Results 1 to 13 of 13
    Veteran Member Three Rings djvice's Avatar
    Mar 03 2008
    Nissan Frontier Nismo, Lexus IS350, Smart fortwo
    Laveen, AZ
    Does rubbing hurt your car/tires?
    I just got 235/40/18 8.5 wheels and tires on my 2006 A4. I lowered with Stasis SS 25.5" in the front and 25.625" in the back (Stasis recommended "Aggressive Street" stance). The car is fine, but it will rub when the car "bounces" on a really bumpy road, or if I don't go into an elevated parking lot at 3 mph.
    I know quite a bit of people on here rub, either because too low of a drop or having 19s. My question is, will rubbing affect the life/quality of the tires? My back tires seem to have a small wear line caused by the rubbing, but the front is less noticable.
    Any comments would greatly be appretiated
    New Member Two Rings M Style S's Avatar
    May 14 2008
    2008 A4 S-Line/Titanium
    Pasadena
    Re: Does rubbing hurt your car/tires?
    Well it mostly hurts the quality because usually when you rub it wears off the side threading on the tire. Eventually those small wear lines will get worse, especially it you take turns hard often...
    Jul 29 2007
    b7 3.2
    I rub just as rarely but still noticeable times as well. I'm dropped on stasis SS and slammed pretty low too, but I'm on 19's. The setup is remarkable though for being slammed and still riding like that.
    Mar 03 2008
    Laveen, AZ
    typerlover...how many miles do you have on the tires?
    Jan 06 2008
    Dacia Sandero
    Arizona
    Quote Originally Posted by djvice View Post
    Whats the offset of the wheels?
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Mar 03 2008
    Laveen, AZ
    38
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    get some negative camber
    Mar 03 2008
    Laveen, AZ
    What is negative camber?
    Would I be able to roll my rear fenders? I've heard about this but have no clue what rolling my fenders is? How is it done? Are there any visual differences in a rolled fender vs a non-rolled?
    Nov 15 2007
    http://en.wikipedia.org/wiki/Camber_angle
    http://www.mazda6tech.com/index.php?...id=17&Itemid=1
    cant really roll the fenders in the rear of the B7 A4, but you can in the front.
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    i rub like once a mile at least. for the last 8k miles. tires look fine and aside from a little missing fender lining in the back (not noticeable at all) the car is fine too. it just looks way too damn good for me to even think about fixing. also on stasis. just dont load like 4 big dudes into your car or bad things may happen.
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Veteran Member Three Rings MarkChai's Avatar
    Feb 01 2007
    1998 Titus Quasi-Moto
    SF, CA
    from cerfus' thread in the regional forum:
    "These shops cater to "custom" alignment figures
    Bob Jordan's Alignment
    8718 E. McDowell
    (480)945-2040
    Campus Alignment Service
    910 N. Scottsdale rd unit#4
    (480)967-8390 (Dan or Bob)
    Network Alignment
    12639 N. Cave Creek rd
    (602)867-8061 (Scott)"
    http://www.audizine.com/forum/showthread.php?t=200135
    Formerly:
    B7 A4 Saloon CVT :P
    C4 A6 Avant Quattro
    B6 A4 Avant USP 6QM
    B5 A4 Saloon Q-Tip
    Jul 29 2007
    b7 3.2
    About a thousand now. Seems ok so far.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    If you rub a lot on the rear fenders (for several seconds at a time or often enough to cause a lot of heat buildup) you can burn the paint on the rear fender and cause it to peel. This happened to my car when I had 10's in the rear and I have to get both rear quarter panels repainted now. This is the extreme though, you have to rub quite a bit for this to happen. A little but of rubbing once in awhile over big bumps isn't go to cause this to happen. If it happens enough that you start to smell burning rubber, then you should be worried.
    -Darrick
