Results 1 to 19 of 19
    Veteran Member Four Rings amd is the best's Avatar
    Oct 05 2007
    '91 200 20v, 01 A4 2.8 PES
    Manteca, CA
    RS4 Fuel pump specs?
    As it turns out I received a faulty RS4 pump with my APR stage 3 and APR is not covering a new one for me. I was wondering if anyone had the specs (flow rating) on the RS4 pump so I can get a comparable pump without paying $800 or whatever it is.
    Thanks in advance,
    Nick
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    8V Audi S3/RS3 Facebook Group
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    Re: RS4 Fuel pump specs?
    are you talking about the high pressure pump? or the fuel pump in the tank?
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by drexplode View Post
    There is only 1 pump. I think you are referring to the fuel pressure regulator.
    You can get an 044 pump or a walbro 255 pump, both of which work quite well.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    I don't get it, why is APR not sending you a new pump ?
    Oct 05 2007
    Manteca, CA
    I purchased a brand new kit from someone who had it sitting for 2 years and even though it was brand new they said because it had been sitting for so long they can't cover it. Pretty shitty. I'll prob pick up a bosch 044.
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Active Member Four Rings
    Jul 17 2004
    RS4:
    044:
    For the price, I would get the 044. I wouldn't get a 255...those things are really hit or miss.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Oct 05 2007
    Manteca, CA
    Awesome info!!! Exactally what I was looking for. 044 is just slightly less for 1/4 the price. Any write ups for 044 install or would getting the 034 be a better choice?
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Jul 17 2004
    I went with 044 because they have the drop-in solution.
    Alex
    Dec 06 2007
    Calgary, AB, Canada
    The 044 holds it's volume better throughout the pressure range than the RS4 pump. If you look, it starts out flowing slightly less fuel than the RS4, but ends up surpassing it very quickly.
    The walbro is a great pump. There are far more walbro's in use that work great, we just don't hear about them because nobody likes to talk about things that work normally. The 044 is also a good pump, though.
    You just replace the stock pump with the 044 like you would any replacement pump. Just make sure you drain the fuel tank to at least 1/4 before installing the new pump.
    Dec 11 2006
    Boston
    I'm sporting the walbro...so far its a hit. It's noisy though. Solid price though.
    Stage 3+ RS6's
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 09 2007
    Quote Originally Posted by The_Jerbel View Post
    I had a walbro on a previous car that was brand new and it just decided to go tits up so I later changed to the 044 Bosch unit and boy was it awesome. Outflowed the walhbro and lasted alot longer.
    044 and you wont be sorry.
    Cheers
    Dec 06 2007
    Calgary, AB, Canada
    I, like many others, am using the Walbro and it's been great, I have no lack of fuel at all and have had no issues. I think there are MANY others, like me, who just don't say anything. It's only those people who have had their pumps fail that say anything. For the number of walbro's in use, the percentage of failures is very small.
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    i managed to break my walbro pump on my GT car now i pimp the 044 Pump no isses :)
    Oct 05 2007
    Manteca, CA
    So although this pump says external it is the one I need, correct?
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    My APR supplied RS4 fuel pump died too. I replaced it with a Bosch 044 pump, works fine.
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Long Island, NY
    i can put a bosch 044 together for someone if they want make it nice and drop it
    Jul 17 2004
    Quote Originally Posted by amd is the best View Post
    Don't buy from Ebay...you will most likely get a cheap knock-off.
    Alex
    Oct 05 2007
    Manteca, CA
    Quote Originally Posted by lil' is 300 View Post
    Eeeek, I just bought it. I looks pretty legit though.
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    2 questions
    anyone have the part # for the holder, screen, etc for the 255 or the 044 I know they sell them as kits but the pumps by themselves are cheaper and I have a spare 255 sitting around I figure I try to use that
    And is they a diy
