Results 1 to 12 of 12
    Established Member Two Rings AIRPATEL's Avatar
    Mar 29 2008
    A4 1.8T
    DFW
    Cat Glowing Red Hot.
    Hey guys, I need your help. I just got my car flashed yesterday and now i see a glowing cat under the hood? What could it be. I felt a misfire several times and a little loss of power not much. It feels like its fine at high speeds, cant' really tell. I think it may be coil packs. Please advise, thanks..
    Revo Stage 1+
    Magnaflow Exhaust
    H&R Sport Springs/Spacers
    K&N Drop In Filter
    Boost Guage
    LED Tails
    18" VMRs
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: Cat Glowing Red Hot.
    Most likely coil packs.
    Buncha motorcycles
    Memphis, TN
    get a test pipe!
    you have probably blown a coilpack (very common) causing that cylinder not to fire and all that fuel just being dumped into your cat.. replace all your coilpacks with the newest OEM revision "R" or HItachi E coilpacks like many of us have done..
    APR Stage 2/AWE Intake
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Be Careful with that, If your exhaust is that hot you are probably knocking, it could be a boost leak from your DV also, Like they said above check you coil packs, hows your idle, you should also let your car idle after you drive it hard like that, i can cause sludging if you dont.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Mar 29 2008
    A4 1.8T
    DFW
    hey guys thanks a lot for all the feedback, i got all my coil packs, and plugs replaced. it seems to be fine now. I'm still worried does anyone think that the revo program had anything to do with this. I really hope not.
    Revo Stage 1+
    Magnaflow Exhaust
    K&N Drop In Filter
    Boost Guage
    LED Tails
    18" VMRs
    Dec 06 2007
    ^^nope coil packs fail real quick due to poor design on our cars!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by AudiA4Turbo22 View Post
    Thats not always the case, my car has almost 84,000 miles and original coilpacks!
    I do have four new Hitachis in my garage, but have never swapped them as there has never been a problem...
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Dec 06 2007
    ^^ well i guess it depends! some cars they go real quic and sometimes u get lucky!
    -Kirk
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    I have noticed reports on this list of coil pack failures right after getting a chip.
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Quote Originally Posted by sailor View Post
    There is still no evidence of coilpacks failng because of getting ur car chipped. i got mine chipped 4 months ago with giac and she runs like a charm minus alarm on crack...
    Registered Member Three Rings Amze's Avatar
    Apr 10 2007
    2003 Audi A4 1.8TQM
    Phoenix, AZ
    coilpacks
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    Better keep and eye on your manifold!
    V8 Touareg - 1G TSI AWD - WRB WRX
