Results 1 to 21 of 21
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    how much do cv boots/joints cost to replace?
    how much am i looking at spending to get both my front cv boots and joints replaced? I dont have the tools to do it myself so im gunna have to pay a shop.
    Im pretty sure they need replacing because i get clunking and snapping noises when i turn my wheel when moving slowly. Especially when trying to parallel park. When i go in reverse and turn the wheel and start moving ill get a clunk 100% of the time. thanks guys.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Apr 22 2007
    Riverbank, Ca
    Re: how much do cv boots/joints cost to replace?
    250 per ~
    Senior Member Three Rings A4Shizzle's Avatar
    Mar 19 2006
    San Jose, CA
    Hey, I fixed my cv boot myself, and when I did I took the whole joint apart to make sure it was good. It wasn't that hard to do so if you want to give it a DIY shot I can help you with that. You don't really need too many special tools. Are you doing the two front outer joints?
    No time to mod with so many things to fix...
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by andyrew View Post
    250 per ~
    per side? ouch
    Quote Originally Posted by A4Shizzle View Post
    yea man i would definitely drive down to san jose if your willing to help me out. And yea i think its just the outers, not sure though. Im getting a full inspection and everything done in a few days hopefully.
    Dec 08 2006
    Cincinnati
    I just had CV boot replaced (not joint though) for $130. Hour and a half labor, and 30 dolllar kit (from shop).
    Apr 22 2007
    Riverbank, Ca
    King, did you take the CV to the shop? Replacing a boot is way different then a new CV.. I bought my new CV's for 125ea through my uncles shop.. I re did the boots on the fronts myself and I should have just bought new CV's..
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    http://www.autohausaz.com/search/pro...6%20Boot%20Kit
    You want the first one on that page, $140 for a true Loebro joint. I have the tools. Theres really only 2 "special" ones you need, a big hex drive and a triple square. The joint kit comes with a boot as well.
    BTW, every shop I went to quoted me $500 for a new joint. They said it would be better to just replace the whole axle for a couple hundred, which is a shitty aftermarket brand. Loebro is the OEM brand on our cars I believe. The first time, I tried to fix my problem by just changing the boot. It was my first time doing anything with axles, all I had was a Haynes manual and it only took around 2 hours. Took apart the joint and cleaned it out, re booted it and put it back together. No dice.I bought my joint for around $150 and changed it in about an hour with a buddy.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Dec 08 2006
    Cincinnati
    Yup, had boot done at shop. They said labor isnt much different (boot v/ joint). If the joint sounds alright still, and the boot hasnt been torn too long (some grease still in there), then replacing just the boot will often suffice. If the joint is already clicking and sounds like crap (or visually see there is not grease left in there) then I guess its worth it to replace.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    $90
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by UN-PIMP-Z-A4 View Post
    $90
    uhh per side? per part?
    Jan 29 2007
    MR VTEC Lives...
    per side rebuilt installed
    QUOTE OF THE YEAR:
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    NOOOOoooooooooooo DON'T BUY JUST THE JOINT!
    You can get a whole new axle with new outside and inner cv joints for $110, it's WAY easier to swap the whole axle than to take the axle out and swap joints.
    http://www.purems.com/products/product.php/II=1657
    I made the mistake of changing the joint before realizing I could have spent less on the whole assembly.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Oct 01 2007
    1997 A4 2.8 QM
    where?
    Quote Originally Posted by Kyle H View Post
    so i have to pay $110 for each left and right side? How much am i looking at a shop charging for an install on those?
    Dec 08 2006
    Cincinnati
    Quote Originally Posted by Kronic Budz View Post
    where?
    My shop charged hour and a half per side. So if you are doing two... around 3 hours i'd think.
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    I was just going to say this - get an entire new axle for $100 and be done with it. The only other cost will be an alignment. You'll get away with $250 for everything - 2 axles and alignment if you do it yourself.
    Oct 01 2007
    1997 A4 2.8 QM
    the cheapest place i can find is ecstuning and they sell each front axle for $150 shipped. So $300 just for parts, and probably another $200 for install by a shop. Anyway to do it cheaper? Or do i just gotta do it myself.
    Established Member Two Rings macgyver681's Avatar
    Jul 02 2007
    2000 Audi A4 1.8TQ
    www.rockauto.com is your friend. They have the front axles for $85 rebuilt. I get alot of parts from them. They blow away just about anyone in terms of prices. $70 if its and automatic.
    Please contact me > macgyver.lcd.audi.vw.repair {at} gmail.com for more information.
    Mar 19 2006
    San Jose, CA
    Its probably just as hard and almost as expensive to do the joint instead of the axle, so you may want to replace the whole thing. Its not really that hard though, maybe an afternoons worth of work.
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    I got both of my front drive axles replaced on my old audi when i first got it, at a reputable euro mechanic. It was a little over 700 altogether.
    {99.5 Avant}
    Veteran Member Three Rings ibew5audi's Avatar
    Feb 24 2007
    Megacab6spdSmarty-fjr1300-express3500
    pitts area
    If you're keeping your car for a while don't buy the china axles. raxles sends you everything you need to change your axle with a rebuilt one from them. New axle bolt/inner hub bolts/ star bit for inner hub bolts. Lifetime guarantee - uses amsoil synthetic grease in joints. I did one two years ago and did the other side a year later. Not a hard job on 1.8t 5spd-especially driver's side. Call and talk to Marty and he'll explain the difference. Boots are a waste of time for the time involved. Or look at blauparts.com for 2.8's they say just replace the outer cv for some reason.
    my old A4 1.8t---226k hard redlined miles -8000 mi oil changes. Chipped for 150,000 miles. Still going.
    Oct 01 2007
    1997 A4 2.8 QM
    ok thanks guys for the advice. I actually just checked out my car today on a lift and both my front outer boots look almost brand new with no cracks what so ever. And my inners dont look to much worse, so im not even sure i need to replace them now... lol but im gunna have a mechanic take a look at them when i get a inspection to really make the final call.
