Results 1 to 9 of 9
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    bumper repair, best solution?
    So I picked up a s4 bumper tonight, pretty cheap, really cheap, but it has some damage. It is cracked in a couple spots, one being pretty bad on the drivers side lower half, the bottom, is cracked up to where the grill would be. What do you think would be the best way to repair this? Would fiberglass be strong enough to hold it? thanks for any input..
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: bumper repair, best solution?
    perhaps some pics might help here homi
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Feb 28 2007
    04 a4 USP ; ATS
    well, its a bit late, and its currently in the back of my car and it is snowing out.. So cant do much about that except to kinda outline how it is on a normal bumper.. It is cracked where it's highlighted.
    Senior Member One Ring blks4turbo's Avatar
    Sep 27 2007
    01 s4,99 1.8t,95 jetta vr6,E30
    ma
    no ..fiberglass will not work those bumpers are plastic and i bealive it will not stick u would have to get SEM bumper repair kit its a tube has 1 to 1 mix that u push and thn mix them together but first u should get a SEM product i belive its a metal to plastic or plastic to plastic glue very good idunoo hope some of this makes sense
    Oct 06 2004
    Minnesota
    3m plastic weld
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Both SEM and 3m Will work. I've done it with previous cars and i plan on fixing a small crack on mine too
    --Black 2001.5 -S4- 10secS4 Tuned
    Sep 11 2007
    Dirty Jersey
    all the above answers are sorta correct, you're bumper is probabaly "TPO" plastic
    if it was me, I'd use my plastic welder to "tack" the bumper back into alignment
    feather edge all cracks, sand a good amount of paint away from the imperfections, then I'd use a TPO prep spray and some TPO repair adhesive either by 3m or SEM, or duramix (all are 2 part tubes that require a specail gun)
    fill imperfections and cracks
    for extra strength you can lay up fiberglass cloth in the adhesive in non visable areas
    (note that does not mean fiberglass and resin in the typical sense, it just means layering the glass cloth into the unset adhesive to strengthen it)
    Feb 27 2005
    North Wales, PA
    From experience, its easier just to find another bumper. A paint can smashed my bumper pretty good and its never been the same ever again. I've repaired the cracks with the SEM bumper repair stuff. Next time I will try a plastic welder to feed in some more plastic to bond.
    Feb 28 2007
    04 a4 USP ; ATS
    Yeah, well I mean I don't see myself coming along another s4 bumper anytime soon unless I feel like paying a lot for it. So I'm gunna try and repair it, gunna have to pick up some of that SEM stuff. Plastic welded a little bit today just to hold it together so it doesn't get worse And just completely snap in half ha. This si more or less a project for me cause I mean my stock bumper is fine.. Just wanted some ideas of how to go about fixing it. Thanks for the replies/help. Any other input would be greatly appreciated, first time working with this kinda stuff.
