So I just had the high idle thread earlier, I hadn't been driving my car this weekend at all, but I turned it on the other day, the car was shaky and the check engine light was blinking, wasn't sounding too hot. I did a search on this forum came up with most people saying coilpacks are out.
However, If you guys remember I had a high idle issue that I made a thread about, and also the dealership over filled my oil awhile back, when I told them they said the levels are high but it's still ok, it's not too bad. The funny thing is when I first checked in the manual a couple weeks ago about overfilling oil it said it could cause damage to the catalytic converter... yesterday when I checked the manual for a blinking check engine light it says could be a damaged catalytic converter. Funny coincidence or what? I'm not sure what to do, should I still drive the car to the dealership? (about a 10-15 minute max drive)
Also I read through search that over filled oil could spill onto the coil packs and cause them to fail? I'm honestly not too much of a techy person I just learn what I can through what I read I don't work on my car at all. All in all, my car is not under warranty but it seems like everything is pointing in the direction of overfilled oil which Audi obviously did on the last oil change. This isn't recorded anywhere on paper (the complaint about overfilled oil that is), so I'm just wondering what to expect. Someone told me to take the car to a local autozone earlier on this forum so they can see what codes show up for the check engine light, but now the light is blinking and the car sounds bad so I'm not even sure if I should drive the car..
Any advice would be appreciated guys.. thanks a lot
edit: car is a 100% stock 1.8t
