Results 1 to 7 of 7
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    How low are KW V3's at factory settings? Pics?
    I've got a set of KW V3's sitting in the box waiting to go on, and I was wondering how low they are if I leave them at the settings KW ships them with. What adjustments have most of you guys made, and what differences did they make?
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Re: How low are KW V3's at factory settings? Pics?
    if you purchased KW V3s and want factory settings, why did you buy a coilover with so much adjustability available? you would have been better of with H&R's.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Three Rings jerrym's Avatar
    Nov 23 2007
    4 Door Saloon
    thats a good question..
    2009 Mercedes-Benz E63 AMG
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2008 Audi RS4 (gone)
    2005 BMW M3 (gone)
    2003 Mitsubishi Lancer EVO 8 (gone)
    "After a certain point, money is meaningless. It ceases to be the goal. The game is what counts" -Aristotle
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    The dampening is pre-set but I dont believe that the same is true for the ride height. My ride height is approximately 25.5 in the rear and 25.75 in the front.
    I say approximately because I had the car corner balanced which allows for 50/50 weight distribution in the corners. I have kept the stock dampening settings because I feel that they are set perfectly for daily driving.
    Here's a pic.
    Jan 14 2008
    Calgary
    Quote Originally Posted by 2PUTT View Post
    I meant the KW factory settings... I thought they came at a pre-set height that was lower than stock.
    Thanks for posting the pictures/numbers MOFSTEEL!
    Veteran Member Four Rings JetBlue's Avatar
    May 03 2004
    Carlsbad
    KW's are not set in anyway from the factory. Call them to get their recommended settings for your car. If not it is very easy for the installer to screw it up and they have to be pulled for damping to be readjusted.
    "The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money." Alexis de Tocqueville
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by JetBlue View Post
    "The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers"
