Originally Posted by
arbaz
it's not really backpressure. backpressure is undesirable in both cases. from what i've learned, in both n/a and turbo engines, you want to achieve a high exhaust velocity which is not the same as backpressure, but the methods of doing so in either engine is different.
for a turbo'd engine, since the turbo works using a pressure difference, so the goal should be to minimize the pressure behind the turbine. if that's the case, then wider should be better to the point where it's counter-intuitive. i was told that for a turbo'd engine barely pushing 200hp, this point is a 2.5"-diameter pipe. it's pointless to have a 3" pipe.
Right..in a N/A car, the combustion process produces a certain "frequency". The key is to tune the exhaust to that specific frequency in order to maximize power. For some cars that might mean making a 2" dia exhaust, for some it might mean making a 4" dia. Length of pipe determines that as well.
And yes, in a turbo car, the ability for an exhaust to expel gas faster, enabling the turbo to spool faster will outweigh frequency tuning.
Now, where it gets sticky is prior to the turbo spooling. On a large turbo car, let's say the turbo won't spool until 4K RPMs. Prior to that, exhaust tuning for frequency is the best power maximizer, cause you don't have the turbo aiding you in power production yet. Once you hit 4K RPMs, then you want the exhaust to override frequency tuning and get the exhaust gas out ASAP as that will produce more power. Ideally, you'd have a dual exhaust that would switch at a certain point. Prior to turbo spool you'd have your frequency tuned exhaust in use, then when the turbo kicks in, you'd switch to the turbo exhaust. Obviously that's not too practical, so most large turbo owners stick with bigger exhaust as that produces the most gains.
For our cars, however, such a small turbo will spool much earlier in the RPM band so the best bet would be to stick to exhaust expelling first and not worry so much about frequency tuning.
And finally, the size of the turbo will dictate exhaust dia too. A larger turbo would need a larger exhaust cause the more exhaust you clear will enable to turbo to spool better. A K03/04..not so much...the law of diminishing returns would come into use. At some point, the bigger exhaust won't matter cause the turbo is already running at full potential. Typically, for a K03/04 that dia is 2.5" to 3". I doubt you'd see a huge difference between the two.
