Results 1 to 40 of 63
    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    B6 S4 .vs. B7 S4
    ok....Ive been thinking about "upgrading" to a B6 S4 from a B5 S4, but I have seen a couple 05 B7 S4 almost at the same price as the B6 S4'S.
    any thoughts ?
    same V8 motor ?
    same MPG ?
    01' B5 S4 STG.II TIP
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Re: B6 S4 .vs. B7 S4
    Quote Originally Posted by EUROTEK//S4 View Post
    any thoughts ?
    same V8 motor ?
    same MPG ?
    biggest differences come in on 06 model year like 40:60 torque split, but i like the B6 better for the clean lines
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Same motor, same MPG. I think springs and dampers are different.
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    suspension is recalibrated i think
    exhaust is different
    looks obviously different
    unless you are getting 2006+ not 2005.5+ then you do NOT recieve the 60/40 rear/front torque split benefit, it is 50:50 same as b6
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Ultimately, the differences are truly negligable other than looks. I went out in September to buy a 05.5 B7, and saw an 05 B6 literally right next to it. There was a $1500 difference in price (B6 cheaper), but the deciding factor was that I found myself checking out the B6 even though I was there for the B7.
    I bought the B6 that day, I just liked the way it looked better, especially from the back (I'm an ass guy).
    Registered Member Two Rings ososlow's Avatar
    Oct 22 2007
    LA
    i like the B6 more than the B7 and was set to find a 2005 B6, only, didn't even care for B7 at all even if they were cheaper (they were not).
    though i must say, the B6 does look old-ish relatively speaking. the B7 still looks new-ish.
    Veteran Member Three Rings 4Chio's Avatar
    Mar 14 2005
    STL
    having had both the B6 and now the B7 the suspension is alot rougher and tighter on the b7. I would say more than my B6 with mods. I cannot figure it out
    2018 S6 Prestige ,sport, JB4
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    2016 S3 Monsoon Gray Prestige | Sport seats| 19's W/ mag ride| Milltek Res valve
    2013 X5 M, 08 A6 4.2 Sline, 08 :.R32 ,07 S4 White/Black, 04 S4 6MT,
    Established Member Two Rings DC25S4's Avatar
    Jan 28 2008
    2007 Audi Q7 4.2 Premium S-line, 2009 Honda CBR 600RR ABS
    Alexandria, VA USA
    the 60:40 split is only available with MT6 editions of B7 S4 MY06 or higher...having just upgraded from B6 to B7 the interiors are almost identical, the suspensions are stiffer IMHO on the B7 and at idle the B7 sounds a little meaner...BTW I have the 60:40 split now and can't tell a difference but I must admit I am mearly a daily driver, not a track tester...
    07 Q7 4.2 Premium (Phantom Black Pearl) - S-line package, Lane Assist, Tow package, Roof Rack bars, DVD headrests added, switched interior to wood trim
    09 GMC Yukon Denali (Black)
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Quote Originally Posted by DC25S4 View Post
    the 60:40 split is only available with MT6 editions of B7 S4 MY06 or higher...having just upgraded from B6 to B7 the enteriors are almost identical, the suspensions are stiffer IMHO on the B7 and at idle the B7 sounds a little meaner...BTW I have the 60:40 split now and can't tell a differnce but I must admit I am mearly a daily driver, not a track tester...
    if you're going to lower your car, the suspension doesn't really matter. the 60:40 can be accomplished other ways
    Jan 28 2008
    Alexandria, VA USA
    :) i think the trunk is bigger with the B7...and you get the longer warranty coverage with the newer model...
    Veteran Member Two Rings Omar0022's Avatar
    Dec 12 2004
    Bay Area
    Quote Originally Posted by Lugi20 View Post
    Same situation with me, but the end result was different. I went in to look at two B6's they had on the lot, but they were in bad condition. Next to them was a B7. I was never a fan of the B7, but as I looked at her more and more she got me. All I have to say if you go with the B7 you will end up loving her too.
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    when I went to the Dealer to test drive my B6, I wasn't sure if I'd be ok with the looks. I've always preferred the side and rear profiles of the B6 vs B7, but I think the front end should look more agressive. But when I walked into the detailing bay where they had it parked, my jaw dropped. It was minty mint, and I fell in love.
    Not sure if that contributed anything worthwhile to this topic - but maybe my advice is that I wouldn't choose one over the other for looks alone.
    Mar 14 2005
    STL
    i agree the exhaust on the stock B7 exhaust is great i almost wish i did not get the apr exhaust because if it was not for looks they sound about the same... the resanator on the b7 is really small compared to the B6 when i put my miltek exhaust
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    Active Member Two Rings Fox233's Avatar
    Sep 21 2007
    A6, Lexus RX330, RHD Mini Cooper, Silverado, GSX-R 600, Ducati Hypermotard
    San Jose, CA
    I too fall into the category of liking the B6 looks over the B7 looks. My friend bought a B7 S4 not too long ago, black, just like my B6, and I still prefer mine when we have them parked next to each other. I think the back and sides are way hotter on the B6. B7 front grille is starting to grow on me however. I like the open mouth look of it. My heart still falls with the B6 in the end. So hot. =)
    2014 Audi A6 3.0 Supercharged, Prestige, Glacier White, Sport PKG, Full LED
    RHD 1974 Mini Cooper
    1988 Chevy Silverado 4x4
    2006 GSX-R 600
    2008 Ducati Hypermotard
    2008 R32 #4318/5000 - SOLD
    2004 Audi S4, Loaded, Black, Black and Silver Alcantara, 19x8.5 3 Piece DTM Kreuz Split 10. - SOLD
    2005 Inifniti G35 6MT, Black - SOLD
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    pics of the two that im looking at....
    2004 B6 Nogaro blue S4
    looking for pics....
    2005.5 B7 WHITE S4
    Senior Member Three Rings killintime's Avatar
    May 02 2007
    VA
    From what I know, the two cars are the same, except of course the looks.
    In my oppinion the front end of the B7 is better looking, but the backend of the B6 is wayyyyy better looking than the B7...the B7 looks like a wimpy car from the back. The B6 looks like it will kick your ass comin' or goin'.
    You can find some B6's out there with some low mileage and low prices to go along with it.
    Good luck,
    KT
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    fsi engine in b7 should get better mpg than b6
    TEAM|AXION
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by speedydragon View Post
    No FSI engine in B7 S4.
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Quote Originally Posted by jsh139 View Post
    4.2 FSI V8 in the new S5 with 16 est. MPG city
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Yes. But no FSI for the 4.2L in the B7 S4, so it doesn't even matter :)
    Registered Member Two Rings AVANT-GARDE's Avatar
    Feb 25 2008
    LONG BEACH CA
    For myself its a mixed verdict. But I chose the B6 because it seems to hold fast to its European look. In my opinion the B7 lost juuuust a little bit of that flavor and swayed a little towards the Far East.
    I know its a SIN to post these pictures but... I have honestly been driving and have had to take second glances to see what was in the lane next to me. *guilty*
    Mar 11 2008
    2005 B6 S4
    I'm new to Audi's but I chose the B6 over the B7 purely on looks (particularly the grill on the B7 did not appeal to me). Obviously personal preference but but just my opinion.
    Senior Member Three Rings slowturbo's Avatar
    NoVA
    love the white b7 with that interior. No stock rims though?
    -Alan
    2018 Audi S4
    Daytona Gray Pearl/Black Napa/S Sport/Carbon Inlays/19's/Nav
    Gone: 2017 A6 2.0T, 2016 VW GLI, 2016 S3, 2005 Touareg, 2011 328xi, 1991 bmw 318i, 2002 bmw 325i, 2007 335i, 2004.5 A4 1.8tq
    Established Member Two Rings Rossi15's Avatar
    Mar 03 2008
    2025 Ice Grey Metallic GT3RS
    Columbus
    I test the drove a 2005 B6; prior to the new B7 Body style. I loved the ride, quick as crap, but I'm really not a fan of the front. I really like the front of the B7's, the B6 looks "dated" to me. But I was checking Autotrader.com and they have some pretty good looking 06's, and very good lease programs.
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    like them both, i think the b7 still looks a bit more fresh. and i personally love the grill. mechanically not much different. stock i didn't particularly like my b7 suspension. kind of harsh and way too high.
    previous cars were b5 and b6 a4's
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    Owning a b6 i used to envy the b7, but it's give or take for me now. The b7 looks much more aggressive, but the b6 looks much more classy.
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Mar 12 2007
    Boston
    I prefer the look of the B6, but the B7 is a fantastic looking car, as well. Especially in person. Basically a jump ball there.
    For me, though, the big difference is the exhaust note. The B7 sounds decidely better. No question about that. A nice rumble at idle, and even at lower RPMs. If not for the ugly and weak looking quad tips, it might not even need an aftermarket catback. The B6 is too quiet.
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    true and (true.)
    Sep 24 2007
    Chicago
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Quote Originally Posted by ososlow View Post
    True, that's why I went with the B7. Resale will be slightly better since it is a "newer" body style. Especially with the B8's coming out soon, the B6's will be 2 generations old. The B7 also fit's Audi's current image with the trapezoidal grill. The B6 looks outdated (although it is still sharp and I still like them).
    Established Member Two Rings AudinLV's Avatar
    Jul 09 2007
    S6 RS6(RIP) S4 Ducati M Dark
    LV, NV
    I like them both, B7 front is newer and looks fresher/update with the new Audi line-up but B6 rear is much more clean and mean IMO! If u like blue, u got to consider the B6 NOGARO WITH BLUE INTERIOR!!
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    The B6 seems to sit lower with stock suspention. For the most part they are the same.
    Mar 01 2008
    ^^both those are sweet.
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    yeah...I dont know about those chrome wheels.....
    Oct 18 2007
    Moscow
    I'm partial to the B6 looks as well. For sure the back and side lines are preferable, but I have also thought that the front of the B7 is just too aggressive for the A4/S4. On the RS4 however, I think the B7 front grill goes really well.
    Apr 29 2005
    Woolrich Pa.
    No chrome.The wheels are 19" forged polished aluminum.
    Senior Member Two Rings S4Sumi's Avatar
    Jan 22 2008
    Black B7 S4, gsxr 600
    San Jose, CA
    I just picked up my b7 S4 6spd manny a couple of months ago and i'm loving it!! The reason I didnt want to go with the b6 is because to me the front end looks the same as the older Audi's. I love the back end of my b7.. love the dual tip APR exhaust Also, I got a pretty kick ass deal on my b7! I can't believe I almost went with an A4.... (no offense to A4 owners)
    Jan 10 2007
    VA
    I like both the B6 and B7.The style arguement breaks down like this:
    B7: I like that the car looks more aggressive and modern.
    B6: I like that the car looks more 'classic audi' and european.
    Overall I give the design award to the B6. The lines flow much better. However if you like the more aggressive grille and the feeling of driving something that looks more modern, go with the B7.
    Jan 01 2008
    Long Island NY
    I like both the B6 and B7 but the B6 looks dated.
    Feb 25 2008
    LONG BEACH CA
    It looks dated because it IS dated. Its an older style. That might actually be a GOOD thing 20 years down the road. The S4 is losing the V8 next year - going back to a turbo V6. There will be two body styles available with the V8. The B6 [2 1/2 years] and the B7 [3 1/2 years]. And check these CHARTS!! woo hoo!!
    2005 B6 S4 / Twin Turbo Pink Carseats... yea. fastest toddlers in town.
