Results 1 to 10 of 10
    Senior Member Three Rings j2da's Avatar
    Jun 18 2007
    00 1.8tqm
    Massachusetts
    bad control arms = vibration at speed??
    when im on the highway, anywhere around 50-65mph (doesnt vibrate at 80) i feel a slight but very annoying vibration in my feet and steering wheel. before i go and get my tires rebalanced i was wondering if worn control arms could be the problem instead. the two upper driver's side ball joints have some play and allow the wheel to wobble a bit when jacked up.
    let me know what u got to say
    -jay
    | koni coils | 18"rs4 | ebayFMIC | giac k04(gpop) | Forge007 | ecode testpipe | rock chips | negative deviator |
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    Re: bad control arms = vibration at speed??
    im guessing it is unbalanced wheels that are the problem. plus, balancing them will be a cheaper way to check if it is the problem than new control arms.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Jun 18 2007
    00 1.8tqm
    Massachusetts
    i went to get my tires rebalanced, and before they even tried to rebalance they said my problem was bad control arms. im gunna order these and see how it turns out
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Get your alignment checked out...
    (Ka-La-Bre-Ah)
    Jun 18 2007
    00 1.8tqm
    Massachusetts
    alignment is fine, i had it done twice
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Yes, control arms will cause intermittant or constant vibration at those speeds... I drove for about 1 1/2 years on bad CA's and it was so freaking annoying... Getting new tires helped it for a bit but since I didn't want those to wear I changed the CA's... Now it is like new!
    ΜΟΛΩΝ ΛΑΒΕ
    Feb 15 2007
    marimont
    I have the same problem :(
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Could certainly be caused by control arms. Worn bushings or ball joints will allow for excessive play and movement. Translate into vibrations, uneven tire wear, and the obvious noises.
    Active Member One Ring noobtuner's Avatar
    May 13 2008
    tacoma
    i agree with EWOK. and you should just get the entire kit for the front it solved my problem. and if you can do the work it will save you some cash
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    What is the difference between B5 S4 kits and the cheaper kits for B5 A4?
