Results 1 to 32 of 32
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    Red Flashing oil light with 3 beeps
    I've tried searching and most everything that I'm finding is for the 1.8t motor. Driving today the red flashing oil can symbol popped up. When I start the car and sit at idle it doesn't come on, but when I start driving it popps right up. Does this mean I have low oil pressure, or just a bad sensor somewhere. My oil level is fine and it drives and idles perfect. Is this common on our cars, and should I stop driving the car untill its figured out?
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: Red Flashing oil light with 3 beeps
    Oil is not the thing I would mess with...and I certainly wouldn't drive the car if its telling me there is something wrong with the oil. What kind did you put in at your last oil change? Good Filter? Check the ground where you park for oil leaks. And are you checking your oil when the car is level? I'd check again dude. And again.
    Try reading your manual, too.
    Dec 11 2006
    Orange County,CA
    I did check level on flat ground and level was good. I use royal purple 5-40 and I change it at least every 2k miles or so. I don't have any leaks under the car. To be honest with you, what does that symbol mean? Does it mean pressure, bad sensor? Thanks for the advice.
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    the only time i seen my oil light pop on was when i was in my b5 a4 i hit a dip doing 80 and put a hole in my oil pan so check your oil pan and oil sensor.
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Trust me coming from a guy who blew him motor b/c of lossed oil pressure from sludge do not drive you car until it is checked out. That light means low oil pressure
    2010 Brilliant Black/Magma Red S4
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    When the warning light comes on does you oil temp gauge go to zero? I had the warning light come on with the annoying beeps and when it did my oil temp gauge would go from normal to reading that oil temp is cold. Then when the light would go away my temp gauge would go back to normal. If this is happening you probably have a bad sensor.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by RolledMySTi View Post
    My temp gauge stays right were it always does when the oil is fully warmed up. I just drove home from work and when I started the car, I decided to rev the motor up in nuetral. The light and beebs started right about 3K rpm. Wouldn't it be more common for the sensor to go bad as opposed to loss of oil pressure? I know the old 1.8t had sludge issues, but I didn't think are cars do?????
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    A buddy of mine with a clogged oil screen in his 1.8 had the same symptoms, I wouldn't drive the car man. An oil light is nothing to shrug off.
    Dec 06 2007
    Calgary, AB, Canada
    There are usually 2 oil pressure sensors in most VW/Audis. One sensor measures pressure up to ~3000 rpms, and the other measures the pressure above that. You may have a botched sensor. I'll look into the B5S4 oil pressure sensing system a little more...
    Dec 11 2006
    Orange County,CA
    ^^^Thanks Jerbel. Its seems to be one thing after another with this thing lately. Anyway, whats the best way to start narrowing this down. Should I do and oil pressure test (if so, how do you do one?) or should I change my oil, filter and start replacing the sensors before anything else? I'm for sure going to take the advice of elitedrumR and park this thing untill I get it figured out.
    Feb 25 2004
    02 S4
    Philly
    check for coolant contamination in your oil creating choco milk and the pressure issues. lots of ruined motors out there, usually headgasket or failed channels in block.
    S4x2
    Dec 06 2007
    Calgary, AB, Canada
    I would change the oil, replace the oil filter, and replace the oil pressure sensor.
    It turns out that there is only 1 pressure sensor on the B5, which measures pressure and transmits variably changing voltage. At below 2000 rpms, the oil pressure should be a certain value, and above 2000, it should be above that value.
    The best way to verify the problem is to get an oil pressure tester and plug in the pressure sensor into the tester and see if it reads correctly.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Quote Originally Posted by The_Jerbel View Post
    Are you using a bentley to search for this?
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Dec 11 2006
    Orange County,CA
    Jerbel as I've told you before I usually do more harm than good with a wrench, so I want to clarify one thing. When you say get an oil pressure tester, and then plug in the pressure sensor to the tester, it leaves me a bit confused. How do I go about doing that? I've never seen an oil pressure tester, have zero idea how to use one and have no clue where in the hell the pressure sensor is located. Sorry if these are stupid questions.
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by espo4442 View Post
    Your oil sump is sludged up and you're not getting oil to your head. I suggest either A) Pull oil pan and clean the oil pick up screen, B) replace the oil pump all together C) Do one of the well documented rx treatments. Because this will destroy your engine sooner or later.
    -18 718 GTS
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by Militant-Grunt View Post
    So I took your advice today and pulled off the oil pan. The pan and both the oil screen looked perfect and their wasn't any sign of coolant in the oil either. I sealed everything back up and fired it up with the new oil and filter. I let it warm up, reved it back up to 3K rpm and the oil pressure light came right back on. I'm starting to think more and more that its a sensor (I hope).
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by audiwop View Post
    Sensor then on the bottom of the oil pan, for some reason I thought your car was a 1.8t, forgot I was in the s4 section haha.
    -18 718 GTS
    Dec 11 2006
    Orange County,CA
    ^^^I may be wrong but I thought the sensor on the bottom of the oil pan was oil level sensor, not the oil pressure sensor. Am I right or wrong thinking this?
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by S4 in_lowplaces View Post
    its just Jordans knowledge that is overwhelming, hes scanning his brain thats all lol
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Sounds like an Oil pressure sensor to me. I would start there for sure. can you VAG the car?
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by obijohn22 View Post
    I'm going to VAG the car today. Should a code pop up saying the sensor is bad if thats actually what is wrong?
    Sep 16 2005
    Asheville, NC
    I'd replace the sensor first because it's probably easier but I just read Bentley and it looks pretty straightforward if you have to replace the pump.
    I can't find any info about the sensor - does anyone know if Bentley calls it a "switch"?
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Sep 16 2005
    Asheville, NC
    Also, looks like you can get a cheap oil pressure tester on Ebay...
    http://cgi.ebay.com/ebaymotors/_Auto...m330245295940&
    Dec 11 2006
    Orange County,CA
    Quote Originally Posted by drkenan View Post
    Where is the sensor located on the car?
    Dec 02 2007
    michigan
    You would likely see a code there but, with a faulty sensor, the code would be false. I was just wondering if any other codes were present, which may help lead us to the problem. If you really had very low oil pressure you would start to hear some extra noise from the valvetrain and/or rod bearings. (ticking, etc.) It is still important to not drive until you have this resolved, but based on the evidence, I suspect you will be fine. Keep us posted so we can all learn from this.
    Dec 11 2006
    Orange County,CA
    No other codes have come up, just that stupid little light. As far as ticking sounds, everything sounds normal to me. When the hood is up and I put my ear up to the valve cover it sounds like its making the normal little ticking sounds but nothing out of the ordinary. When the hood is shut, its sounds as quiet as ever. How loud would the ticking be? I mean would it be something and idiot would notice or is it more of a subtle noise?
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Sensor is located on the oil filter housing. Pain to get to, also check if the wire that runs up the engine is not burned or pinched.
    Dec 11 2006
    Orange County,CA
    ^^^Thanks for that.
    Dec 06 2007
    Calgary, AB, Canada
    The pressure sensor is actually the sensor on the bottom of the oil pan. A pressure tester is just a couple of hoses and wires and a gauge. You plug in the pressure sensor to the gauge and connect the hose of the pressure gauge to the hole in the oil pan where the pressure switch used to be. You then give 12v to the pressure switch and ground out the gauge, and that's the setup. Then you start the car and rev it up gradually. The light on the gauge should be on between 1.2 and 1.6 bar of pressure. If not, replace the switch. Then at 2000 RPM and an oil temperature of 80 ° C, oil pressure should be at least 2.0 bar. If not, you have oil pressure issues.
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    The sensor on the bottom of the pan is the combined oil level and oil temperature sensor. The oil pressure sender or switch is on the top of the oil pan behind the oil filter housing and oil cooler.
    A replacement sender should be about $20-$25 from the VW dealer (same basic part has been used since the 1970s on the VWs).
    Dec 06 2007
    Calgary, AB, Canada
    My mistake. I knew it was on the pan somewhere...
    Dec 02 2007
    michigan
    It would be very noticeable if some moving parts were oil starved. I think everyone has you on the right track. check or just change the sender, and go from there.
