Results 1 to 8 of 8
    Registered Member Two Rings
    Jul 29 2005
    Quebec
    So is it GL-4 or GL-5 (Transmission oil question)
    Ok, so I just bought 3qts of Redline MT-90, was about to change it on the weekend but run short of the special tool needed to drain the tranny. Emailed a shop today and they said, just make sure it's GL-5 oil.
    So I called Audi today and he went to look up the specs, and said it's GL-5 also.
    So now I'm confused, Redline Mt-90 is GL4 which everybody reccomends here. I'm starting to think of bringing it back to exchange it for some Royal purple, which is GL5 I believe.
    Thanks in advance for any clarification on this matter.
    Jul 29 2005
    Quebec
    Re: So is it GL-4 or GL-5 (Transmission oil question)
    ok, so, is it me, or nobody has ever changed their transmission oil?
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Unless you have a very specific use for your car (track etc), I'd put whatever the dealer puts in it. Heck, I'd buy it from them or a reputable audi mechanic. I know an excellent place in Quebec City for Audi work. PM me if you want details.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    The rear differential REQUIRES GL-5.
    The transmission can take GL-4....I have had Redline MT-90 in my tranny for about 4K miles and love it.
    -Sami-
    Jul 29 2005
    Quebec
    thanks for replies!
    Audi fluid is 22$ per liter, Redline was 16$ and it seemed like it's the oil everybody uses here.
    Aug 26 2005
    Quote Originally Posted by youriy View Post
    OK, the MT shares the lubrication of the differential with the transmission gears, the differential is a hypoid gear, and would "like" GL5 lube, but GL5 is too slippery for the transmission synchronizers, so Synthetic GL4 is the required specification.
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    Ok, but would the Redline 75W90 NS oil without friction modifiers (designed for synchronizers) be acceptable or better than MT90/MTL?
    Aug 26 2005
    Quote Originally Posted by Splattj View Post
    I don't think so. Because a GL-4 is specified by Audi, the higher friction in the diff with GL-4, compared with GL-5 is less important than proper synchro function assured with GL-4. I recommend asking Red-Line what they advise regarding the Audi's hypoid diff and synchros and shared lube. I think MT-90 is prefered here...
