Page 59 of 60 FirstFirst ... 94957585960 LastLast
Results 2,321 to 2,360 of 2375
  1. #2321
    Veteran Member Three Rings makisupa's Avatar
    Jan 30 2006
    Boston, MA
    Image1634573751.745361.jpg that new new
    4.2L CFSA swapped 2013 allroad
    plus a bunch of other crap slapped on there
  2. #2322
    Feb 07 2021
    nice makisupa - what are wheels specs?
    2022 RS6 avant
  3. #2323
    Jan 30 2006
    Boston, MA
    Quote Originally Posted by JG 996T View Post
    RS5 hyper silver rotors, 20 x 9 et26. Could use some spacers.
  4. #2324
    Senior Member Two Rings HOJeepster's Avatar
    Aug 04 2014
    Lyons, CO
    Quote Originally Posted by makisupa View Post
    Looks super sick. Is your ride really V8 swapped? Build link?
    Justin | '14 Allroad | CTS K04 | CTS DP | ECS IC | APR Tune | Magnaflow | E85 | Vogtland 968116 | Macan calipers |
  5. #2325
    Jan 30 2006
    Boston, MA
    Quote Originally Posted by HOJeepster View Post
    Wouldn’t lie about something like that lol
  6. #2326
    Aug 04 2014
    Lyons, CO
    That's amazing, got a build link?
  7. #2327
    Jun 27 2011
    Couple of questions since this thread is relevant to me at the moment and I'm hoping someone here might have some insight.
    Question 1: I've got a set of Whispbar Flush bars (the ones that clamp to the inside of the roof rails) on my b7 and need some help. I've got an old Yakima ButtonDown Aero ski rack (https://yakima.com/products/buttondown-aero). The factory oval clamps sorta work but the bottom of the clamp could hit the roof with enough weight on top. I'd love to utilize the Whispbar's T-Slots but I've not found a truly plug and play kit. I ordered a set of the Thule Xadapt 12 but the included bolts are too short, only 7/8"/22mm. I found some spare parts bolts at Thule that are 35mm T-slot bolts and I ordered 4, and was planning on just taking a hacksaw to the factory clamp mounts to keep the spacer function that they perform. Has anyone tried this kit though: https://yakima.com/products/smart-slot-kit-2. It looks ideal but they don't list bolt length specs and I worry they'll be too short. Not to mention its backordered/out-of-stock everywhere. I know it says for FatCat only, and those appear to mount lower to the bars so I suspect its too short.
    And question number 2 (thanks for sticking with me this far). I ALSO have a Yakima Skybox 16 Carbonite that has the nifty toolless clamp mounts, however it, also, is too thick to mount to my avant. It works fine on our Q7 which is what its intended for but its a no go for the avant. Does anyone have experience converting it to use U-bolts or something to give more clearance for the Whispbars on a b7?
    Thanks all. And yea, I know I could just get a new rack, but whats the fun in that?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  8. #2328
    Mar 28 2009
    Minneapolis, MN
    I'm not sure if this will help, but I ordered a set of the Thule T-track adapters to use with my roof box instead of the clamps. These are longer screws that might work for what you need, and you could cut them down to the length you need if they're too long.
    https://www.amazon.com/Thule-T-Track...dp/B08375WQLG/
  9. #2329
    Jun 27 2011
    Thanks for the idea @dropshadow, not sure why I didn't see your reply till just now. I googled those bolts and the Thule manualpage shows they're 30mm, so likely too short. Good news is I just got those 35mm Thule bolts and they should work great. I have to modify/cut the factory Yakima mounts but I'm not too concerned about that. Theres just enough meat on the bolts to get a nut on it through the rack so I think I'm good to go. Just need to find a black oxide or stainless nut at the hardware store and I'm good to go.
    As for the roof box mounting, I don't think theres anything off the shelf thats going to work. I'd likely have to create my own mount so I'm probably going to shelve that idea unless theres some pressing need to mount the roofbox to my avant.
    -CP
    2017 Q7 3.0t
  10. #2330
    Jun 23 2008
    I have a Packline t-track 20mm mount setup for roof boxes that would work, I bought from Norway. I can send photos. It worked in my SkiGuard and Thule box.
    I have 2 sets and sold my roof boxes so happy to sell you one.
  11. #2331
    Jun 27 2011
    I appreciate the offer Evan, I’m not sure I’m going to bother trying to get the box to mount to my Avant, being realistic, I just don’t see when id ever need it where we wouldn’t be taking the Q7 so it’s probably not worth trying to figure out.
    In other news, the bolts I got at apparently fine pitch m6 thread so nuts that fit that are practically unobtanium. And since the only places I could find them were shipping from China I’ll be getting them some time in the next few weeks. And I just went to test fit the factory mounts and while the rears have some clearance, 1/2cm or so, the fronts are literally squeezed in between the roof and the bar. So the ski rack is a no-go until the nuts arrive. Oh well, at least my skis fit in the pass through…
    -CP
    2017 Q7 3.0t
  12. #2332
    May 13 2008
    NoCal - EBay
    Something old and something new.
    After my 5000mi Christmas/New Year trip I decided I need a cargo box.
    After 2+months of Thule-fever I have assembled my setup:
    1) Yakima-Whispbar Railbars. The most flush mounted I could find.
    2) Thule Vector Alpine in Titan Grey
    3) Thule t-slot mount kit.
    I have not yet taken any photos with the t-slot kit installed. They do save A LOT of interior cargo box storage space compared with the click-stop clamps. Also, I am now able to slide open my sunroof 100%; I could do this before installing my t-slot kit but now I can also tilt it open 80%. My front stop-click clamps were resting directly on the sunroof. The rear was okay. My sunroof is not panoramic so it slides into the area between my roof and headliner.
    Here is the final position few inches back from position in my 1st photo. Half a thumb-width from the rear hatch glass full open. I really like how the curve of the Vector follows the side-rails. Titan Grey is not a perfect match but its close enough for now.
    I will include a photo or two of my box interior with the t-slot kit installed to highlight the increased space available soon.
    'SOFTWALKER MODS
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
  13. #2333
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    I need to do the t-slot with my alpine vector, such a bummer to not be able to use the sun roof
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
  14. #2334
    Jun 27 2011
    I ended up not being able to use the t-slot bolts I got due mainly to the interior of the rack I have, the channel inside where the nut would go was too small to actually tighten the nut.
    I ended up buying these: https://maloneautoracks.com/T-Slot-M...6-117-118.html
    I just slid them into the channel, taking some car to line them up, then just stuck some stainless hex bolts in the top of the rack and bolted it down. I’d already sliced off a bit too much of the spacer for the rack so it sits right on the bars so I can’t open the top all the way but it’s plenty to get skis in. The other bummer is that my bindings hit the roof so I have to have them facing up side by side. But, again, it works and it’ll work just fine in my Q7 as the bars have like 2” more clearance. Annoyed I spend so much money trying our various options but whatever, I got it sorted eventually.
    Ideally I'd have left an extra 1/4-1/2" for the spacer/mounting blocks (not seen, they're between the rack and the bar inside it...) and my skis would have fit fine upside down. If I get really ambitious I could draw up a really simple spacer block in CAD and get a set 3d Printed I suppose...
    -CP
    2017 Q7 3.0t
  15. #2335
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by shreddykrueger View Post
    If you have the kit and you are thinking about it. It took me less than an hour working in my garage.
    1) Remove 4 rail end caps.
    2) Remove 4 Power Click clamps
    3) Slide in t-slot bolts onto your rails one side at a time. Yakima bars have the t-slot bolts slide on top of the rubber strip. Thule bars have the t-slot bolt slide in the middle as their strip is actually split down the middle. Should be no cutting and measuring needed.
    4) Hand tighten the bolts with the built-on grips to snug.
    5) Reposition cargo box - this could take a few tries to get it set where you want it front to back and left to right. Mine is off very slightly left to right in the front by about 1/16th of an inch or <2mm. I will correct it next time I'm in the mood. The box is so big it really is not obvious at all unless measuring and comparing both sides
    6) HAND-tighten to 2Nm (1.5 - 3 ft-lbs) NO he-man tools OR application of forearm-biceps-deltoid strength or you will strip the bolt. I have triple-checked everything and that tightness coupled with the softness of the metals used keeps everything tight under there. Follow the Thule instructions and re-torque after the first few trips. Mine did not budge. Hand tightening to where it just starts to dig into your fingers is sufficient just a few degrees after the bolt stops turning.
    7) Replace your rail end caps.
    8) Enjoy the sleek underbelly of your cargo box mounting system.
    P.S. Those in the know and are not haters will marvel at the look and give the mental nod of "job well done". Those that dont know will say it doesnt make a difference.
    'SOFTWALKER MODS
    Avant>Sedan! Click
  16. #2336
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by A4SoftWalker View Post
    And as everyone knows, these are the best type of mods.
  17. #2337
    Jun 27 2011
    Show Me Your Box - the Roof Mounted Cargo Box Thread
    The conversation with my wife went something like this:
    Her: “WTF is wrong with you just use the mounts it came with.”
    Me: “Well they hit the roof.”
    Her: “Then put something in the roof so it doesn’t scratch it.”
    Me: “but that’s not solving the problem….”
    Her: “You’re an idiot.”
    Me: “I know.”
    Haha. She only cared because I was talking about it for weeks and ordering random bolt kits (at least they were all fairly cheap) and cutting the costing mounts. By the time I finally figured it out, ski season was practically over, haha. But I’ll be damned if I was going to let the roof rack win!
    I was really close to just buying some 3/4” steel plate and cutting my own T-Slot “nuts”, drilling and tapping threads in them, and essentially replicating the Malone parts I bought but finding the right thickness was tricky and expensive as I’d have to buy a large piece just to cut like 4” off of it.
    But I too really dig those “you don’t know unless you know” mods.
    -CP
    2017 Q7 3.0t
  18. #2338
    Senior Member Three Rings Ethernaut05's Avatar
    Dec 05 2016
    Delaware
    Looking at the Yakima GrandTour 16. 1. Hoping I can fit two deflated Body Glove paddle-boards in it. 2. Our B9 AllRoad is Audi Exclusive Sepang and I'm looking to get it paint (vinyl?) matched. Any help would be appreciated! Running Audi OEM cross bars.
  19. #2339
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by Ethernaut05 View Post
    I think the Grand Tour you are looking at is 16 cu-ft. You could always measure your equipment and go look at some cargo boxes to get a general idea. Bring your tape measure along too. Thats what I did.
    'SOFTWALKER MODS
    Avant>Sedan! Click
  20. #2340
    Junior Member Two Rings Maxiimm's Avatar
    Jun 09 2013
    Audi RS4 B8 a4 b6 1.8t , a4 b8 3.2
    Russia
    oem audi roof box
    rs4 b8
  21. #2341
    May 13 2008
    NoCal - EBay
    ^^^ Looks so good with the color match. GREAT job.
    'SOFTWALKER MODS
    Avant>Sedan! Click
  22. #2342
    Aug 13 2015
    LA
    Hi you said earlier those are Whispbar Flush roof racks and mount against the inside of the factory rail? Do you know the specific model for that? I'd prefer that over the wrap around rubber. Do you have a close-up of that mount? Thanks!
    Nevermind, I searched the Yakima website: It's a RAILBAR SINGLE BAR MEDIUM (Dimensions: L 40.14 in x W 4.00 in x H 1.50 in) and a RAILBAR SINGLE BAR SMALL (Dimensions: L 37.75 in x W 4.00 in x H 1.50 in)
    https://yakima.com/products/railbar-system
  23. #2343
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    I know it’s not an Avant but wanted to share… freshly color matched IMG_4834.jpg
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
  24. #2344
    Junior Member Two Rings ultimo's Avatar
    Dec 20 2014
    Serbia
    I have this Thule Polar 700 that perfectly matches my needs and I can fit all snowboard gear in it, except for its color. Now that Q7 is here I was wondering if should I get one of the Dynamic models or just paint this one...
  25. #2345
    Feb 07 2021
    C1C7A03E-E565-457E-9ECA-7D7451D27834.jpgE0EDAE90-25D1-4843-9529-3EC05CC314A7.jpgC1C7A03E-E565-457E-9ECA-7D7451D27834.jpgE0EDAE90-25D1-4843-9529-3EC05CC314A7.jpg
    Quote Originally Posted by cleoo View Post
    thats right
    2022 RS6 avant
  26. #2346
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by ultimo View Post
    Why not both?
  27. #2347
    Feb 07 2021
    2022 RS6 avant
  28. #2348
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    The old Thule Atlantis twice painted over has finally been upgraded.
    Wooded Winter by Ryan Ponto, on Flickr
    It was a great match for the allroad... but looked a little funny on the Q7.
    20230219180849_AP4A1874 (1) by Ryan Ponto, on Flickr
    So here we are! New Vector Alpine!
    Thule by Ryan Ponto, on Flickr
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
  29. #2349
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    What is the biggest roof box (any brand) I can install on my 2015 Allroad? I have the stock roof rack.
  30. #2350
    Veteran Member Four Rings Ozone510's Avatar
    Feb 15 2016
    Audi A4 B8 Avant 2.0T, Audi A4 B7 2.0T SOLD, Audi TT 8J Cabriolet VR6 DSG
    Hayward, California, USA
    Quote Originally Posted by djnuge View Post
    I think size isn't a limitation, but as long as you don't exceed your weight rating and your box fits inside the parameters of the rails. Go as big as you'd like lol
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
  31. #2351
    May 15 2015
    Quote Originally Posted by Ozone510 View Post
    Got it. So what brand and model has anyone installed?
    Sent from my SM-S906U using Tapatalk
  32. #2352
    Feb 15 2016
    Thule is the OEM when you get an Audi Branded one, works best with out design. I have an Audi/Thule one and it gets the job done, but expensive. Get whatever floats your boat
  33. #2353
    Feb 07 2021
    sg
    2022 RS6 avant
  34. #2354
    Feb 14 2016
    S4 Avant
    S4 Avant (6MT)
  35. #2355
    Nov 24 2020
    canada
    OEM roof bars and Bentley roof box (Thule Dynamic M)
  36. #2356
    Sep 24 2012
    Spokane, WA
    Winter mode[IMG][/IMG]
  37. #2357
    Feb 15 2016
    Every time someone comes into my car, they point to the box and ask "what is this for?" Are people really this unaware of roof attachments???934347244.jpg
  38. #2358
    Active Member Two Rings Chaingang's Avatar
    Jan 31 2024
    Virginia
    Added motion xt alpine…
  39. #2359
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    AP4A4676 by Ryan Ponto, on Flickr
    Vector for the win! Actually improved towing mileage vs. our older Atlantis box.
    Ponto
  40. #2360
    Jan 31 2024
    Virginia
    The Vector is so bad ass…I considered it, but went with the Alpine motion instead. $2300 was just too much to justify…..i will go be poor somewhere else
