Results 1 to 20 of 20
    Dec 25 2007
    Cable or drive by wire?
    Are our cars cable throttle or electronic? I have noticed that sometimes if I am in first with the clutch in, I blip the throttle a bit to get going, then sometimes if I have to clutch in quickly again, when I attempt to blip the throttle again there is no response, and the throttle seems to have gotten very confused.
    Anyone else experience this?
    http://www.johndent.com/news.jpg
    01 GT 577rwhp/506rwtq
    08 B7 A4 2.0TQ
    00 Focus Hatch
    Dec 13 2007
    05 Denali, 64 baja bug, 67 beetle, 04 passat W8.
    Eastern CT
    Re: Cable or drive by wire?
    its an electronic throttle - DBW
    Dec 25 2007
    Quote Originally Posted by audiB7t View Post
    I figured. Thats why I suppose it gets confused if I make quick throttle movements. Often times Ill tap it then tap it again and nothing is happening. Other times its superb response.
    This normal?
    08 B7 A4 2.0TQ
    00 Focus Hatch
    Veteran Member Three Rings TunaRollZ's Avatar
    Feb 20 2007
    911 TT/A5 3.2L/S4 4.2L
    Sunnyvale CA
    dbw is weird.
    08 Audi A5 s-line 6MT - new daily
    06 Audi S4 6MT - JHM'ed :)
    01 Porsche 911 Turbo 6MT - some mods ;)
    06 Scion Xa - road trip monster
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Definitely drive by wire. I don't think Audi has made a cable operated throttle since sometimes in the mid/early 90s
    Aug 20 2007
    2006 Audi A4 2.0T Tip'
    Fitchburg, MA
    Quote Originally Posted by Phrost View Post
    Definitely drive by wire. I don't think Audi has made a cable operated clutch since sometimes in the mid/early 90s
    Throttle?
    Jan 24 2007
    Wisconsin
    ^ lol yup. My bad
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Yeah the (electronic) throttle is not very sensitive to rev-matching techniques. Just step down on the throttle more or blip it twice- that's how I've been doing it for the last 2 years.
    But just think of it this way, BMW's electronic throttle is even less sensitive to "blipping". You literally have to mash the pedal to the floor for about a second to get proper response.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    What about our steering? My hunch is its conventional because when you pull out that servotronic relay it gets really really heavy. Am i wrong?
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Clutch isn't the same as throttle. IIRC B5 wasn't DBW until the 99.5 refresh.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Sep 18 2006
    GTA Canada
    Quote Originally Posted by AlexK View Post
    Is there a production steering-by-wire i.e. non-concept car by anybody at all?
    2nd Ring: 2006
    4th Ring: TBD
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    i like the DBW much smoother. you can take your foot on and off the gas without any jerking
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by MoroIsAnOrange View Post
    Pretty sure the new BMWs have electronically controlled steering. Also I imagine those new Lexus LS cars that park themselves have to be electronic as well.
    Sep 11 2007
    San Mateo, CA
    Did some research and looks like nobody has 100% steering-by-wire. So they all maintain the mechanical linkage but the electronic system can intervene when necessary - i.e. ESP, automatic parking.
    So I guess my question is, do our cars have any ability to do anything like that?
    AWD_4TW
    It's been raining very often here recently. And I always drive with ESP OFF in the rain, the traction control system and I don't get along very well in low traction environments. The car wants to shift weight around and understeer while the steering input I give says experience and skill tells me this line and that speed is more than fine.
    I've noticed that with the ESP off the steering becomes heavier (at all speeds) and becomes a lot more sensitive to input. Basically I have control now, car doesn't tell me what to do. Haven't pushed the car hard enough in the rain yet to test if ESP comes back on (probably never will). But I've read some threads in the past with regards with ways to turn ESP off completely because it does supposedly kick back in to prevent you from trying to do AWD donuts
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    I've done AWD donuts and ESP doesn't come on, but you will burn up your tires and oil pretty quickly. I was runnin her pretty hard.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Quote Originally Posted by Blown01NJ View Post
    This normal?
    I've noticed this same thing in this car, minor annoyance and as another poster said, no where near as bad as BMW's DBW. I like the fact that when I'm in 1st in heavy traffic I can precisely control the throttle so as not to stall the car, it's very sensitive to input in that situation.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Jan 24 2007
    Wisconsin
    Our ESP is GREAT in the A4. If you're in a foot of snow with it on, instead of it just applying ABS hardcore to almost make you stall , it transfers power and makes the best out of the situation. Sliding around is hard, but that's how it should be. I'm very impressed at how safe it feels with ESP on.
    With ESP off, I think the steering feels really good. It's a little understeer biased, but I'd rather have that than oversteer. Learn your car better and you won't sit there and burn up tires, the torsen system is awesomeeee
    AWD_4TW
    I've never driven in snow before but I'm assuming that quattro was designed with that more in mind. Personally I feel very uncomfortable with the way quattro transfers weight and "power cutting" at corner apexes sometimes. But in rainy conditions I now drive with ESP off, and the car's behavior is very predictable (for me at least).
    Sep 18 2006
    GTA Canada
    I don't think those can be considered steering-by-wire. If you use the same definition that's used for DBW & fly-by-wire in the aviation industry, SBW would mean there isn't a mechnical linkage between the steering wheel & the wheels.
    2nd Ring: 2006
    4th Ring: TBD
