Originally Posted by
The_Jerbel
How did the plug look when you pulled it out? Did you replace it? You are clearly not firing on cyl 5 for whatever reason. You checked the CP, have you tried replacing or swapping the ignition control modules? CP to plug connector (the CP seat)?
You probably drained out all your coolant, which is why your coolant light is on. Fix the broken t connector and re-fill with G12 coolant.
awww, thanks for the reply. The plug seemed to be ok but I'm not too familiar with this stuff. It was looking black at the tips and a little on the threads. I had just swapped them out less that 1k ago due to other misfires above 3 to 4K RPMs, it fixed that problem.
I just bought a new CP from the dealership thinking it would fix it but it didn't. Like I said before I swapped plug, and CP with cylinder 6 but still not firing on 5. I will try and swap the ignition controls and see what I come up with. I'm not sure how to check the seat?
