Originally Posted by
dirtybrd
You are correct about velocity, but the MAF doesn't measure velocity if measures flow. Reverse what you said about the straw. If you breath in as much air as you can thru it in one breath it will take a while, but a paper towel will flow the same amount of breath just in a shorter period of time. Get it. Both will only flow what is drawn thru them. With the larger MAF it will draw more air in thus increasing velocity with it. I might have contidicted myself.
Actually Velocity is exactly what it measures. Velocity and flow from the standpoint of a maf are the same, just a poor word for it really.
A hotwire maf has a heated element inside of it and it cools as air moves over, that is how the velocity and density of the air is measured.
The 1.8T Maf sensor measures velocity of the air, and density. Actual mass air flow is calculated in the ECU from this number and the ecu believes it has a stock sized housing.
If you're interested I found the calculations:
Velocity (M/)s * Area (M) = Volume/time = (Meters^3/Second)
By using a larger housing you decrease this velocity because the area is increased.
M^3/second = Velocity* Area
Area = PI*Radius^2, larger area = lower velocity at same flow.
The car will respond to the lower velocity by using a lower injector duty cycle as It thinks it's getting less air, so it needs less fuel. If the injectors open less that is less fuel going into the engine. You would need to match proportionally larger injectors to make up for this difference in velocity.
The ecu will have some adaptation and will to a point tune out using fuel trims to get an appropriate air fuel ratio, however if you increase the housing to 3" without an injector swap or ecu re-tune you will run lean. Lean conditions cause a lot of heat especially on a turbocharged car which can lead to "holeing" pistons and other pretty major problems.
Regards,
