Results 1 to 13 of 13
    Jul 01 2008
    Minnesota
    CV Joint Sounding Click while going STRAIGHT?
    Im hearing a click at low speeds from the right side. I was trying to correct some other problem by replacing the driver side CV, and right after it sounded like the right side was clicking so i replaced that one, however its still doing it. It will never do it on hard turns, just straight and when it clicks i feel the car shake just a little.. any thoughts?
    Jul 01 2008
    Minnesota
    Re: CV Joint Sounding Click while going STRAIGHT?
    Bump
    Apr 22 2007
    Riverbank, Ca
    check for rocks/ metal objects in the tire, check your brakes make sure you have nothing in the brakes, ect..
    Jack up the car and spin the wheel, still click?
    Jul 01 2008
    Minnesota
    Thanks for the reply, it doesnt do it when ijust turn it by hand. The brakes look good and everything too... idk what else to check.
    Active Member Four Rings
    Dec 11 2006
    Boston
    I had that issue. I had to replace my front axels.
    Stage 3+ RS6's
    Jul 01 2008
    Minnesota
    Yeah thats what i thought, but both of my axles are brand new. I did the driver, then after doing a brake/gas combination at low speeds to try and diagnose some other problem, the right side clicked so i did the right side, but now the right side is still clicking. (unless i happen to hear it wrong and the drivers side i bought was defective but it really sounds like right side to me)
    Jul 01 2008
    Minnesota
    What else is there to check, and btw what specifically should i look for on the caliper?
    Senior Member Two Rings suju82's Avatar
    Jun 02 2007
    1999.5 a4 1.8tq k04+giac, tt dv, bosch 4 bar fpr, DP back 2.5" magnaflow, k&n drop-in.
    Toronto, Canada
    It might be the wheel bearings if axles have already been replaced.
    Jul 01 2008
    Minnesota
    Thats what the guy from carquest was saying, that would be kinda weird since i just replaced that one a year ago but maybe it wasnt put in right.
    Dec 14 2006
    Halifax, NS, Canada
    Did you have the car sittiing on the bearing without the axle in? That will ruin the bearing if you do
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jul 01 2008
    Minnesota
    Nope i had it on the jack the whole time i was working on it.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    im getting this too, im hoping its not an axle, does it kinda feel like the cars almost running over itself when you turn at low speed?
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jul 01 2008
    Minnesota
    Well it never happens to me when im turning, only going straight. And yeah i guess you could describe it that way it just feels like somethings making it jerk just slightly. I was hoping it was the axle haha.. they are pretty easy to replace, if youve done the control arms you could do an axle.
