Results 1 to 16 of 16
    Veteran Member Three Rings ////D's Avatar
    Aug 22 2007
    847 IL
    Warning Beeps upon start up
    everytime i start my car i get 3 beeps meaning that something is wrong. i cant tell what they are because my center display is broken. i looked in the owners manual and it says to emmidiately shut off my car, but i dont have a check engine light, and my car runs fine. this happened after an oil change one day, well i thought it was the oil filter throwing the car to think it had low oil compression. so i changed the oil again with a different filter and nothing changed. and during that first oil change i fiddled with the coolant reservoir, i flipped on its side when i was trying to get to the window washer nozzle. so i dont know if that had anything to do with it or not. i got it vagged and nothing came up. anyone have any ideas?
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Re: Warning Beeps upon start up
    no other lights appear? say an oil pressure light?
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Aug 22 2007
    847 IL
    Quote Originally Posted by maxspeed View Post
    nope! nothing, except an air bag light thats been on forever
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    It could just be your Maintenance Reminder. Did you reset it?
    Other ideas:
    Washer fluid low
    Coolant low (or the sensor is messed from you dropping it)
    Light bulb out
    Brake material has worn past sensors.
    Aug 22 2007
    847 IL
    Quote Originally Posted by whoace View Post
    Other ideas:
    Washer fluid low
    Light bulb out
    the only thing out of these that make sense to me is the sensor being bad, because the other things you listed dont match, i have a lot of brake pad life left, washer fluid has been on way before this 3 beep thing happened and i dont have any light bulbs out
    Apr 22 2007
    Riverbank, Ca
    I have no washer fluid in my tank, and no beeps on mine, just an idiot light. (I have a FMIC that runs into my squirters, so I took them out)
    So that couldnt be the issue.
    Aug 22 2007
    847 IL
    Quote Originally Posted by andyrew View Post
    i have the same light, but ive had that light on forever, and i dont havea fmic yet
    Active Member Two Rings Big-Pat's Avatar
    May 28 2007
    St. Paul, MN
    Do you have gas?
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    warning three beeps is for abs. my abs was faulty so i just disconnected it. then i would get the three beeps which tells you your abs isnt working. so i just took out the cluster and killed the speaker. So when you get those three beeps try to brake really hard and your brakes will lock up
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Registered Member One Ring avant11's Avatar
    Feb 04 2008
    Malaysia
    Quote Originally Posted by Rhinop21 View Post
    I have the same problem and it's now narrowed down to the sensors or ABS module. Waiting for sensors to arrive and change to see if it can be fixed.
    Feb 12 2009
    T.O.
    anyone figure out what the problem was?
    Oct 29 2007
    2 1990 yamaha superjets
    Greenville, NC/ NoVa
    Im pretty sure if it were the abs acting up, there would be a light for it and the e-brake light would be flashing.
    2000 A4 1.8tqm
    - 2.0l - GT3076 - 630cc - spa - 034 - tial - aeromotive - mahle - unitronic - eurojet - forge - apikol - podi - innovate - raceline - alcon -
    Veteran Member Three Rings Amorphic's Avatar
    Jun 05 2009
    2013 A4 2.0T Premium 6MT
    BC, Canada
    the three beeps can also be low brake fluid. happened to me when i blew my rear caliper.
    Feb 12 2009
    T.O.
    oh, crazy... never topped up brake fluid, can u do it under the hood easily?
    Jun 05 2009
    BC, Canada
    Quote Originally Posted by bint2k View Post
    yes. there is a brake fluid reservoir under the hood, clearly labelled. Just make sure you use the proper fluid.
    Feb 12 2009
    T.O.
    Thanks a million, topped my brake fluid up and the beeps seem to be gone for now... will update if i still have problems.
