing with just swaping the chip and vag com???
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    Quote Originally Posted by SportSter View Post
    Yes, you can. Read my write-up on this. Be careful not to damage your original immo chip when you remove it from the old key fob. A number of people have screwed up their immo chips by breaking them. I've done this several times without issue.
    Aug 26 2005
    Quote Originally Posted by derleicaman View Post
    2nd, converted to the B7 fob no problems.
    Apr 02 2009
    2004.5 A4 1.8T Avant Quattro
    Vancouver, BC
    I can confirm this works! Just have to be a bit quick on the draw pressing the unlock on the new key after turning the "working" key to the locked position in the door...
    2 seconds.
    let go
    Sep 11 2011
    san diego
    THANK YOU 400HPA4!!
    Out of all the different methods this is the only one that works on my car. For those who have the 2005.5 B7 2.0T, this should work for you as well.
    Thanks again, this was driving me nuts!
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    so if I don't have the "valet" key, I can use my "working" keys right? I want to have an extra key coz I only have one.
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Senior Member Three Rings on1wheel01's Avatar
    Mar 03 2012
    mooresville nc
    Older thread but worked well to program a different remote. But once I did it erased all memory from my first remote. And after trying to reprogram the other remote it works but then erases the other's info. I have tried to sync the other and set with different clicks to get different channels. But nada. Any ideas?
    Mar 18 2007
    Ottawa Ontario Canada
    Quote Originally Posted by 500HPS5 View Post
    2 seconds.
    let go
    I can also confirm it works BUT, you MUST HAVE THE KEY TURNED TO THE ON POSITION (don't start the car)... I almost chopped my arm off doing it with the ignition turned to the "OFF" Position.
    **NOTE** The immobilizer is a totally different story. Before even considering using VagCom you will first need the 4 digit Immobilizer PIN which the dealership will NOT give you, even if you have completely paid the car off. I had to get a locksmith to do it for me.. Dealership wanted 200 bucks to program the fob. The locksmith Cost me 60 bucks AND, he gave me the Immobilizer PIN which by all rights belongs to me, not Audi. :)
    Junior Member One Ring randyp's Avatar
    May 26 2015
    Wilmington, DE
    Yep, it worked... did it with the ignition off and the window did START to come up but went back down... I did need to turn the ignition on and off again to complete the programming.
    Aug 19 2013
    minnesota
    Didn't work for me
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
