Results 1 to 21 of 21
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Need help asap!!! S4 overboosting!
    I have an audi b5 s4 and was driving on the interstate and check engine light came on...I'm getting the code checked in the morning but one thing I noticed is when I accelerate at wot the boost gauge spikes at 25psi and stays at 25psi and acts light a rev limiter and the whole car starts to shake and acts like it bogging and cutting fuel. I have awe's stage 3 kit with fueling on the car. What could be causing the overboosting? What should I check. Thanks guys for the help. This is my first s4 so I am clueless. The car pulls hard till it spikes at 25psi and then this happens.
    Apr 05 2007
    Re: Need help asap!!! S4 overboosting!
    either boost leak or bad N75 valve would be my first guess. i would stay out of boost until you diagnose what is going on, as it sounds like you might be spiking over 25 lbs.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Quote Originally Posted by exorcet View Post
    +1
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 05 2007
    also, it try unplugging your N75 (sensor right in front of the MAF housing/accordian hose.. brown square connector) -- this will allow you to test if you have a leak in the wastegate line, which can cause overboosting.
    unplug the N75 (just the electric connector, not any hoses/tubing), and see if you only get 7-9 pounds of boost at WOT. If you do, your wastegates/lines are probably ok and you can rule that out. If you go higher.. you'll know that's where your leak is.
    Here is where the N75 is, circled in red. This is also something AWE recommends replacing as preventative maintenance on any higher mileage stg3 cars.
    /thanks to Cole for letting me steal this image of his engine from another thread without his permission. ;)
    May 23 2008
    Columbia, SC
    So if my psi goes higher than 7-9 pounds then its my wastegates/lines? how would I replace those? and if I it stays within 7-9 pounds then what would be my problem? How would I tell if it is my N75 valve?
    Dec 06 2007
    Calgary, AB, Canada
    The only way it would be a boost leak is if it was a WG or a boost reference line that was leaking.
    OP, you should log block 119 and 115 and post them here. Pressure test the line coming off the side of the N75 toward the driver's side of the car. Make sure it holds pressure. What exorcet is saying is that if you unplug the N75 it should throw you into limp mode and you should only boost to 7-9psi. If you do, then your WG lines and WG's are functioning properly, if not, then they may not be. The most fool-proof way of testing the N75 and its lines is to log it, and pressure test the lines, like I mentioned above.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    I VAG'd the car and drove it this morning.
    only has catalyst eff. codes.
    its hitting WAY more than 25, as its going past 25 by at least 5psi on his AWE gauge.
    maxed out the MAP sensor as well. working on uploading the 115 log i took.
    N75 looks original, so i told him to get one monday, our dealership's closed on sat's.
    BTW, his doesn't have the shiney blue, red, orange and yellow things or shiney cap pictured here:
    could that be part of the problem?
    Oct 17 2004
    Columbia, SC
    Apr 05 2007
    Quote Originally Posted by offroader1006 View Post
    No, not part of the problem. What is the setup on this car - i'm assuming K04's... if not i think the K03's would be dead now.
    Do you what software/hardware this car has? From all the information I'd say WG line or N75.
    Sep 20 2007
    Harrisburg, PA
    You also may have coolant leaking into your oil...common problem when the seals leak.......if you taste the oil and it's at all sweet that's the problem....or one of them.
    Dec 06 2007
    Calgary, AB, Canada
    Anyways, offroader, I can't read that log you posted, try emailing it to me [email protected]
    May 23 2008
    Columbia, SC
    Ok...one of the hoses hooked into the N75 valve had come off! Replaced the hose and now car only boost to 15psi. Checked all hoses and tightened up everything. Unplugged the ecu and restarted the car...runs at 18psi and holds with no spiking??? Car was spiking before to 24psi, holding at 22psi and glides to 18-20psi. I ordered the a new n75 and vast mbc...you think this might fix the issue?
    Apr 05 2007
    Quote Originally Posted by Allaidback View Post
    yeah, there is a good chance it will, i think. but you should also do a pressure test to make sure you don't have any other leaks.
    May 23 2008
    Columbia, SC
    It's funny...this is my first turbo car and you can really tell the difference in just 2psi!!! I never even thought that could make such a huge difference in acceleration.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by johnkent1212 View Post
    yeah i mean if you put it on your steak and you die that means you're good to go. lol
    Sep 20 2007
    Harrisburg, PA
    1 psi = roughly 15 horses.
    Sep 20 2007
    Harrisburg, PA
    I didn't say drink the stuff...just a little taste. I kinda set myself up for that one...haha
    Oct 17 2004
    Columbia, SC
    one place i didnt check visually was the "F" hose. definitely a likely spot for a leak.
    andrew, if you search "F" hose in the B5 S4 forum you should find some pics and a description. jake has an upgraded "F" hose, if you want i am sure we could put one on yours sunday.
    Apr 05 2007
    no wonder when i had my MBC set to 15psi it only felt like i had 225hp.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    some of these replies are funny. haaa
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Sep 20 2007
    Harrisburg, PA
    Quote Originally Posted by S4 in_lowplaces View Post
    You're funny.
