i made a diagram so i wouldnt F-up the install and figured i would share it for anyone who may do the same.
I used one of the coil signal wires for RPM, so i just set cyl # in the SAFC to 1.
I also put a toggle on the power to act as an anti-theft kill switch.
http://www.audizine.com/gallery/show...=57775&cat=500
if you want to hook it up to come on when the key is turned on, the 15(ignition power) is located under the left side of the dash. Remove the knee bolster. Under the relays there is a row of downward facing nuts on a junction box, all of the wires are red except for the far left, its black with a yellow stripe. that is your ign power.
