Results 1 to 16 of 16
    Senior Member Three Rings Wilco's Avatar
    Dec 11 2006
    1998.5 B5 A4 2.8QM
    Tacoma, WA
    Question Lug Bolts Rusted On
    I finally got new wheels and swapped out 3 of the 4. I can't for the life of me get the rear left wheel off. All except one of the lug bolts are so rusted on they won't come off.
    Any idea what I should use to get them off? I put some WD-40 in there to sit overnight. But maybe this is a job for that liquid wrench stuff? I've already tried a 4-way wrench + a rubber mallet with no luck.
    BRAND SPANKIN' NEW: AudiWiki.net
    1998.5 Brilliant Black A4 2.8QM
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Lug Bolts Rusted On
    Craftsman 1/2" ratchet, 3ft cheater bar, and something soft to land on when you break it loose. Use gravity to help you put your weight on that cheater bar.
    Otherwise, I'd shoot for an impact, but you would've used that by now if it were an option.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yeah a breaker bar with an impact socket and a cheater bar then just bounce, jump on it. If it doesnt work get a longer cheater bar.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Be prepared to break them...It has happened to me a couple of times now. One of them broke off flush and I basically had to scrap the whole assembly. The other one sheared the head off so there was enough sticking out that a small propane torch and a Craftsman Stud Extractor was able to twist it out...
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    PB Blaster. One of the few rust breakers that work. Wd-40 is like water compared to it. Spray the lug every half hour for a couple of hours, put a sleave over the ratchet of thick PVC pipe if u got any lying around, if not a breaker bar. Should come off rather easily.
    Oct 26 2007
    '99 A4 Avant 1.8tqm / '04 S60R
    Nashua, New Hampshire
    I second PB Blaster.
    Please take the effort to make me feel unworthy!
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Soak them in PB Blaster. Reapply every half hour for a couple hours. Then put a breaker bar on a 17mm impact socket and slide the jack handle or other long pipe over the breaker bar. If it won't turn this way you'll need to take it to a shop and have them use their big impact gun to spin them off and then torque them by hand so you can remove them at home.
    Rusted lug studs are evidence that the tires were not rotated often enough. Simple maintenance would have let your tires last longer and saved you this trouble.
    Jim
    I Do Werk.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    One of the techs can't help you out at your work?
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 29 2005
    10speed
    San Francisco, CA
    you just need a long bar
    - Clint
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    autozone breaker bar ftw
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by ThirdStrike View Post
    your avatar intrigues me.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Antiseize FTW
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by Stampy View Post
    Antiseize FTW
    You don't use that on lug nuts/bolts!
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    yeah i dont man. more of a joke...
    Village Idiot!!!
    (\__/)
    (")_(")
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Ewok_Fetus View Post
    It's been done before, but you are correct, it's not recommended.
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by djwimbo View Post
    Ask my buddy what happend when he did it... He would be glad to tell you that his bolts came loose and wheel fell off and went flying off into the other lane and almost had a head on...
    ΜΟΛΩΝ ΛΑΒΕ
