Results 1 to 40 of 44
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Question Brake Caliper Piston Tool??
    I'm changing my rear brake pads this weekend and I wondering do I need a brake caliper piston reset tool or can I get away without one, and if so which one is best for the least amount of $$.
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Re: Brake Caliper Piston Tool??
    you could go get one or you could just use a wide flat head and turn them clockwise while you push them in...
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Dec 19 2007
    York, PA
    just go buy one at advance auto and return it...its basically their rental process...its like $109
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by n7plus1 View Post
    +2 on the rental. Or you can go buy a "Brake cube" from AutoZone or similar for a few bucks and compress the piston with a little elbow grease.
    Dec 19 2007
    York, PA
    ^wtf, i never saw one of those...thats hardcore.
    Dec 28 2006
    Western Maryland
    You have never seen a "cube of death"???? I still have one I picked up in 1970!!
    Feb 07 2008
    Orlando, FL
    ^Thats what i was going get but I didn't no if it would work for my car!
    The rental idea is good but $100+ is a lil too much right now
    Dec 19 2007
    York, PA
    i cant imagine twisting that with my bare palm...
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Dirty View Post
    first of all I don't think the rental will be $100. I rent a spring compressor from AutoZone about once a year for $45 (fully refundable). And I had to file down the sides of the round pins on the cube to get it to work on the VW/Audi rear caliper pistons.
    Feb 07 2008
    Orlando, FL
    No no no. it clicks into a ratchet.
    Dec 28 2006
    Western Maryland
    You use a ratchet and extension to press and turn the cube.
    Feb 07 2008
    Orlando, FL
    first of all I don't think the rental will be $100. I rent a spring compressor from AutoZone about once a year for $45. And I had to file down the sides of the round pins on the cube to get it to work on the VW/Audi rear caliper pistons.
    Cool thanks old guy! I think I'm just going to get the brake cube and file down the sides like u said.
    Dec 28 2006
    Western Maryland
    As I mentioned, the one I have is pretty old. If you get a new one I guessing that one of the pin sets should work just fine without any filing.
    Feb 07 2008
    Orlando, FL
    thanks for everyones help!!
    Senior Member Three Rings topcat's Avatar
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    Yeah, the new ones have a pin set that work. I got the disc compression kit from harbor freight, and that makes things effortless then.
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    100 BUCKS?!?! No way...
    You need Schwaben Piston tool. It's 40 bucks, comes in a case, and has all the attachments for nearly every vw/audi there is (some other european cars too). I think the only place where it's easy to find is ECS, that's where I had to get mine. Definitely get it, you'll tear your hair out doing it without the tool.
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Dec 19 2007
    York, PA
    see...i told you ive never seen that before...
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by topcat View Post
    Agreed. I have long since replaced my "cube of death" with a decent compression kit but I certainly got my $$ worth out of it!
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    ^^^x2 I got the cube years ago to work on my GTI, total POS! I bought the brake tool from ECS. Well worth the $40!
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    I haven't done brakes on my Audi yet but most cars I just use a c-clamp or big channel lock pliers.
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
    Senior Member Three Rings BlackA4Turbo's Avatar
    Sep 20 2006
    90 Nissan S13
    Palmdale, CA
    Quote Originally Posted by DELUX View Post
    paid $35 for this kit and it was well worth it...as a matter a fact just finished some rear brakes on a friends MINI Cooper and it worked like a charm
    03 Black A4 1.8TQM Sport - (SOLD)
    08 Black Triumph Daytona 675 - (SOLD)
    06 Black A4 2.0T Quattro S-Line - Daily - Luxury
    07 Black Silverado 6.0 4X4 - The Truck - Towing
    90 Black S13 Silvia 1.8T - Project Car - Performance
    "Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games"
    -Ernest Hemingway
    "A man is truly living the dream when his wife supports his hobbies, habits, and fantasies."
    Jun 29 2007
    Raleigh, NC
    Quote Originally Posted by JoeM View Post
    you know what's wierd?
    i thought the c-clamp wouldn't work on our cars because it wouldn't turn the piston while compressing. but i used one on my rear brakes and it worked. go figure.
    btw. someone should hack up an old ratched, get a cube of death, and weld the square end of a ratchet on the end of a c-clamp.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Three Rings tuner culture's Avatar
    Jul 19 2007
    1.8T Q 1+, Honda Odessy
    Florida
    C-clamp all the way!
    2003 A4 1.8Tq
    19" RPM | Bridgestone Potenza RE960AS
    APR stage 1+ | Forge 007 | Kerscher | AWE | Race tec | RS4 pedals | S4 Grille |
    Dec 19 2007
    York, PA
    why's everyone complaining about $100...you just take it back and get your money back...its an entire kit, so theres like 20 tools in it...pretty much everything you need.
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    I think its because the one that is $35 does the exact same job...100 is redunkulous
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by B6Lovin View Post
    How is that possible? The rear caliper piston needs to rotate and can't just be 'pushed in' like the fronts.
    Here are some brake caliper piston tools for under $50:
    http://www.harborfreight.com/cpi/cta...emnumber=97143
    similar to ECS'
    http://www.harborfreight.com/cpi/cta...emnumber=40732
    Schwaben Piston tool (ECS #9747)
    http://www.ecstuning.com/stage/edpd/...category=Tools
    -Doug
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by I Audi5K I View Post
    WTF is wrong with you people, you go there, pay 100 bucks, take the tool home use it, take it back and they refund you 100 bucks. It costs you NOTHING!!!
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    The C-clamp works because the end portion of the clamp has a rotating face. The friction pressure of the rotating face allows it to turn with the piston.
    Dec 19 2007
    York, PA
    Quote Originally Posted by A4ringedONE8T View Post
    exactly...i dont know how they dont get that
    Jun 29 2007
    Raleigh, NC
    similar to ECS'
    what the guy a couple posts up said -- i didnt think it'd work either, but didnt feel like going to get a tool so i tried it anyways, and it worked. there was enough friction to hold the piston, and it turned as it went in
    The Awesome™
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by woofster View Post
    Strange. Because I had to turn the piston quite a bit to get it back in there. My pads weren't even that worn too. Took more force with the piston retractor tool than I'd think you'd get form a C-Clamp.
    Either way, if it worked for you then great. I have the piston retractor tool so I just use that all the time now. $30 is cheap in my book for another good tool.
    -Doug
    Feb 07 2008
    Orlando, FL
    Ya but you need the $100 in the first place to buy the damn thing!
    Established Member Two Rings gotquattro's Avatar
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    Ah, the trusty ol CubeO'Death....
    Used & bloodied many a time over the years.
    My Audi laughed at it.
    Really. No amount of pressure and turning would convince the piston to retract. Yes, I'm old and have abused many a caliper over the years, but these needed "The Tool"
    I now own the schw...sc..... the one ECS sells......
    Glad to have it, and it's got the different adapters making it worth it just to avoid using c-clamps on my future caliper abuse missions...
    The power bleeder too is handy...
    Got Quattro?
    02 Silver A4 Sport (sold)
    3.0 Q / T / S
    14851's | RS4 Rear Sway | Slotted F&R w/ Hawk HPS & Stainless lines | APR Snub
    2006 MazdaSpeed6 GT #3476
    - clicky-clicky for details
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by gotquattro View Post
    The Motive Power Bleeder is money. Makes life SO much easier. It was effortless to do my brakes.
    I think the hardest part was getting that lower rear caliper bracket bolt out.
    -Doug
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Well, it's not $100 to rent the tool. It's $35 to rent their tool (I've rented it multiple times now from various autozones). $35 sounds better than $100 even though u get your money back
    To those who don't know, they charge $35 and then you get it refunded when you return it.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Sep 13 2009
    2004 A6 3.0
    Boston
    If you do not have either of the tools mentioned you can use needle nose pliers. Make sure that you apply enough pressure and then turn clockwise. It will accuate the mechanism and the piston will begin to retract.
    Feb 07 2008
    Orlando, FL
    I've heard of ppl doing this, but I wouldn't recommenced it as the break cube was a PITA!
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Senior Member Two Rings BRSox307's Avatar
    Aug 16 2007
    I have this one and it works great.
    http://www.ecstuning.com/Audi-B6_A4-.../Tools/ES9747/
    Apr 12 2007
    Milwaukee
    the same tool ECS sells is also sold at harbor freight for $20, and it works perfectly
    Mar 09 2009
    California
    I know this is a very old thread, but I a cracking up over here! It was clear to me the first time you said it that this is a RENTAL deposit, you get your money back. Yet I can't believe how many morons don't read critically and keep saying "I can't afford $100."
