Results 1 to 19 of 19
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    Which Optima battery?
    Battery is on its way out. Thanks to some of your posts, I decided on an Optima. Now, I found some good info on the Optima RedTops, especially the post by RxRep here - http://www.audizine.com/forum/showth...ghlight=optima
    But, I want to be sure that I get the right one for my B5 S4. Anyone know which RedTop is the best fit for our B5 S4s? From what I understand, they have 75-25, 25, 75-35, and 35. Gotta pick one up today so any help would be hugely appreciated. Thanks!!
    Senior Member Three Rings jakecro's Avatar
    Feb 08 2007
    '00 S4 6MT 324K mi stock K03s
    Pittsburgh
    Re: New Battery Recommendations?
    try a search since this has been discussed before
    here's a few threads that I found in my subscriptions on the topic:
    http://audizine.com/forum/showthread.php?t=200112
    http://audizine.com/forum/showthread.php?t=157915
    -Jake
    [email protected]
    www.audidatabase.com <--feel free to contribute material
    new siggy
    710Ns|CC|VDO Vent Boost Gauge|Piggies|LW Crank Pulley|034 Snub|Hawk HPS|K&N|Continental ExtremeContact DW
    Senior Member Three Rings team_soy's Avatar
    Apr 30 2008
    florida
    deka xt20l i think..odyssey posts...and some zip ties...all of that should bring you under 100 bux
    Registered Member Two Rings
    Jan 26 2008
    00' S4 M6 blk/blk
    columbus, OH
    Interstate
    Sep 23 2007
    77 montecarlo, Suzuki GSXR, S4
    chicago
    Recently replaced mines with Autozone, Duralast 48-DL... Paid under 100 bucks.. Perfect fit..
    Established Member Two Rings dc878mmm's Avatar
    Jun 20 2007
    San Francisco
    How about Odyssey lightweight batteries? It'll lighten your car by 25lbs.
    2001.5 B5 S4 Stage 3
    Veteran Member Three Rings ss4's Avatar
    Jun 04 2005
    San Diego
    Quote Originally Posted by AUDILUX View Post
    Battery is on its way out. Anyone have any recommendations for what brand to replace it? Thanks.
    I use the Odyssey PC925MJT; fits in the stock location and saved about 20 pounds compared to stock. You will need to buy a cheap battery bracket from your local parts store to hold it in place. People have used the even smaller/lighter 680 battery but a little too weak IMO.
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    Quote Originally Posted by ss4 View Post
    I have the Odyssey PC680 and haven't had any problems.
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Depending on your average commute time and driving condition with the car, in conjuction with the lower temp. After-Run pump sensor switch modification, you may run a greater risk of killing the light weight battery prematurely and subsequently, the alternator as well.
    Jan 16 2006
    Vancouver, Canada
    Quote Originally Posted by Tifosi View Post
    I drive one day a week for about an hour or two, and I have the upgraded after-run sensor mod.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    i am partial to yellow tops for my audi since it gets driven 1nce a month... red top in my daily
    Oct 16 2007
    B5 S4 / 335i
    Quote Originally Posted by ThirdStrike View Post
    I drive the car about one day per week. Should I go with the yellow top? Also, where did u get the battery from? I stopped in to Pep Boys today and they told me they didn't have any optimas for my car (2001 S4).
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by archimense View Post
    The problem tends to arise with people who drives on multiple short trips during the day that are just long enough to heat the coolant temp to activate the after-run system after the car is shut off. Think of it like this, the battery is being drained with repeat activation of the system but not enough time to recharge the battery properly with each activation.
    In your case, even know you only use your car once every 7 days, you are still charging the battery with your 1-2 hrs drive with the ARP system activating only once.
    Not sure about AZ, but do a search on AW about this as this issue has been discussed and reported many times already.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    uhm yah they have a point.. the optima doesnt fit correctly in our battery trays. i just put mine in and did away with the locking mechanism.
    yellowtop is made for deep cycle -aka--you can drain it almost empty many times without ruining it.
    Oct 16 2007
    B5 S4 / 335i
    So, what do I need to ask for? Is there a specific (model #) optima yellow top that I should ask for?
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    PC680 with after run in Wisconsin. No problems. Stock Battery strap "tweaked" to fit. Looks and is oem. 14 lbs.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Apr 27 2004
    Pacific NW
    You should be fine with either RedTop or the YellowTop. Key thing is that you need reverse terminals to fit the battery in properly, either a 34R or a Group 35 of the Optima RedTop. but they will all require aftermarket bracket or strap with some creativity to anchor them down.
    Jan 28 2005
    02 S4
    soCALI
    Odyssey PC925 (larger reserve capacity than PC680, more practical for daily driver)
    Oct 16 2007
    B5 S4 / 335i
    OK, what's the difference between the 34R and the Group 35? They have them both on Amazon-
    Optima Batteries OPT 34R 800R Reverse Terminal Starting Top Post Battery, Red Top for $177 &
    Optima Batteries OPT 35 Group 35 Top Post Battery, Red Top for $141
    Only the 34R says "reverse terminal". If both of these work, which one is better?
    Thanks.
