Results 1 to 13 of 13
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    Door Handle Covers
    My driver side door handle cover has been loose. I tried a quick fix with some epoxy around the tabs in the 2nd pic, but it gave after a couple months. Does anyone else have this issue? Every time I close the driver’s door the cover rattles (which reminds me of the sloppy jalopies I drove in high school every time I close it) and I really hate the whistle/chatter it gives @ 80mph+
    I’m trying to figure out how to remove the cover. Does it pop off from the top? I’m stuck at work with some free and alone time and figured I’d tackle this while I’m on the clock.
    Cell phone pics
    Previous
    USP B6 A4
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Re: Door Handle Covers
    wow that sucks..ive never seen that on a b6 before
    Dec 06 2007
    same here, my door handles have to be repainted they are chipped like crazy!!!!! i've removed it by mistake but couldn't get them back on!
    -Kirk
    BetaAlphaTau Member #58
    Senior Member Two Rings akordboy's Avatar
    Feb 24 2008
    B6 A4 1.8tQ 6-sp
    York, Pa
    mine is loose and drives me crazy as well.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Mar 11 2008
    B7RS4 & e46Ms
    When I finished my sub enclosure... the ONLY thing on my car that rattles is the driver's door handle...first thought..."this is a stupid f**king problem to have"
    I'd love to hear of a fix...
    Dec 06 2007
    ^^anyone know how to remove the trim covers???? i need to repaint them and don't know how to go about doing this!!
    -Kirk
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    mine are fine .. other than rock chips
    as for how to remove them - screws inside the door panel
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Dec 06 2007
    ^^screws for the trim covers????? i'm talking the painted par not the whole handle!
    -Kirk
    Mar 22 2004
    Castle Rock, CO
    Well here's how you remove the trim.
    As far as fixing the "loose-ness" I'm still working on that. I'm thinking of bending the bracket a lil bit to firm things up. Will post update...
    Previous
    USP B6 A4
    Mar 22 2004
    Castle Rock, CO
    Well I fixed it. I took enough pics and the results kicked enough ass I'm going to put a lil DIY together in it's own thread.
    Previous
    USP B6 A4
    Senior Member Three Rings NVR STSFD's Avatar
    Oct 10 2007
    2003 CVT, Lexus RX 300
    Norcal
    Sweet, I can't wait. I need to fix mine too.
    Mar 22 2004
    Castle Rock, CO
    The DIY is up. It took 10 times longer to write it up then to perform the procedure
    http://www.audizine.com/forum/showthread.php?t=212229
    Previous
    USP B6 A4
