Results 1 to 9 of 9
    Veteran Member Three Rings audi314's Avatar
    Oct 22 2007
    06 A6 C6 Avant, 12 F-150 FX4 Twin Turbo
    ATL
    Wheel/tire size calculator
    I ran across this calculator. Its pretty in depth. Just thought I would share.
    Calculator
    I had a BT Audi!****> Lost at Barber MSP 11/1/09
    Hero-->http://www.youtube.com/watch?v=Q3gN6...eature=related
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Wheel/tire size calculator
    Very nice.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    That one's pretty cool. Nice find.
    I usually use these two:
    Tire size calculator
    Offset calculator
    -Darrick
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Jeez. If I went to 17x8"s with 215 tires, my actual speed would be 31.2% faster than my speedo was showing?
    That sucks.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Nov 14 2006
    Gig Harbor, WA
    Depends on the aspect ratio of the sidewall.
    -Darrick
    May 19 2007
    Bay Area
    So there's ways to tweak with the dimensions to get smaller margins of change?
    SIXFIVEOHphoto
    Nov 14 2006
    Gig Harbor, WA
    Correct.
    For example, if the tires on your car right now are 225/55/16's, if you went to a 215/50/17 there would only be about a 1% difference.
    Using the 225/55/16 as an example:
    The first three numbers (225) are the section width of the tire (width at its widest point). The second (55) is the aspect ratio of the sidewall, or the height of the sidewall as a percentage of the section width (the sidewall height is 55% of the width of the tire). The last number (16) is the size of the rim they go on.
    -Darrick
    Registered Member One Ring papasito's Avatar
    Jun 04 2007
    2000 A4 B5
    Montreal, Quebec
    Quote Originally Posted by audi314 View Post
    Calculator
    Thx !!! very helpful
    Mar 05 2008
    Trinidad
    thanks
