Results 1 to 17 of 17
Thread: A3 rear swaybar
    Established Member Two Rings s4sleepin's Avatar
    Oct 10 2004
    New England
    A3 rear swaybar
    I'm am looking to upgrade the rear swaybar on my 07 A3 2.0T S-line. So far I have found that H&R has a 22mm and a 24mm and Hotchkis has an aggressive 27mm. I was looking for any feedback from people that have used either brands/sizes.
    thanks
    2019 RS5 SB
    2005 SL55 K2
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    Re: A3 rear swaybar
    I have the H&R 24mm adjustible sway bar... love it! Can't compare it to the others you mentioned however since I havent used them before.
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Registered Member Two Rings kwanja_a3's Avatar
    Mar 28 2007
    2007 Audi A3 2.0T S-Line
    Toronto, Canada
    Re: A3 rear swaybar
    Quote Originally Posted by s4sleepin View Post
    thanks
    FYI, here are some more RSB options:
    Neuspeed 25mm RSB:
    http://www.mjmautohaus.com/catalog/i...6211_6530_8809
    H-Sport and AST RSBs:
    http://www.purems.com/products/products.php/CA=1470
    Autotech RSB:
    http://www.autotech.com/prod_susp_swybars.htm#MK5
    Good luck with your research, haha.
    If it helps, the most popularly used are Neuspeed and H&R (both the 22mm and 24mm versions).
    The Autotech one has been ranted about quite a bit, something to do with the bushings being too large that they break the mounting brackets after some use.
    I purchased the Neuspeed RSB after many hours of researching which bar I wanted. It was down to the Neuspeed and H&R 22mm. Despite the Neupseed bushings having to be re-lubricated every year in order to prevent squeeking (the H&R bushings are maintenance/squeek free), I still decided to go this route because I feel that it is a quality made product that will give me the performance I am looking for under aggressive street use.
    I made this thread not too long ago, it may help you with your decision. Be sure to click on the links that other people suggested, there are some good ones!
    http://forums.vwvortex.com/zerothread?id=3686895
    2007 Audi A3 2.0T S-Line 6MT
    http://mydubspace.com/kwanja3
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: A3 rear swaybar
    What about just installing a Stern Rear Subframe Brace?
    I have even talked to Mike at Purems about a GB on these if anyone is interested.
    Oct 30 2006
    2011 GT3 RS, 2011 C63AMG, 2012 E63 Wagon, 2010 ML550, 2006 A3 commuter
    ca
    Re: A3 rear swaybar
    I have it installed, i dont feel a thing.
    Oct 10 2004
    New England
    Re: A3 rear swaybar
    Thanks for all that info!, that helps a lot, much appreciated.
    I'll post after I pull the trigger on one.
    2019 RS5 SB
    2005 SL55 K2
    Dec 03 2007
    2016 Toyota TRD Pro 4Runner
    Salt Lake City, UT
    Re: A3 rear swaybar
    I too am looking to upgrade the RSB on my S-Line A3. Being the engineer that I am, I put my car up on a lift last week and measured the stock sway bars. The stock RSB is 21mm in diameter. I'm probably going to get the Hotchkis kit unless someone here comes out and says that another kit is just as good.
    '15 Q5 3.0 TDI
    SOLD '08 Sprint Blue A3 2.0T | EVOMS MKV/A3 CAI | AWE MKV/A3 Cat-Back Exhaust | AWE Vent Gauge | Falken FK452's
    Oct 23 2006
    2006 A2 DSG Sport, 1993 BMW 325is D/SP Autocross, 2000 MBZ ML320 Designated Ski Vehicle
    Bellevue, WA
    Re: A3 rear swaybar
    The Hotchkiss and Neuspeed appear to be similar tubular bar designs that should be lighter than equivalent stiffness (the tubular bars will of necessity need to be larger diameter than a solid bar of similar stiffness. Oh, wait you're an engineer, so you knew that) solid bars like H&Rs If you looked under the car you probably noticed that changing even the bushings in front requires dropping the front subframe. Swapping the rear is very straightforward.
    You may also want to try just upgrading the bushings to Poly. These are available from Summit Racing / Prothane for about $10.95 (!) a pair. They add a significant amount of rear roll stiffness and improve both turn-in (a little) and holding a line through a corner (a lot). A RSB will do the same thing, only more.
    Caveat: Too much RSB will make the car prone to snap oversteer on trailing throttle, especially in the wet. And just like an old Porsche 911, the only way out is your right foot, firmly applied to the right pedal. Or go off the inside of the corner, ass first.
    Senior Member Two Rings UberA3's Avatar
    Jul 28 2007
    Las Vegas
    Re: A3 rear swaybar
    Quote Originally Posted by Panzr15 View Post
    Yeah and being the electrician I am I took ohm readings on the main harness while the car was still on the dealer's lot.
    2020 SQ5 Quantum Grey - Sport Package - Black Optics - Cete Controller - 034 ECU/TCU flash - AWE Exhaust, Intake, Intercooler
    2007 Misano Red A3 - DSG 2.0T - K04 - S3 body kit
    Registered Member Two Rings llllllllll's Avatar
    Oct 31 2006
    Florida
    Re: A3 rear swaybar
    Quote Originally Posted by kwanja_a3 View Post
    What kinda squeeking does the Neuspeed bar make? Is it like a squashing noise over dips?
    I wonder if this could be my misterious noise i hear every so often over SOME not all dips and bumps?
    Mar 28 2007
    Toronto, Canada
    Re: A3 rear swaybar
    Quote Originally Posted by llllllllll View Post
    that's a good question, I have never heard the Neuspeed RSB squeek in person. Maybe someone else can chime in here
    Jul 28 2007
    Las Vegas
    Re: A3 rear swaybar
    I hear the same thing! Does it almost sound like something is loose and rattling?
    Oct 10 2004
    New England
    Re: A3 rear swaybar
    I ordered the Neuspeed 25mm RSB, should be in next week!
    2019 RS5 SB
    2005 SL55 K2
    Oct 10 2004
    New England
    Re: A3 rear swaybar
    I LOVE IT!!
    The install was pretty straight forward. I set it to the more aggressive setting. The car feels more planted, the steering feels more precise when you enter a turn and the car feels overall more flat. I thought it might be too much, but it feels great. With some effort you can induce some oversteer. No ride quality was sacrificed either. Definitely worth the money! I think I thoroughly pissed off all of my neighbors today.
    2019 RS5 SB
    2005 SL55 K2
    Mar 28 2007
    Toronto, Canada
    Re: A3 rear swaybar
    I LOVE IT!!
    lol, congrats man! Your feedback seems to be the same as everyone elses......... great planted feel, no ride quality sacrificed.
    Registered Member Two Rings Syndromeofadown's Avatar
    Apr 09 2008
    T-Town, CA
    Re: A3 rear swaybar
    Neuspeed 25mm RSB:
    Eurocode has it cheaper.
    http://www.ecodetuning.com/shop/cart...t_detail&p=691
    edit: by 1 cent. whew!
    Veteran Member Four Rings MJM Autohaus's Avatar
    Dec 20 2005
    Many VAG toys!
    T E X A S
    Re: A3 rear swaybar
    Quote Originally Posted by Syndromeofadown View Post
    Not quite, but we sure do appreciate how others sweat our prices like Money Penny does Bond.
    : MJM Autohaus :: 210.DUB.PART (382.7278) :: AIM - mjmautohaus :
    Warehouse Distributors for APR | Sparco | MOMO | Eibach | StopTech
    .....and wholesale prices on OEM and maintenance parts for your Audi, too!
